Ironton 10 in Multi-Sliding Compound Miter Saw
Review by OldCoach posted 01-31-2017 01:34 AM 4393 views 0 times favorited 14 comments Add to Favorites Watch
Ironton 10 in Multi-Sliding Compound Miter Saw No-picture-s No-picture-s Click the pictures to enlarge them
I decided to add a sliding miter saw to replace a Ryobi miter saw in the shop. However, it had to fit in my miter saw station that is 26” deep. That left me with few choices-Bosch, Hitachi, Makita and the Craftsman Compact were the major players. All of these would fit in my station. Since all my saws use 10” blades, I preferred to stay with a 10” model. Of course cost was also a major factor, preferring to stay under $250. That pretty much left the Craftsman. I found a couple of used Makitas, but they were in the 300-350 range.
That is, until I stumbled onto the Ironton sold by Northern Tools. However, I could not find much information, and very few reviews on this product, hence, this review. I found my saw listed on Craigs List and got it for $150. New, they sell for $250 which is about 50-60% less than the big 3 and a slightly more than the Craftsman..
The saw I bought looks like it had been used very little. The sliding mechanism is smooth, almost as smooth as the Hitachi and Makitas I fondled. It has 2 sliding arms on either side which give the saw a little more stability in my opinion. I added a zero clearance insert and when I cut the slot, it measured 13 7/16 long to the fence, making it one of the longest cross cut saws on the market. I have the front feet sitting 23 1/2 inches from the wall, which gives me 4” of space in the back to work the bevel lock.
This saw is a dual bevel, going 47 degree both directions. It will cut miters 50 degrees both directions with detent stops along the way. The detents are very crisp and solid. The bevel to the left is very smooth. To the right, the slide housing hits the top of the fence at 45 degrees. This may cause problems if I ever have to make this cut.
The saw has its quirks and I am sure the more I use it I will figure out what I need to do before I cut a bevel or miter. The fence is tall and slides for additional width. As for accuracy I was able to adjust it .006 of square over 12” on the second adjustment. I will get it closer when I get more time. Dust collection, hooked to my dust collection system is awful. I will try to improve this as I did on the old Ryobi.
The power is adequate. It cuts through 2x material without any noticeable reduction. I used the same blade I had on my Ryobi and it works, but I’m sure a blade replacement is overdue.
For the woodworker hobbyist looking for a sliding dual compound miter saw that has a small footprint and a reasonable cost, take a look at this saw. I am positive there are better saws on the market, but for those of us who do this for fun, this is a step up from the entry level chop saw, and affordable.
-- Play cowboy on weekends and make sawdust in between when not watching football
View OldCoach's profile
OldCoach
47 posts in 902 days
14 comments so far
View NormG's profile
NormG
6141 posts in 3031 days
#1 posted 02-05-2017 12:55 AM
Sounds like you may have just purchased a saw that will provide you with great service for the foreseeable future, congrats, thank you for the review, I was not aware Northern sold a saw like this
-- Norman - I never never make a mistake, I just change the design.
OldCoach
#2 posted 02-07-2017 03:46 AM
Since this review, I fiddled around with it and got it to .001 of square using the 5 cut method. I repeated the cut 3 times and each time it came to .001. That is about as close to square as I need in my little shop.
I fanagled with the dust collection and so far I have not seen any improvement. It is by far the worst thing about this saw, much worse than my old Ryobi chop/miter saw. If anyone has any ideas I would welcome your suggestions.
So far I have designed extensions out of a variety of plastic containers with not much luck improving the dust collection.
View BenDupre's profile
BenDupre
650 posts in 515 days
#3 posted 03-11-2017 05:50 AM
Menards sells this saw under the Masterforce brand. They go for $299 but recently it was $229 on sale. I had never heards of this ironton brand before. Glad to hear its a descent saw. I have been waiting for Menards to mark it back down but i might have to buy this one instead. Thanks for the heads up
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
View sjonesy1's profile
sjonesy1
5 posts in 410 days
#4 posted 05-09-2017 07:02 PM
Just was curious how the saw was doing since you have had it for a few months now? Any quirks to mention or any reason not to buy it? This is really the only review I can find online concerning it and I was thinking about buying one.
Thanks,
View builtinbkyn's profile (online now)
builtinbkyn
2381 posts in 968 days
#5 posted 05-09-2017 07:08 PM
I asked about this saw last year in a thread I made. And like you found, there’s wasn’t much info. I ended up with the Bosch 10”. Keep us posted on how it performs.
-- Bill, Yo!......in Brooklyn & Steel City :)
BenDupre
#6 posted 05-09-2017 07:09 PM
Its back to $229 at menards. This week. I actually tried to buy one and had to take back. It wouldnt square up. Not enough fence adjustment. I would have had to wallow out the mounting holes to make it square.
sjonesy1
5 posts in 410 days
#7 posted 05-09-2017 07:21 PM
builtinbkyn-thanks for the response. I had read your comment about it a year ago and noted nobody knew much about the brand. I am surprised nobody seems to know much about them, that is probably not a good thing.
BenDurpe-I looked at it at menards online-thanks for posting that above, and I do not have one close by to go look at it. Are the two the exact same saw? It seems as if there are some differences, I do not know if it would affect the fence or not though.
Northerntool currently has a promo for $50 off making this saw $199.99 with free shipping.
BenDupre
#8 posted 05-09-2017 07:38 PM
Idk they look the same. Sometimes there are minor differences between brands importing the same product. It would probably be a good saw if you can get the fence square. Like the other guy i decided to move on and get a bosch. Have to save a little more for that one. BTW it is also on sale this week at Menards. If you are game i would get the northern tool for $200 that seems like a real good price. One feature this has is up front release of the trunion.
sjonesy1
5 posts in 410 days
#9 posted 05-09-2017 08:05 PM
I looked at the Harbor Freight one and the plastic piece which holds the positive lock was a big negative, but you cant beat the price at $139.99. It also had alignment issues which could be fixed if you put locktite on the adjustment screws.
I have looked at the Kobalt but for the 12” which is $299 (a little more than I want to pay if I can avoid it) looks interesting but I know it can be had for cheaper ($199) and it seems it has alignment issues.
I may wait and see if I can get an update from OldCoach to see how this saw is holding out before I pull the trigger and purchase anything.
OldCoach
#10 posted 05-10-2017 01:41 AM
I have been using the saw for a few months now, not everyday use though. Like I said in the original post, the dust collection is awful, even though it is connected to my dust collector. I have not been able to improve it so I have resigned myself to break out the shop vac at the end of each use.
I have only used the double bevel on one project. I had to re-cut the corner because of a math error, but the saw made a perfect corner when I got the angles right. The 45* detent on the bevel cut is very accurate, both directions. I mitered some 2×10 SYP and there was some loss of power through the cut. But I am still using the same blade I had on my old miter saw. I’m sure that a new blade would help alleviate some of that problem. Anything smaller, I have not experienced any power loss.
Overall, I am pleased with the saw. For what I do in my shop, it is better than I had and I find I use it more now than I did my old Ryobi chop saw when I would use the table saw for the larger cuts. With the 13” crosscut capability, I don’t have to use the table saw sled near as much. I feel that it was $150 well spent. I would pay $200 for a new one.
I did get an email when Sears had a sale on their compact saw for $189. If it was dual bevel I would have been tempted to take a look. If you are patient a good deal will eventually turn up on Craigslist for a saw that you can add to your shop. If the Ironton shows up, I would not hesitate to pull the trigger for the right price.
sjonesy1
5 posts in 410 days
#11 posted 05-10-2017 01:58 AM
OldCoach-thank you for the update. I do not intend to use the saw much just the occasional home owner type stuff. With that being said, the dust collection is no big deal to me, I will likely never hook it up.
My wife has recently asked me to build a coffee table, 2 end tables, and a buffet bar which I did with a 15+ year old Benchtop 8 1/4 that is just extremely basic and functions but that is about it. At some point, which dad never did use it when he had it, there have been several pieces go missing so all I basically have is the saw itself, none of the extra fences or clamps or even the miter set screw. But now she is wanting me to build a crib, changing table and dresser for our upcoming child and after I realized just how basic mine was, it was time to buy a new one.
If this saw is good and precise, which from your review it seems to be, it could very well be the best bang for the buck. I plan to buy an arbor laser for it just basically since I think it could assist and it is a fairly cheap add-on for about $20.
I appreciate the update and I plan to buy mine tonight. Thanks for all the input.
BenDupre
#12 posted 05-10-2017 02:28 AM
Fwiw the Masterforce has a laser. Still $30 cheaper the northern tool version is better value. I have an irwin laser on my HF and it is always dead on. Only drawback is it only marks the left side of the cut.
sjonesy1
5 posts in 410 days
#13 posted 05-10-2017 02:36 AM
The masterforce I would have to pay shipping (they do not offer a ship to store and the closest one is 1.5hr one way away) which was 21 and I’d have to pay sales tax too where there is one in my state. There is not a northerntool in my state so I dont have to pay sales tax on it.
I was looking at buying the Oshlun LG-M01 Miter and Portable Saw Laser Guide from amazon for $22, it has good reviews and is half the price of the irwin which is $48 on amazon. I appreciate the input once again.
BenDupre
#14 posted 05-10-2017 02:51 AM
My Irwin is going out. Had it for 10 years and two saws. Worked great until it didnt. Replaced batteries and it still wont work well. The inertia switch is sticky.
