Another Harbor Freight gem!
Review by dbhost posted 93 days ago 1414 views 1 time favorited 17 comments Add to Favorites Watch
Another Harbor Freight gem! No-picture-s No-picture-s Click the pictures to enlarge them
Knowing that the lathe itself is just the tip of the financial iceberg when it comes to wood turning, I needed to control costs wherever I could without sacrificing quality I searched, talked with the club representatives at the various woodworking shows etc… And the response came back about the Jet JWL 1236 and its CLONES… It would appear this lathe had been rebranded by several companies, including, but not limited to Grizzly, MasterCraft, and for those of us that are a bit on the cheap side, Harbor Freight under their Central Machinery brand name.
Unlike other Central Machinery products I have attempted to decipher the owners manual to, the 34706 lathe was written in perfectly understandable American English. I am chalking this up to an accident, or rewriting someone else’s manual…
The entire thing came in one just sub 200 lb package, with plenty of foam block to keep the parts from banging around, and into each other. Everything was in good condition, present and accounted for.
The complaints I have read about the stand being unduly flimsy are partially true, and one of two reasons this lathe gets 4 instead of 5 stars. I somewhat thing this is unfair though as this is a matter of the TYPE rather than the specific lathe. Unlike the 1440 the 1236 and its clones get stamped steel stands instead of nice solid, heavy cast iron. So yes, this lathe DOES tend to do a little dance across the floor with uneven bowl blanks the the like, but more on that later on… Overall for what it is, the stand is acceptable.
The other area that I disliked, again was part of the design with the positionable head. Bringing the head back to center does not always, well… Bring things back center. I had some initial trouble lining my center pins on my live center and spur drive. Harbor Freight support was no help at all. BUT… Some quick perusing the exploded parts diagram in the unusually helpful manual led me to fiddle with the nut below the headstock, a minor adjustment later and it swings back where it belongs and the centers line up perfectly!
The variable speed settings lowest speed is 600 rpm, which is a bit high for large diameter turnings, but not horrid… Power is plentiful from the 3/4 HP motor, not enormous but nothing to sneeze at. Yeah you can jab a skew in a work piece and stop it, but then again people can do all sorts of stupid things…
The fit and finish of this lathe is top notch, every bit as nice as the “Real” Jet lathes on display at Woodcraft. Good quality paint, good machining on the cast iron, everything just fits right. Simply put, this is no slacker.
Back to the stand issue. Like most all other lower end free standing lathes, and that is what this is, do not mistake this for a high end large capacity lathe, it does it’s job nicely, but it is no 16” swing machine by any means… Well like others of this type, the stand is simply stamped steel, and offers NO ballast, or weight to resist vibration with…
A simple piece of scrap plywood cut, and screwed to the spreaders, provides ample room to drill through for slots to store your bits and pieces like spanners, faceplate, knock out bar etc… But more importantly, there is enough room to stow at least 2 80lb bags of Concrete. That additional 160 lbs helps anchor that lathe to the ground, and keep it from dancing around the shop floor…
Just like all the other Harbor Freight machines, but it smart, get it on sale, and use the 20% off coupon. Mine was on $179.00 sale with the 20% off coupon. The price tag is well worth it. This lathe with an inexpensive chuck, and a good HSS starter chisel set can get you quickly finding turning Nirvana.
As long as you expect this to behave like the type of lathe it is, you will be VERY well pleased with the quality of this lathe. It is every bit as good as the more expensive brands, but without the higher price tag…
-- Trying to follow the example of the master.
View dbhost's profile
dbhost
620 posts in 129 days
17 comments so far
16982 posts in 474 days
posted 93 days ago
interesting review well done
View dustbunny's profile
dustbunny
328 posts in 192 days
posted 92 days ago
I also bought this lathe for the price tag and features.
Mine came out of the box with no issues, all aligned.
I put a piece of plywood on the leg supports, and built a small box for accessories on the ply shelf.
Awesome review, and if I can add a note- if anyone is thinking about trying turning, this is a great machine at a price that is not going to bankrupt you.
Try it, if you don’t really like it you haven’t broken the bank.
Lisa
-- I inherited the woodworking gene and it's gone into overdrive.......
View Doug's profile
Doug
43 posts in 205 days
posted 92 days ago
Anchor it to the floor, I don’t have a central Machinery wood lathe, Mine is Delta made in 1960, But it’s anchored just the same
-- Use your imagination ! you'll be suprised
dbhost
posted 92 days ago
Dustbunny, you got pics of your box / shelf layout? Mine’s a basic shelf drilled to hold the accessories nice and tight… I have considered building a box, or a proper stand, but nothing springs to mind…
Doug, If my workshop wasn’t my attached garage, I would SERIOUSLY consider it. A friend of mine’s soon to be ex father in law has an old Rockwell that is anchored to the floor of his shed / shop. He never has to chase his lathe…
3046 posts in 918 days
posted 92 days ago
I had that style lathe a few years back and did a ton of work with it.
The Reeves pully needs a good cleaning about once a year but it ran like a top for me.
I put a plywood shelf across the leg standards and sandbagged it.
It make a huge difference in vibration.
View Mike67's profile
Mike67
5 posts in 233 days
posted 92 days ago
Good review, thanks. I have that lathe now and have used it for a bunch of furniture parts – chair legs, spindles, etc. It works fine. Great starter lathe at a good price when its on sale.
View jake's profile
jake
36 posts in 600 days
posted 92 days ago
I don’t have a lathe and appreciate your review. I have to watch the price of my tools and can’t just buy the top of the line as many people do. With so many tools made in the same factories these days, there are many bargains if people are willing to look past the brand. I will likely buy one based on your review, thanks!
dustbunny
posted 92 days ago
David,
I built this box as part of the shelf, it is basically four sides of 1” pine scraps I had laying around, and a double hinged lid. Because the legs are mounted on angles, a solid lid will not swing up without hitting the height of the space, or the top of the tapered legs. I pretty much threw this together in an hour or so.
I had a piece of styrofoam from some boxed machinery, I cut out spots for my faceplates, and it had compartments that I put stuff in. It mostly has chucks, faceplate’s, tool rests, and wrenches.
If you need more info you can PM me.
dbhost
posted 92 days ago
No need, you gave me LOTS of ideas… Love that box idea, super easy to do, What about ballast with it though? I don’t see enough space for sand bags…
posted 92 days ago
You can drop a bag on either end and still have access to the storage.
View Broda's profile
Broda
235 posts in 416 days
posted 92 days ago
I have no doubt that that is the same as the popular MC900 lathes we have in australia. they are sold under different logos ie. Carbatec, Timbecon, hare and forbes etc. but are all made in the same factory.
I bought mine second hand for 200 bucks (including a nova chuck) and I have had no problems with it. Its a great lathe for a bigginer turner untill they can upgrade to something better.
This is mine; they look identical
-- BRODY. NSW AUSTRALIA -arguments with turnings are rarely productive-
dbhost
posted 91 days ago
Yeah it looks the same. I have seen this lathe online in various colors and stripes with different names on it, they all seem to be off of the same line in Taiwan, just go through different paint and stickers…
FWIW, I LOVE that orange color, and if I end up needing to repaint mine just might get a coat of orange…
dbhost
posted 90 days ago
Just looked up that MC9000, yeah it looks identical…
You guys in Oz are getting hammered price wise though. That lowest price on that lathe I found is the equivalent of $330.00 U.S.D., still far less expensive than buying it with a Jet label but about double what we can buy them for on sale here… Of course I am not privy to the sale flyers and such.
FWIW, regular full retail for this tool here in the U.S. is $249.99 for the Central Machinery variant.
It runs $799.00 for the Jet variant.
Aside from cosmetic differences, such as color, striping etc… mounting location of the switch and the switch itself, which I honestly prefer where the Central Machinery switch is. Makes it a LOT easier to put this lathe on a different stand…. and possibly the tool rest, but the demo model I saw in store appeared identical…. I really see no difference other than name brand recognition. Which is worth something if you are a retailer, but worth diddly squat if you are just trying to turn a few spindles and bowls…
View Mike Gager's profile
Mike Gager
230 posts in 164 days
posted 83 days ago
great review, i plan on getting this lathe as soon as i have the extra cash
View DTWoodknot's profile
DTWoodknot
91 posts in 83 days
posted 78 days ago
Nice review i think you sold me, i have an old craftman that my brother found @ the dump that I have been bringing back from the dead and now that i have it work i want abetter one but don’t want to spend a lot.
-- Dave, I wood if I could but I can't so I woodknot
View reggiek's profile
reggiek
717 posts in 167 days
posted 78 days ago
I have a jet 10” that I use for spindles and a pen or two if I am in the mood…..It works great…and is very similar (a lot of clones have come from these as you said) and it was cheaper for the extension bed than my larger lathe so I can turn long spindles.
I bought a used Stubby many years ago…and when that no longer could get it done…I got the PM3520b (I love that lathe – but since I do alot of turning…I bit the bullet and bought it…it is not as pricey as some of the truly deluxe models, like the ones the pro’s endorse).
One thing for sure though…its not only the lathe, but the tools, the chucks and the wood for blanks that will add up (unless you have a nice free source of burls and blocks).
When it comes down to it…its the the talent of the user that makes a lathe great.
dbhost
posted 77 days ago
Even with the low dollar turning tools and chucks, there are some real gems out there. I REALLY like my Benjamin’s Best set I got from PSI, although I could use a larger roughing gouge, and the WoodRiver chuck from Woodcraft is every bit as nice as chucks costing twice as much. It grips like a Pit Bulls bite, and although a keyed chuck would have been nicer, I find I can tighten this one handed with no problem… But then again I have big hands…
