| Review by PurpLev | posted 83 days ago | 1697 views | 0 times favorited | 38 comments | ![]() |
- DeWalt DW735 Heavy-Duty 13" Three Knife, Two Speed Thickness Planer
- Brand: DeWalt | Category: Planers
After getting a Jointer, I realized very quickly that I should have gotten a planer FIRST. I was able to flatten a board, and joint an edge, but that is something that I can do fairly easily with hand planes. thicknessing that board on the other hand is sometimes a bit more challenging to do by hand – especially when you have multiple boards to mill.
Price
I have limited funds, and so visit craigslist often for tools. I was actually not expecting to find the Dewalt 735 in my budget, but was searching for Deltas and other planers until I saw this one with the mobile base, extension wings, and extra sets of blades for a very very very attractive price – needless to say, I bought it. and didn’t even feel the need to negotiate the price. with that said – MSRP is a bit higher than other lunchbox type planers. but it is a more robust built machine, which justifies the extra cost, although might put this unit out of reach to some (me included… without that once in a lifetimes deal, I wouldn’t be able to justify it’s purchase at the moment).
Build and Weight
This unit is WELL BUILT! it’s built like a tank, and weighs like one at 79lbs. it’s great for me since it means the planer doesn’t move anywhere once placed on it’s stand – I don’t even bolt it in place, however – this might be a con if someone is planing to use this as a portable machine. it’s portable, but heavy to lug around.
Controls
OK, I really like the controls on this one, compared to other machines – the side wheel is very convenient to use as opposed to a top handle. I like the fact that it can be grabbed anywhere along the wheel, including the handle (obviously) for minor adjustments.
the front cut gauge is nice and easy to read, nothing too extreme here -looks kinda the same on all the planers I’ve seen.
Depth stop is excellent – as can be seen in 3rd picture, you can set a depth stop to most common board widths, which will stop the cutters from going any lower – this is a nice feature as you can always go back and mill more boards to same exact width even several months down the road. so far I haven’t really used this much as I usually try to mill my parts as thick as possible (from the rough boards) so not really trying to match a “common” width – but its a nice feature to have when you need it.
unlike some other models, this planer does not have a cutterhead lock, because it does not require it since the cutterhead/motor assembly rides on the 4 spiral posts (consider this an auto-cutterhead-lock). which is nice, as this is one less thing to worry about/deal with.
Extra Features
As mentioned above – this planer comes with a depth stop for most common thicknesses.
This planer can run on one of 2 speeds, either for rough planing (faster rollers) or finishing planing (slower rollers). the switch has to be turned AFTER the planes is turned on and the motor is running. I do find mine to be somewhat hard to turn at times, and for most – I just use the rough setting for faster planing as I hand plane the boards anyways afterwards with a #4 smoother.
Built-in Chip blower – the planer blows away the chips real well, it will inflate my 4” DC hoses if I don’t have the DC on. you can either hook it up to a DC, or just blow the chips away / bag / trash bin.
Performance
This planer is LOAD, but I guess not any louder than any other universal motor planer. ear protection is a MUST – really!.
I only take 1/16” and lighter cuts with this planer, mostly at ~1/32. and it works great. I can double feed it, and really quicken things up (load 2 boards side by side).
to tune the planer, I use paste wax on the bed to make it smooth, I did notice that on a humid day the bed became somewhat rough, and I had to retouch it with some more paste wax. also if there is a build up of chips on the bed, it will interfere with the power feeding of the boards – I had the boards stop midway and had to manually pull them out before I reapplied paste wax to solve that problem.
the planer cuts very nice and smooth. I do get some lines in certain places on the boards since there is a nick in the blade – but since I smooth my boards with a hand plane it doesnt really bother me. I could move one blade to the left, and another to the right to eliminate it , and eventually flip the blades around (dual edge blades), but for now this is no big deal for me, and something that is to be expected.
Other than that , I’m extremely happy with it as it frees me from having to consider which board I should use since I can use whatever I want, and mill it my way.
Accessories:
I got this with the extension beds which work nice for added support for boards on both sides. curious though – these wings are supposed to fold up for storage – but only the infeed table folds properly – the outfeed table cannot fold up because something is in it’s way, so I just leave it unfolded.
I also got this with the mobile base – this base is fantastic! moves smoothly and locks down firmly. also it has some storage shelves ,and is a base well made.
Conclusion
Highly recommended machine, although a bit on the pricy side. If I had the space and money for a new one – I’d probably go with an induction planer all together, but for a mobile planer, I think this one is one of the toughest machines in the market today.
EDIT: There are several third part companies that make replacement knives/cutterheads for this planer:
Accu-Head makes a helical cutter head (this is the same company that makes the helical cutter heads for the steel city planers)
Infinity Tools makes replacement HSS and Carbide blades for this planer
38 comments so far
home | projects | blog
3710 posts in 873 days
posted 83 days ago
HI Sharon,
You sound pretty pleased with this. I haven’t heard anything but good about this planer.
Have fun with it, but remember to wear hearing protection. I said, wear hearing protection. LOL
DrDirt
183 posts in 635 days
posted 83 days ago
I know I shouldn’t say ‘only’ four stars but what didn’t you like? That kept it from the top score
I do like mine – I do occasionally still fight snipe even with the outfeed tables set to tip up a nickels thickness which helped.
For a ‘portable’ – I haven’t heard of a better unit.
-- Its never too late to have a happy childhood. But the second one is up to you and no one else.
RexMcKinnon
670 posts in 88 days
posted 83 days ago
I have this one also. Hard to compare as it is my first and only planer ever owned/used but I think it is a really good unit. I rarely get snipe. If I do it is usually my fault. Long board need support and sometimes I get lazy then I get snipe. One of best setting is no blade alignment. Drop them in and its over. Takes me about 15 minutes to change 3 blades. If there is any complaint; blades seem to be an issue for some. I am on my 3rd set and I have planned a couple hundred board feet. I can’t say if this is good or bad becasue of my lack of comparison. I know Byrd sells a spiral cutter head for this unit with carbide blade but it is around $600. With four sides to each carbide cutter it could last the life of the planner. At $60+ for a set of HSS from dewalt it will not take long to spend the $600 for the spiral head cutter. Now you have to think about the fact that your planner just doubled in price. For that amount could you have just bought a better one? I am still debaiting and every time I order a set of blades I wonder if I should just spend the money on the spiral or never spend it. That is not a complaint but an issue I have make a decision on. I love the machine though.
-- If all you have is a hammer, everything looks like a nail!
16695 posts in 470 days
posted 83 days ago
congrats on a new toy.Hope it serves you well. good review.
nanoman
15 posts in 156 days
posted 83 days ago
I love my Dewalt 735. It has power to spare and it’s 3 blades makes rough board smooth pretty quick. I like the finishing function and find while it does take a good twist to turn on, it really does a good job.
-- Nano Nano - Live long and prosper
Julian
688 posts in 419 days
posted 83 days ago
I’ve been abusing my 735 for about 5 years now. It stands up to the task without any problems.
-- Julian, Park Forest, IL
25792 posts in 1294 days
posted 83 days ago
Sharon: Great review. I’m glad that you got a planer that suits your needs.
Craftsman on the lake
812 posts in 331 days
posted 83 days ago
I’ve got the 734. Nothing like having a good planer. My space is a little limited and it was one of those tools I put on a wheeled cart that is slid in between other power tools for occasional use. I find that it’s sitting out in the middle of the floor more often and that I’m accessing it all the time. Not only for flatting wood for use but things like making some nice svelt thin sides for drawers or getting wood down to 1/2” for some other use. With it you’re not stuck at 3/4” all the time.
Good purchase.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
lew
4482 posts in 649 days
posted 83 days ago
Great review, Sharon.
I just got the same planer a couple of weeks ago. Had to replace my old Bridgewood Lunchbox planer. The only thing I don’t care for is the same thing you mentioned. After a couple of passes thru the planer, the boards started sticking. More wax fixed the problem but I can see that if you are in the middle of a “run” all the same thickness and have to stop, wind up the elevation, apply wax and then try and rest to thickness to exactly where your were- it’s going to be a real pain in the A**.
Lew
Ryan Brown
35 posts in 83 days
posted 83 days ago
I love my DW735!
Instead of wax on the surface I use a spray lubricant with teflon and I feel that it lasts a LOT longer than wax. As for “shifting gears” always make sure that the planer is on and not under any load. I tell ya, mine shifts between speeds as smooth as butter. It’s about 2 years old now and probably has 1000 bf or so through it.
-- If you can't fix it with a hammer, you have an electrical problem. Roanoke, VA
Routerisstillmyname
110 posts in 402 days
posted 83 days ago
Didn’t think 735 came with infeed/outfeed table?
-- Router è ancora il mio nome.
PurpLev
2739 posts in 542 days
posted 83 days ago
I actually read some mixed review on older versions of this planer, some mentioned that the sprockets for the knives were faulty at some point – I decided to take the plunge and take a chance, and luckily, this one wasn’t one of the faulty ones. it works really really well, a true time and labor saver.
Lee – WHAT DID YOU SAY????
Dave personally I don’t care much for the 5 Star rating system, I think that a 10 star system is a bit more forgiving. this is definitely a 9+ machine in that resolution, but not a perfect 10. I did give some 5’s on previous reviews- but I find that in order for me to rate something as ‘perfect’ (for me) it really has to WOW me = overperform it’s price. in this case, this is a high priced item, and as such performs according to the expectations – but not beyond. which is why I rated it a 4 – aka really really good machine, but not perfect – lacked the ‘WOW’ factor for me.
RyanBrown – I’m curious – which spray are you using? as for the gears, I did change it while motor was running but NOT under load – I got this one used, so maybe it has seen it’s share of switching in the past – just thought I’d raise it up, but personally since I don’t use it that much it’s of no big difference.
Routerisstillmyname – it doesn’t ‘COME’ with infeed/outfeed, if you’ll read the review- I mentioned that it’s an Accessory – purchased separately (I bought this used, and the guy sold it with the tables and mobile base)
Cato
138 posts in 206 days
posted 83 days ago
Purp- Noice!!! I have been eyeing this planer for some time, and waiting for the year end clearance prices to bring the cost down a bit. I considered a jointer, but think the planer will be first.
Good review and like your choice in tools.
3037 posts in 915 days
posted 83 days ago
That’s a good one Sharon, You willnot regret going for a bit more technology.
Dusty56
3458 posts in 581 days
posted 83 days ago
Congratulations , Sharon : ) I’ve had my eye on this for quite some time and I think that they finally have all of the bugs worked out of it now. I have two DeWalt planers already and they have paid for themselves many times over : )
I think that you did make the right choice by getting the jointer first because if the board isn’t flat to start with , then it won’t come out of the Planer flat in the end. Enjoy your new to you toy !
ellen35
532 posts in 326 days
posted 83 days ago
Very informative review, Sharon.
Sounds like you got a winner in that planer.
Ellen
-- Ellen on Cape Cod
SteveM
76 posts in 1060 days
posted 83 days ago
Like just about everyone else, I’ve had a 735 for some years, beat it up and love it.
kkickback
234 posts in 109 days
posted 83 days ago
Purplev great review like always…my experence with this machine running red oak dont take more than 1/16 off @ a time other wise you will have dull blades very fast…lol other than that i lov this machine, even with muffs on the ears its still (loud)...with out a doubt
-- christoper Blanchard, Michigan
kkickback
posted 83 days ago
I been hearing that some people been able to get this planer @ home depot for 275..with set of extra blades….cause of clearencing em out…
Todd A. Clippinger
5635 posts in 993 days
posted 83 days ago
I have had the opportunity on job sites to use several different brands of portable planers.
This unit has to be the best on the market. The two speed feature produces the best cut and the chips seem to be well evacuated which reduces chip dents. It weighs more than most but the cut it produces is beautiful and on slow feed it is exceptional.
I have a DW733 that is 11 years old, it still runs faithfully and produces a good cut. I imagine this machine should serve you like the old unit and you will be very happy with it.
I am excited for you that you got such a great machine.
PurpLev
posted 83 days ago
Thank you guys,
although I’ve read a few “enjoy your new toy” – I actually have had it for a while now, otherwise I would not write a review on it.
just like with the jointer – I never ever take cuts more than 1/16” and rarely go above ~3/64” (aka, don’t really take 1/16” cuts) but that may be because I don’t have much experience with these machines, and would rather be on the safe side both for the machine, and for the knives – so far it has worked great for me – and since I’m no production shop, I don’t REALLY have to rush milling too much (definitely faster than thicknessing by hand for me- so I’m happy with that)
Todd – thanks for your excitement! I sure hope that they didn’t start slacking in production after they made the 733, and keep the same QC for the 735 so it’ll last for that many years (so far from other’s comments and reviews, it seems like it’ll be the case)
Brad_Nailor
1213 posts in 851 days
posted 83 days ago
Nice Purp! This is a great planer and you got all the good accessories with it. I see these pop up on Craigslist occasionally, but they are gone before I can send an email. One thing I am interested in allot of the reviews i read on this machine people were complaining about the knives wearing out fast….be interesting to see how they do for you. I think allot of the people complaining about the knives prematurely wearing out were taking too much off at a time. I want to buy this planer…..or the Steel City with the helical cutter head..
PurpLev
posted 83 days ago
Brad – so far it performs well, but I haven’t run too much through it – only did my bench using this:
I read the same reviews regarding the knives life span, and was concerned about it as well, but I guess that’s the same with all the replaceable planer knives out there. there are Carbide knives available for this planer (third party) and also a helical cutter head replacement (third party – company that makes the helical cutter heads for the Steel City planers) – which I mentioned before… I guess I’ll add a link in the review as well.
Tim_456
45 posts in 489 days
posted 82 days ago
I’ve had mine for about two months and so far so good. I love it. Easy to use and was built rock solid. I paid a bit of a premium for it but I also think I’ll never have to buy another one.
DrDirt
posted 82 days ago
I got a set of knives from Infinity
http://www.infinitytools.com/DeWalt-735-Replacement-Knives/products/1345/
I got them almost 2 years ago and have not had to flip them yet, though there are a couple of knicks, which I clean up with a card scraper, but otherwise still cutting a good surface.
They have gone up in price to ~80 bucks though while the DeWalt OEM blades are 55 bucks at Amazon.com.
The Infinities are my third set of knives in the past 7 years – - -2002 purchase,Original set inside, one set of Dewalt replacements and now the Infinity set. It appears they are doing better than OEM blades but my workload on the planer is uneven through the years.
Cheers
Routerisstillmyname
posted 82 days ago
Hummmmmmmmm, Amazon reviews are not too favorable with the knives it uses. any user feedback on that?
THX
buffalosean
61 posts in 280 days
posted 82 days ago
it something how strong that blower is! that planner blows harder than my 1 1/2 hp dc sucks!
good luck with yours. I’ve been really happy with mine
-- Sean Buffalo, New York
gbvinc
538 posts in 840 days
posted 82 days ago
Great review. I have had mine for a few years now and have given it a real work out. No complaints at all!
McLeanVA
147 posts in 327 days
posted 82 days ago
Great review. Thanks for all of the details. Glad it’s working out well for you.
-- Measure, cut, curse, repeat.
RexMcKinnon
posted 82 days ago
Dave do you have a rough guess on the board ft you have put through your planner.
Has anyone out there tried the carbide blades and helical cutter heads.
Any info would be great.
DrDirt
posted 81 days ago
Rex – I use a lot of 6/4 and 8/4 stock and do some resawing to make boxes – so for a “load” on the planer I would that though I have run ~8-900BF through it…For a reference, I would say that with resawing and planing both sides to re-establish flat – so an average of 3 passes/side and a 4” typical width – it is about 14000feet of of 4” surface has gone under the rollers.
Seen the carbides but the price vs. ‘extra’ lifetime doesn’t seem to fit. (though I paid 65.00 for mine from infinity) The Infinity blades are 79 bucks for HSS and 249 for carbide. Though I havent experienced it myself, I doubt that one gets 3+ times the life for the carbide. Typical is that carbide holds up better but is not as sharp an edge…If you can get the DW735 for the 274 dollar close-out that was reported today from Home Depot on this site…
http://lumberjocks.com/topics/9757
.then go for it. But I think the price of knives vs. the amount of use…is questionable financially.
marksalot2005
41 posts in 175 days
posted 81 days ago
I have the same planer with extension wings. Works very great have had no snipe done yet. I have planned a lot of red oak wood. I am going to build a cabinet with moble base to move it around my shop. When I finished using it for the day. I fold up the wings. The exit wing I fold up and use the power cord as I wrap it around the planer. It traps the rear wing in place. Then I can move it to a shelf rack. Almost too tall to fit on a shelving unit. But it does fit for now. May it give you many thousands of board feet great work. I feel its a great benchtop tool. Had to save my pennies for a while to get it. But worth every dime when used.
-- Mark, Katy, Texas, Did they give Noah a hardtime about the wood boat in his driveway
PurpLev
posted 81 days ago
Thanks marksalot2005 glad to hear I’m not the only one with the outfeed wing not folding all the way…
PS to all that are interested, it seems like HomeDepot are having another power-tool-sale where you can get instant $150 off any purchase over $599
RexMcKinnon
posted 81 days ago
Dave I see your point. Infinity claims that the carbide will last 10x longer than hss but I have trouble believing that. Also the nice finish is one of the perks of this planner and if switching to carbide will compromise that I am not sure that is a switch I am willing to make. It would be nice to try the carbide but it costs way too much to buy and pass a few board feet and thow to the side if I am not happy with the result. I think I will stick to HSS while I think about it some more.
Ryan Brown
35 posts in 83 days
posted 80 days ago
frostwood
34 posts in 80 days
posted 80 days ago
HD does have it on clearance sale for $274.. I picked up one last week but they seem to be hard to find . I was fortunate as the other two store in the area that I checked did not have any.
-- With each new day, celebrate life. Love God with all of your heart. Share Jesus with those around you and make a positive impact on those you meet. Bob
JimBuchanan
26 posts in 242 days
posted 76 days ago
I had one of these until about 4 weeks ago. Someone walked into my garage (door was left open the night before) and took it along with some other things and tools. I was pretty ticked. I had only run one thing through it.
-- Jim
RexMcKinnon
posted 76 days ago
Wow, nothing worse than some !@#$% loser taking your stuff. I hope you were insured Jim.
