| Review by Dick, & Barb Cain | posted 757 days ago | 8855 views | 1 time favorited | 55 comments | ![]() |
- Rikon 10-325 14-Inch Deluxe Bandsaw
- Brand: Rikon | Category: Bandsaws
Second photo from Rikon
Reason for buying:
I’ve had an old 14” Taiwanese saw for quite a few years, so I looked at some reviews on Band saws, & decided this would be the one for me.
I shopped around the internet, & decided to buy it from Woodcraft. It was $750, & free shipping,
so I saved $75, enough for a few gallons of gas.
Pros:
The price fit my wallet.
It looked like a well engineered saw. when I received it, I was surprised by the heftiness of it. The cabinet,
& all of the doors, even the lower cabinet were about 14, or 15 gauge steel. About twice the thickness of my old saw. I also like the way the doors latch, with a quarter turn of a knob, & tight enough for no rattling.
The table is a nice size, & it has a well designed, & a sturdy fence, that comes with a ripping bar attachment that bolts to the fence.
I also like the geared tilting mechanism.
It comes with ball bearing blade guides.
It has plenty of power 1 1/2 HP
I think having cast iron wheels gives the saw added inertia, because of their weight.
You can re-saw 13”, without having to install riser blocks.
I recently re-sawed some 9” burly maple with no slowdown.
Specifications:
Cutting Capacity
Height 13”
Width 13-5/8”
Blade
Width 1/8” – 3/4”
Length 111”
Table
Size 16” x 21-1/2”
Left Tilt 5°
Right Tilt 45°
Groove “T” Slot (2) 3/8” x 3/4”
Height to Floor 39-1/2”
Motor
Amps 14/7
Horsepower 1-1/2 HP
Volts 115/230V
Speed Capacity 2
Speed Range 1445/2950 ft/min
Dimensions
Height 75”
Width 30”
Depth 25”
Net Weight 251 lbs
Electrical Requirements
Minimum 110 volts
60Hz
20 amp circuit.
Cons:
Poor quality manual, with lousy pictures. They told me they were going to upgrade it though.
The dust collector port was blocked with a plate welded over it. ( you can see it in my previous review).
First I drilled some holes in it, but i finally got it working right by chiseling it off.
It works fine now.
If I had to do this over again, would I buy one of these saws again?
You Bet I would.
This is a piece of 9 inch wide maple, that I re-sawed, it cut through it like butter.
This is before sanding, a nice clean cut.
THIS IS MY EARLIER REVIEW!
I just bought my machine back in March of 2007. Woodcraft had a weekend discount, plus free freight so I jumped at the deal. I saved $75, just on the freight.
I’ve had an old Taiwanese machine for many years, but I figured I owed myself a new saw, So I did a lot of research, & decided on the Rikon.
Now I have to decide on what to do with my old saw, because it still works.
The saw comes with about the lousiest manual, for such a nice piece of machinery.
The pictures are very unclear.
I called Rikon right after I got the saw, & they said they were working on a new manual.
They’ve been kind of slow about it, because I haven’t seen a new edition yet.
I haven’t had a chance to use it much yet, but the times I’ve used it, have been very favorable, meaning Man, do I ever like it.
Here’s some things I’ve found out about this machine so far.
After setting it up, the first thing that happened to me, was when I hit the start switch, nothing happened it blew out the circuit breaker. Now what? I tried a couple more times with the same results, so I called Rikon, he asked what size breaker I had. I told him 20 Amps. He told me to go to 30 Amps, because of the heavy starting load, even with the motor being rated less than 20 Amps. I change too 30 Amps, “problem solved”.
I’ve learned more about the problem I had with blowing of fuses. My shop has the old style screw in fuses,
even the Fusetron that has overload protection didn’t work for me. I bought some new screw in type circuit breakers, & a 20 amp breaker works fine now. I hope my review hasn’t caused anyone any added costs by switching to a larger circuit breaker.
Since I made this review. I’ve had a chance to test it on some projects. & I’m very satisfied with it.
I recently re-sawed some 9” Maple, & it sliced it like butter, with no blade drift whatsoever.
I had a question about the blade guide setting, I didn’t think they were right, so I did some checking, & now I use the thickness of a dollar bill for blade clearance setting,
I like the large highly finished cast iron table, & an excellent fence.
The heavy cast iron wheels run very smooth.
The inertia in the wheels allow it to coast almost 30 seconds after shutting down. That also helps with the power with heavy work loads.
The windows for tension adjustment, & centering the blade are also good features.
Blade check window.
There’s one thing I discovered with the dust collector port.
It has a steel baffle welded about 1/2” in front of the hole. It stops the air flow, & it did a poor job of sucking away the dust.
I called Rikon ,& they said it was a safety feature specified by OSHA, to prevent getting fingers in the wheel spokes.
I suggested drilling holes in the plate would allow air flow, & he agreed with me. He said he’d pass it on to his engineers.
I have completely removed this baffle since this picture was taken, & now I’m much more satisfied. .
You can’t get your fingers in the port when the pipes are connected.
I have recently attached some casters to the base of the saw, & it works fine, &
I haven’t had any problems with this set up. Check it out.
Here's a review of this tool, by Fine Woodworking.”
I f you wish to see the comments of the early review click here._ There’s some interesting comments that compliment this early review
Dick Cain
home | projects | blog
3383 posts in 520 days
55 comments so far
15086 posts in 1132 days
posted 757 days ago
“you bet I would” ... can’t top that for a thumbs up!
3781 posts in 951 days
posted 757 days ago
Hi Dick;
I guess that pretty much says it all.
I’ve come to the conclusion there is no right or wrong in some cases. It boils down to a particular unit, much like cars or even people. (some are lemons).
Grizzly is a brand I’ve seen this most often in. Some guys here swear by them and their customer service policies, while others curse both the service and the tool. Go figure!
I’m glad your’s is keeping you happy, which is the bottom line.
Dick, & Barb Cain
7210 posts in 1270 days
posted 757 days ago
Blade changing, & clearance set up is not difficult once I’ve done it a few times.
The only problem I have is trying to see through the old bifocals on the lower guides. LOL
rikkor
11329 posts in 845 days
posted 757 days ago
I have a Griz with Carter bearings. I am eminently satisfied.
mot
4900 posts in 1007 days
posted 756 days ago
Great review, Dick. Those saws aren’t available in Canuckistan, but would be up for consideration if they were.
GaryK
9820 posts in 959 days
posted 756 days ago
Nice review!
-- Gary - Never pass up the opportunity to make a mistake look like you planned it that way & "We are what we repeatedly do, excellence then is not an act, but a habit" -Aristotle
cobra3740
1 post in 716 days
posted 716 days ago
Great review on the Rikon 14”. I have the same model, also from Woodcraft. I had a Craftsman before. It worked fine but this Rikon is a real professional tool. I really love this one. The assembly and instruction manual was terrible, but they have produced a much better one that can be downloaded at http://www.rikontools.com/images/Manuals/10325.pdf
The model I have has the work light included. The only thing they could have done better in my opinion is to have an outlet mounted on the saw for the light plug, especailly since the cords were different lengths. Then I don’t need two shop receptacles. When I get some time I plan to fix this myself.
-- Cobra3740, Cudahy Wisconsin
Dick, & Barb Cain
posted 716 days ago
Thanks Cobra,
I checked out the new manual, & its much better.
Mine has the work light attached also, but lately it won’t stay in position. it keeps sagging down.
I haven’t taken the time to check how to tighten up the neck on it yet..
USCJeff
904 posts in 1039 days
posted 712 days ago
I figured I’d second Dick as I’ve had about a 6 months experience on the Rikon now. My experience is limited to a bottom shelf Lowes import, a 14” basic Grizzly w/o riser, and the Rikon. While the Girzzly did very well, the Rikon excelled. Tallest resaw w/o riser I’ve seen in the 14” category. Great factory bearings. Big table, and virtually any perk I’ve seen on any bandsaw. If hit by lighting today, would repurchase.
-- Jeff, South Carolina
iannlb
11 posts in 750 days
posted 692 days ago
I also have the Rikon 14’ Deluxe and am very pleased so far. I had some questions during initial setup that were promplty answered by tech support. In fact this has been my best experience with tech support of any of my machines. I cant wait to try a really good re-saw blade. Only to knocks: poorly machined guide bearings and the light really isn’t very useful. But plenty of power and capacity a big table and great price.
-- Iannlb
Dick, & Barb Cain
posted 692 days ago
I tried tightening the goose neck on my light the other day, & it’s almost impossible to tighten.
I think I’ll take it off , & relocate it to a more convenient place.
iannlb
posted 692 days ago
Dick,
I was thinking the same thing.
-- Iannlb
Dick, & Barb Cain
posted 692 days ago
When I get around to doing it, I’ll post a picture.
SteveKorz
2028 posts in 685 days
posted 685 days ago
I’m looking at buying this machine in a couple of weeks or so, I’m so glad you put this review on here… the “you bet I would” part sold me… Great review… thanks
Dick, & Barb Cain
posted 685 days ago
Hey Steve!
After having my Rikon for over a year now, I’ve been looking at other band saw reviews,
& have found that mine has a lot more features that I like.
I’ve learned what to look for as a comparison much better now.
Freddo
59 posts in 668 days
posted 668 days ago
I’m going to buy one of these too as soon as I have the space for it! I’ve heard that the Ittura Design sells blades to fit this saw that are awesome for resawing (up to 3/4”). They’re the same as the HH Woodslicer and can be had at the ‘not-so-common’ 111” length.
-- God bless! Freddo (Northern - NJ) Our Creator designed us to create - so use WOOD!
Dick, & Barb Cain
posted 666 days ago
I’ve discovered that the manual of any machine, is only used in the initial assembly.
After a person has his machine for awhile, the manual will sit on the shelf most of the time.
Just using your machine is the best way to get used to all of its bells, & whistles.
bake
68 posts in 648 days
posted 648 days ago
I tried to buy one of these yesterday 4/30/08 form our local Woodcraft store, they were out of stock (just sold the last one yesterday) they said they would be happy to order one, I should be able to get it sometime between mid June and mid July!
-- The only thing wrong with instant gratification is that it's not fast enough. Bake, Lehi,UT.
Dick, & Barb Cain
posted 648 days ago
Bake!
Sorry to here that, I bet you’ll be chalking off the days impatiently.
It’ll be worth the wait though.
bake
posted 648 days ago
I found one locally from another dealer and i’m on my way to get it now.
I feel much better about life already!
Dick, & Barb Cain
posted 648 days ago
Good for you, I hope your strong, because it’s pretty heavy.
bake
posted 642 days ago
Holy crap it’s heavy. I assembeled it by myself. I’d like to buy some extra blades for it any suggestions on type and brand? Also any thoughts on using a mobile base?
Dick, & Barb Cain
posted 642 days ago
I warned you that it was heavy!
GaryK swears by Woodslicer from highland hardware. I bought the 3/4 inch, & it works real good.
I don’t have a mobile base because its going to stay were I put it.
If you buy one, make sure it’ll handle all of that weight.
Have Fun!
zwwizard
62 posts in 680 days
posted 642 days ago
I have mine for about a month now, and every time that I use it I like it more. Like the rest of you I found the manual pretty bad, BUT, there is a up dated version on line, at their web site. There is some improvements coming. The light will be moved, for any thing very tall ,it is useless. I am going to add one with a magnetic base. A geared fence may be coming. That would be nice for setting up and for making adjustments. If you ever have any problems, John at their service center is a big help.
-- Richard http://www.PictureTrail.com/gallery/view?username=thewizz
Dick, & Barb Cain
posted 642 days ago
Thanks for the info about the manual, Richard.
I like mine even better after comparing with other saws.
I know what to look for now.
bake
posted 642 days ago
I finally completed the assembly and adjustments, I had a lot of trouble adjusting the fence, everytime I tighten it down it lifts off of the table. It stays square ok but I would like it to sit flat on the table. I turned it on and made some boards into toothpicks it runs real nice. Also hooked my shop vac up it seemed to work very well, I think that they have changed the plate over the opening it’s still there but it doesn’t cover the hole completley.
Dick, & Barb Cain
posted 642 days ago
Hi Bake!
Maybe your fence guide is set to low. I think it can be adjusted with the two adjusting screws.
The same ones you use for blade drift adjustment.
USCJeff
posted 634 days ago
I’ve been hearing Rikon is way behind on production of this model as well as its bigger brother. I know they bumped up the price on the mini-lathe quite a bit. Expected that though. Wins all kinds of reviews and was dirt cheap. Nice marketing strategy I suppose. Are the bandsaws to follow suit? Wish I’d got the lathe before the bump, but am glad I got the 14” BS last year before the increased demand. Starting to like Rikon’s designs.
Dick, & Barb Cain
posted 634 days ago
Hi Jeff,
Did see their new Rikon hybrid table saw?
It looks pretty cool.
SPalm
1155 posts in 853 days
posted 634 days ago
I bought one of these a couple of months ago and really like it. It is a good medium sized saw, and a good looker too. All the benefits and quality are too long to list, so I will just list my little complaints:
The light is a good idea, but is too low for any large work.
The bottom rear thrust bearing is hard for me to adjust.
Actually I wish all the blade bearings had smother adjusters.
Blade changing is not the easiest, but also not that bad.
The dust collection is not up to snuff. I have not drilled out the plate yet, or added a Y closer to the blade.
I have pinched myself several times on the door twist knobs. (Stupid, but it really hurts).
Good looking saw though,
I would recommend it.
Steve
Jon3
455 posts in 1076 days
posted 581 days ago
I just picked up one of these, and so far, your comments are spot on for my review as well.
The new manual, which is also available as a color PDF on their website, seems to have been improved significantly.
Dick, & Barb Cain
posted 581 days ago
Thanks Jon3!
I’m sure you’re going to be highly satisfied with your saw.
I’d like add to my review here:
I recently made some beveled cuts while making some post toppers on a porch railing, using my Rikon,
& it worked great.
It was sure nice using the rack, & pinion table tilt adjustment. It was much easier than my old band saw.
15140 posts in 822 days
posted 577 days ago
Great review Dick. Just goes to show there is a difference in quality out there!.
kewald
123 posts in 552 days
posted 537 days ago
I have the 18” Rikon. Love it. Gobs of power and solidly built.
-- Always do the Right Thing the Right Way the First Time - if you can figure out what that is! Ken, Spring Branch, TX
JRB
3 posts in 534 days
posted 534 days ago
I just bought the 14” Deluxe Rikon. Luckily, I was able to purchase it off the floor at our local Woodcraft store, already assembled. After getting it home, the first thing I did was change to a Timber Wolf blade the sales guy recommended. I went through the guide alignment process setting up all the guides as per the manufacturer’s instructions. Now, I’m ready to make sawdust! After running the first small plank through a resaw, it seems like it should be smoother? I am seasoned on all other types of woodworking equipment but this is my first attempt on a bandsaw and I’m not sure what quality of cut to expect. I’ve rechecked all the settings and attempted a few more cuts (I know you get better with experience) but I’m still not satisfied with my results. Any suggestions.
Dick, & Barb Cain
posted 534 days ago
Hi JRB
I haven’t looked at their latest manual, but my manual says to set the guide bearings to 1/32” on each side.
I didn’t go along with their advice, & did some research.
I set my saw using the thickness of a dollar bill, you can see the results by the cut I made on that piece of Maple.
I used this 1/2'' Wood Slicer I bought from Highland hardware.
SteveKorz
posted 534 days ago
JRB,
Dick is right… I have the same saw. Put a dollar bill between the two side guide bearings on the top and the bottom. This should help quite a bit. Also, you may want to look at what kind of blade you bought and compare that to what PS wood machines reccomends, as they have different types for different applications.
Hope this helps.
—Steve
Dick, & Barb Cain
posted 534 days ago
Checkout GaryK’s Review of Wood Slicer.
This is what led me to buying the Wood Slicer.
Lenny
182 posts in 498 days
posted 498 days ago
Hi Dick,
I just signed up so I am new to Lumberjocks. No pressure but, I purchased this Rikon 14” bandsaw essentially based on your review! Seriously though, I appreciate the extent of description and photos you provided, along with your experience (e.g., the circuit breaker issue). I picked my saw up at my local Woodcraft on Wednesday night but did not get to unpack it until today. I spent a good part of the day assembling it and still haven’t finished. I guess I am guilty of excess breaks for food and football games. I seem to be missing a couple of washers which I can replace but the table leveling nut and bolt are also missing and I will have to call Rikon for those. I have been woodworking for 30+ years but I am not the wisest when it comes to electricity. Sure, I have done my share of running wire and installing outlets but I don’t know the ins and outs of circuit loads and things like that. That’s why I want to ask about your swapping out the 20 amp circuit breaker for the 30 amp one. Am I correct that the saw is rated to run on a 20 amp circuit and 12 guage wiring but due to the surge of the starting load, it needs the 30 amp breaker? The guy in the electrical dept at HD was suggesting I need to run 10 guage wire. My guess is that typically a 30 amp circuit would require the 10 guage but since the saw specs don’t call for it, the 12 is sufficient. Are there any concerns that the breaker will not trip “when it should”, i.e., when a 20 amp breaker would? Thanks. Lenny
-- And on the eighth day God was back in His woodworking shop!
Dick, & Barb Cain
posted 498 days ago
Hi Lenny,
I’m sorry my review led you astray.
I learned something after writing my review, & I’ll have to correct it.
My shop has the old screw in fuses,
& the ones that were in my fuse box were the kind with no overload protection,
so I replaced them with 20 amp screw in breakers.
I hadn’t replaced the fuses at the time I wrote my review, & didn’t think of editing my review.
Thanks for bringing this to my attention.
I hope you haven’t bought a new circuit breaker yet, but maybe you’ve tried to see if your
20 amp one worked alright.
Again thanks for the reminder.
I know you won’t be sorry you bought this saw, because I sure love mine.
Muttray
6 posts in 443 days
posted 443 days ago
I have been shopping for a quality bandsaw via Craigslist for the last couple of months and finally gave up. All the good ones popped up while I was out of town and were gone by the time I got back home. I have gotten some good deals in the past on Craigslist on a Grizzly shaper and some other smaller tools but bandsaws must be hot items. I am working towards opening up a small cabinet shop so what I buy these days needs to be good stuff. I have also found an existing shop for sale but there are lots of factors involved there that belong in a whole ‘nother thread.
After reading reviews (including this thread) and doing lots of scheming I decided to go with the Rikon 10-325. Woodcraft tipped me over the edge when they put it on sale this month for $799. It is more than I need right now but long ago I stopped buying the minimum quality of tool that I needed at that time. I would rather spend the extra money and not be irritated every time I fire up a tool that is a piece of junk.
Anyway, I just put my new Rikon together today. I agree with most of the comments already posted. It took me about 3 hours to put it all together and get it going. The only issue I had was one of the bolts that hold the table on the trunnions stripped out with almost no force applied. I am going to contact them and see what their response is. I still have the factory blade on it so I don’t really know what the quality of the cutting is going to be yet, I am betting that it will be fine. This is my first decent bandsaw so I have lots to learn but so far so good.
If anyone is interested I can post some more thoughts as I get experience with this saw.
Thanks to all the previous posters all around this site, I have learned a lot from you all!
Matt
-- Parrotheads - We party with a purpose
Dick, & Barb Cain
posted 443 days ago
Hi Matt,
It sounds like you got a good deal, & I know you’ll be very satisfied with your new saw.
Muttray
6 posts in 443 days
posted 441 days ago
A follow up to the issue of the table bolt stripping out. I e-mailed Rikon about this problem during assembly. They e-mailed back the next morning asking me to verify if it was the bolt or the table that stripped out. Once I let them know that it was the table that stripped out they told me a new table will be sent to me today via UPS. That is pretty good customer service in my book.
Matt
Dick, & Barb Cain
posted 412 days ago
That’s very good news, Matt.
GeoffR
13 posts in 404 days
posted 404 days ago
Dick,
Thanks for the great review. I own this saw as well and was stymied by the dust collection port too, which led me to your review. What did you find was the most efficient means of removing that annoying plate?
Thanks,
Geoff
Dick, & Barb Cain
posted 395 days ago
Hi Geoff,
I’m sorry I haven’t answered you yet, but it slipped by me.
The baffle plate is only spot welded with a couple of small weld beads.
I just used a sharp cold chisel on them.
GeoffR
posted 394 days ago
Dick,
Thanks for the reply. To be certain, you were able to break the spot welds with a direct blow from a hammer to a chisel that was applied to each weld?
Dick, & Barb Cain
posted 394 days ago
Yes, it takes a few blows, but eventually breaks away.
If you can get in there with drill, & drill a row of 1/8” holes close to the weld, it may come easier.
GeoffR
posted 376 days ago
Got it off with a combination of a Dremel tool/cut-off wheel and some pounding with hammer and chisel. The dust collection does work better, but a lot of dust is still left on the table in spite of a 1400 cfm system. I will need to rig up a separate collection hose for above the table.
Thanks, Dick, for the advice.
Geoff
BVH
2 posts in 372 days
posted 372 days ago
Your review was very helpful, thank you! After a couple days researching, I seem to keep coming back to the Rikon 14 deluxe. However, most of my work is with metal, some wood. I work with solid bars of hot roll steel, maybe up to 2”x2” square tubing, lots of 1/4 and 1/8” strap. I assume it’s just a matter of getting metal cutting blades for this saw or is there something I’m missing.
EDIT: Ahhhh…..I see now. Cutting speed needs to be way down in the 1,2 maybe 300 FPM range.
-- BVH
Dick, & Barb Cain
posted 370 days ago
Hi BVH,
I’m sorry I didn’t get back to you right away, because I’ve been doing my taxes.
If I were you I’d Get a vertical metal cutting bandsaw.
The Rikon can cut metal because you can set it for a slower speed.
The only problem is, you can only cut up to 14” in length.
I did a lot of welding in my shop at work, & I had a vertical saw similar to this.
I made a lot of things with the use of it, for instance this snow groomer.
I hope this is what you wanted to know.
SCOTSMAN
2330 posts in 556 days
posted 370 days ago
Nice saw well done glad you are pleased with it I bought w very large italien saw cost me around four and a half thousand dollars ie £2300 it is simply great I dont use it every day but when I need it it’s great thanks again for showing Alistair
jcecil
38 posts in 621 days
posted 328 days ago
Does anybody have an experience with converting this bandsaw over to 220v? Mine currently is the 110v from the factory and it is quite slow starting. It is on a circuit with enough capacity but it still seems to lag a bit. I read about the 5 second delay I think in the manual or FAQ on the website but curious if anyone has gone the 220v route. And if so I am curious if there is any harm in wiring the light into a leg of the 220v? The circuit breaker I would use would be 10a and the saw pulls 7a on 220v and the light I would assume wouldn’t be too much.
Dick, & Barb Cain
posted 328 days ago
There’s a wiring diagram in your manual, mine is on page 16.
You just have to switch a couple wires around, & get a 220 volt plug.
The light should have no affect on your power.
The cast iron wheels are what causes the slow start up,
but when you shut the power off it coasts for about 30 seconds,
so be careful after you turn it off. the blade can still cut you.
Michele Maika
3 posts in 18 days
posted 18 days ago
Many thanks for informative review
Metal BandSaw
-- http://www.metalbandsaw.net
