Can be made to work, but not all that great...
Review by dbhost posted 91 days ago 380 views 0 times favorited 8 comments Add to Favorites Watch
Can be made to work, but not all that great... No-picture-s No-picture-s Click the pictures to enlarge them
I am posting this so all the LJ-ers out there won’t start thinking I drank some kind of Harbor Freight Cool Aid or anything like that…
A while back I acquired a Drill Master 94203 1” to 2-1/2” Hole Saw Set from Harbor Freight Tools to bore some large holes after my old Ace Hardware set was discovered missing. (Long story, problem since solved). As often as I have been using a hole saw, I figured a cheapie wouldn’t be a bad thing. I was wrong.
The good.
The steel cups are nice and straight, and if it was completely up to the cup, this would drill nice, perfectly straight holes exactly where you want them.
The injection molded case is nice for keeping your bits and pieces organized.
Everything you need is included, however…
The bad.
The set screw threads in the arbor were stripped out from the factory, making it impossible to tighten the set screw onto the pilot bit.
The pilot bit was bent from the factory, meaning once the set screw problem was taken care of by rethreading the hole and adding a new set screw, the saw still wouldn’t drill a straight hole.
The solutions to the bad.
Using a machine tap, rethread the hole for the set screw, and replace the set screw with the new larger size. Pick your tap size and set screw size carefully, there isn’t a lot of material to work with here.
Replace the pilot bit with a decent quality bit. I matched up the bit with a same size old mismatched Ace Hardware bit I had in a toolbox. I ground a flat spot for the set screw to tighten down to, and installed it. NOW the hole saw set works fine.
Long and short of it, don’t waste your time, unless money is really that tight, and you have a tap set handy, and even then it is a pain to deal with… You will be far better off with a better quality set…
-- Trying to follow the example of the master.
View dbhost's profile
dbhost
620 posts in 128 days
8 comments so far
View DaleM's profile
DaleM
412 posts in 280 days
posted 91 days ago
I guess I got lucky. Mine wasn’t stripped out or bent and works just fine. I was happy since I knew I was taking a chance buying from HF. It seems like they sell some good products but are lacking quality control and consistency.
-- Dale Manning, Carthage, NY
3041 posts in 918 days
posted 91 days ago
I used mine on the weekend because, like you I put my 2-1/2” Milwaukee saw in a safe place where I can’t find it.
I bought mine for $2.00 at a clearance and it is still no bargain.
I practically had to stand on it to get it through 3/4 MDF.
It also didn’t have a hole in the side to remove the plug necessitating taking the whole thing apart .
just another nail in the Chinese manufacturing coffin.
View AaronK's profile
AaronK
409 posts in 360 days
posted 91 days ago
i must be lucky too. mine is fine, for the 1 time i used it. i expect to use it maybe 1 day out of the year, so its a good value to me.
View John Gray's profile
John Gray
1753 posts in 781 days
posted 90 days ago
I have the large and the small sets. Found each size good for about 1 hole each and then they’re useless. But there are times when I’d give the price of a set just to drill one hole.
View Kent Shepherd's profile
Kent Shepherd
833 posts in 182 days
posted 90 days ago
Once again Harbor Freight proves their worth.
Thanks for sharing
dbhost
posted 90 days ago
In all fairness, I haven’t found any problems with the cups. They stay relatively sharp through repeated use in wood. They are NOT hole saws I would use for metal applications though….
After tapping, and replacing the set screw, I also replaced the bent drill bit with the same size (I forget now what size that thing is) bit from an old mostly missing bits Ace Hardware set. I simply knocked a notch into the shaft with my bench grinder so the set screw had something to bite on… It works fine now, and I don’t hesitate to use it, it is however a good example of why it was so cheap…
View dustyal's profile
dustyal
447 posts in 371 days
posted 84 days ago
Yeah, I picked this up on one of my browsings through the store… real cheap. I’ve cut a couple of holes… worked fine. May not last… but I use hole saw soooo infrequently that it’ll do for me. No problem with stripping set screws or bend drill bit. Not high quality stuff, but for occasional weekend woodworker it isn’t a bad deal.
-- Al H. - small shop, small projects...
View David Craig's profile
David Craig
39 posts in 5 days
posted 2 days ago
I picked up the small and the large diameter set. I am guessing these are about in every workshop in some corner somewhere. I had no issues with mine. I wouldn’t recommend it for anything thicker than 3/4” nor any hardwood or MDF. I did find the 5” handy for a roofing project recently. I had to put a hole in for some new flashing and the saw worked fine on the thin OSB. I will probably spring for the better bi-metal blades in the future, but this set does alright for my limited use.
