| Review by FoggyGarage | posted 84 days ago | 973 views | 0 times favorited | 10 comments | ![]() |
- Bridgewood Design Cutlist Plus, Woodworking Software
- Brand: Bridgewood Design | Category: Other
A few years ago I found Cutlist Plus from Bridgewood software. At the time, it was the only consumer-level layout + cutting diagram software I could find. (I have recently found the cutlist plugin for Sketch-Up, and I will talk about that at the end of this review).
Cutlist is available from the Bridgewood Design website: http://cutlistplus.com/
The software is available in a few different versions. The $90 Silver version allows you to create a modest project with 50 parts, but the biggest limitation I found was that it did not allow you to create sub-assemblies as separate projects and then specify multiple copies of that assembly in a larger project. I eventually upgraded to the Gold edition, which has very few limitations. There is also a $500 Platinum version which has some extra tools that make CAD design easier. I can’t comment about those options.
CLP does layout very well. You define parts in a spreadsheet-like interface. The program has a database where you can enter in the type of material (species, thickness, board/sheet, etc), so that the material will be available in a drop down when you set up your project. Options such as edge-banding and grain orientation are also included. (I have not used the edge-banding optimization, but CLP will tell you how much you will need).
There are options for printing; diagrams with scaled boards, expanded diagrams, or just a list.
As stated previously, the Gold version allows you to import another project as an assembly, and you can then specify multiple copies of that assembly.
Here’s where things get nice…
You can also enter your existing stock into the database. So if you have 3 6”X18” 4/4 cherry boards, CLP will include those off-cuts in the optimization. And, if you have a sheet of ply in your stock, and you commit a project that cuts off half, CLP will automatically update your stock to reflect the change.
CLP allows you to label each part, and produces cutting diagrams with options to include the part name, assembly and dimensions of the cut part. You can also print the BOM to standard Avery labels so that you can stick a label on each part as you cut them to keep track. See my kitchen cabinets project to see a cool pic of 92 stiles and rails lined up with labels.
I routinely update my stock with the materials I have for a project; once in a while, especially when I am using expensive wood, I take my laptop to the lumberyard and temporarily add in the boards I find to see how well the optimization works.
For those who run a commercial shop, the program also tracks costs, time and helps you price out a project.
The Google Sketch-up plugin has an option to output the results to CLP; I tried it (as I am new to Sketchup) and it seems to work very well.
I cannot recommend this program enough. I originally bought it when I screwed up a layout on a $110 sheet of cherry plywood. I got by for a while on the Silver version, and only upgraded to Gold when I had a project that benefited with the sub assemblies options. It has been worth every cent.
On a personal note, I have communicated with their support for a printing problem I had, and they got back to me quickly and fixed the issue.
The software does have to be activated over the web (or via some other method). However, you get to install it on at least two computers and if you have to reinstall, you just click that that’s what you are doing on the registration form. This is pretty important to me, as my day job (programmer) requires me to reinstall my PCs all the time.
Quick Disclaimer: I am not affiliated in any way with the company that makes this. I just love their product.
10 comments so far
home | projects | blog
20828 posts in 722 days
posted 83 days ago
This is a nice review. I have used the silver version for several years and have found Cutlist to be an indispensable part of my woodworking routine. I have thought about upgrading to the gold version but so far I have been able to work around the limitations of the silver version. As you said it not only is a nice program to produce project cut lists but it also is an inventory management program.
Rileysdad
13 posts in 179 days
posted 83 days ago
I use CutListPlus too. It’s a great tool. I wish they had a Mac version. I have to run mine through a PC emulation and it’s a little quirky.
-- Measure twice, cut once, buy extra stock.
FoggyGarage
14 posts in 86 days
posted 83 days ago
RileysDad,
At one point I was running it both on my XP laptop and through WINE emulation on a linux workstation. I had to set up something to sync the materials database between the two, but it worked well- although I could not print from linux.
OK. Sorry for that guys. This is a woodworking site and there are more than enough places on the web to discuss software on linux machines.
25871 posts in 1300 days
posted 83 days ago
I’ve used CutlMaster and love it. Also a happy user.
posted 83 days ago
This is not a PC woodworking site,or a Linux woodworking site, or a Mac woodworking site, but a woodworking site. So discuss away about software for woodworkers.
Jimi_C
200 posts in 135 days
posted 83 days ago
I second Karson, I run Linux at home as well, so it’s good to know it runs through WINE. I haven’t tried Sketch-Up on my main desktop, and my Windows laptop is work-owned, so I don’t like to install too much on it in case they complain. I really loved all those labels on parts for your cherry kitchen project, so I may look into using this when I do my own kitchen.
hooky
148 posts in 219 days
posted 82 days ago
cool that sounds pretty good to me
it sounds like it would beat trying to work it out in my head
I will have to look into seeing if i can by it here in Oz
Thanks
Hooky
-- Happiness is a way of travel , not a destination (Roy Goodman)
CessnaPilotBarry
1294 posts in 603 days
posted 82 days ago
I also like Cutlist a whole bunch! It’s also great for moldings, when you can specify lengths from your vendor to end up with the least waste. If the vendor can only supply a certain length, a recalulation is quickly available.
For solid hardwood furniture, I don’t use it so much, as the parts need to be chosen with figure and color in mind.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
Wingstress
215 posts in 415 days
posted 79 days ago
This question might be a little off topic, but… I’m an Engineer who by day designs aerospace landing gear components using Unigraphics and or CATIA (Both very powerful programs that run about $20,000 a seat) I’m a woodworking hobbyist who loves to come home and design/build. I’m primarily a box maker, but my Engi-nerd side can’t help but want to model everything, draft it and optimize it in 3D and 2D. Because, I’m used to very powerful software where I can simulate “engine out” failures or missile strikes, I find that drawing stuff on Google sketch up to be so frustrating, because I feel like I’m just drawing free hand and I have no spacial reference or scale.
It appears that you guys use this software as a cut list and/or inventory calculator as you would in production management. I make Christmas and Birthday presents with wood (not money or business). Would you recommend that I research this product, or do you have any other (inexpensive) ideas? Please don’t say sketch-up. I’m just generally interested in being able to design stuff on my laptop, when my wife is forcing me to watch dancing with the stars with her.
Thanks for the help!
Tom
-- Tom, Simsbury, CT
FoggyGarage
14 posts in 86 days
posted 79 days ago
Hi Tom,
You can download a trial from the website, but it’s not a modeling program. It’s really designed for optimizing your cuts from lumber to minimize waste. You enter rectangular dimensions for each part into a spreadsheet-like interface.
I don’t do any CAD, so I am just starting with Sketchup- but I can see what you are talking about in regards to scale.
