Shop Fox Safety Issue - Be Warned
Review by becikeja posted 12-10-2016 03:15 PM 4501 views 0 times favorited 14 comments Add to Favorites Watch
Shop Fox Safety Issue - Be Warned Shop Fox Safety Issue - Be Warned Shop Fox Safety Issue - Be Warned Click the pictures to enlarge them
I have a small hobby shop and like to have my tools on mobile bases. The Shop Fox Mobile base seemed well made and strong. Assembly was simple enough, and it was easy to move into place and with a simple turn of the stabilizing screws quickly became immobilized when the bandsaw was in use. I was very happy with the product.
A couple of weeks ago I took on the task of cleaning the shop. Behind the Bandsaw I found a chunk of rubber. I could not figure out where it came from. Then I began to roll the bandsaw out and it kept sticking and was not rolling right, I gave it a quick tug and almost tipped it over. The outer rubber layer of the wheel had been coming off the underlying plastic wheel as you can see in the pictures. As I looked at the other wheels, I noticed this to be the case on 3 of the 4 wheels. In my experience with the bandsaw becoming unstable I see this as Safety concern and decided to post this review to warn my fellow woodworkers.
I contacted Shop Fox tech support a couple of weeks ago to advise them of this safety issue. Andrew C. quickly responded ”We are sorry to hear about the problem you are experiencing with your SHOP FOX ADJUSTABLE MOBILE BASE. The warranty coverage for the SHOP FOX ADJUSTABLE MOBILE BASE is valid (1) year from its date of purchase. ” Really, you’re product is literally falling apart, and risking injury to your customers and the response is a simple “Its out of warranty” You can’t make this stuff up. I just hope no one is severely injured due to the product failure and poor quality of the product. Be Warned, if you buy this product be prepared to replace the wheels in a couple years.
View becikeja's profile
becikeja
919 posts in 2928 days
14 comments so far
View Redoak49's profile (online now)
Redoak49
3450 posts in 2104 days
#1 posted 12-10-2016 06:40 PM
Thanks for the review…Will stay away from this mobile base
View NormG's profile
NormG
6226 posts in 3119 days
#2 posted 12-10-2016 09:44 PM
Ouch, I hope that the new casters costs would not be anywhere near the price of a new base
-- Norman - I never never make a mistake, I just change the design.
View Mike Hillman's profile
Mike Hillman
30 posts in 1845 days
#3 posted 12-10-2016 09:44 PM
View Greg the Cajun Wood Artist's profile
441 posts in 1058 days
#4 posted 12-10-2016 10:38 PM
Sorry to hear you got a mobile base with the defective wheels. Their response from Shop fox is not what i would have expected either.
I have four of the Shop fox mobile bases…one for my table saw, jointer. planer and bandsaw. They have been in use for almost 10 years and so far they all seem to be hoiling up as they should be.
-- Wood for projects is like a good Fart..."better when you cut it yourself"
View ChuckV's profile (online now)
ChuckV
3160 posts in 3642 days
#5 posted 12-11-2016 01:27 AM
It is not just your casters. There are many such reports out there on Amazon and elsewhere such as here:
http://www.chaski.org/homemachinist/viewtopic.php?t=101626
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View GR8HUNTER's profile
GR8HUNTER
4539 posts in 828 days
#6 posted 12-11-2016 03:35 AM
sorry to hear about your bases failing …... everything in the world is definitely made cheaper today then in years past
View JAAune's profile
JAAune
1826 posts in 2432 days
#7 posted 12-12-2016 03:21 AM
Sounds like they coated plastic wheels in rubber so they could call them rubber wheels. They ought to be solid rubber or solid plastic and not coated.
View wuddoc's profile
wuddoc
311 posts in 3833 days
#8 posted 12-12-2016 04:56 AM
I had the same problem and found I could substitute the rubber coated casters with the steel casters found on the Shop Fox / Grizzly Super-Heavy Duty mobile base.
-- Wuddoc
View ocean's profile
ocean
99 posts in 949 days
#9 posted 12-13-2016 06:25 PM
For anyone who owns a boat on a trailer, we already know that rubber coated plastic or all rubber wheels can not stand up to pressure for more than a year or less before they deform and come apart under regular use. Urethane rollers on trailers do not deform and outlast rubber/plastic rollers by many years. My boat trailer has urethane roller and they are 10 years old and have not deformed and roll like they are new (boat weights 3500 lbs.). So with that bit of knowledge, look for urethane casters. They are more expensive but worth the cost. My lumber cart weights in at 400+ pounds and moves around just fine after 8 years. Urethane is the way to go. Don’t be fooled by the colored wheels on the market that claim to be urethane. Unless they say “urethane” they aren’t.
-- Bob, FL Keys
View Ken90712's profile
Ken90712
17570 posts in 3304 days
#10 posted 12-13-2016 06:41 PM
Yep, thx for sharing I make my own. Had the same trouble.
View dmo0430's profile
dmo0430
64 posts in 1118 days
#11 posted 12-15-2016 07:43 PM
I agree with “ocean”. The first mobile base I made I had the same thing happen as OP. It was for a tablesaw though not a bandsaw so not as top heavy.
becikeja
#12 posted 12-15-2016 10:17 PM
Wow, I had no idea the problem was this far spread. They do make a nice base, it’s ashame they can’t install decent wheels.
View PRGDesigns's profile
PRGDesigns
238 posts in 2429 days
#13 posted 12-24-2016 04:44 AM
Yep, all of my Shop Fox casters delaminated, but long after the warranty period ended. The tools were mostly stationary, but with occasional movement. It’s my understanding they need to be moved frequently to avoid a pressure point developing on the casters. I expected them to last longer than they did, because changing them out is challenging. Live and learn. I’ve also converted some of my Woodcraft polyurethane casters over to steel casters due to similar delaminatibg issues.
-- They call me Mr. Silly
View WoodNDust's profile
WoodNDust
228 posts in 2221 days
#14 posted 05-05-2017 12:54 AM
Sorry to hear that your Shop Fox D2057A mobile base is not holding up for you. I bought this same base when I purchased the G1023RL table saw from Grizzly. My saw is nice. But I waited until this past week to open the mobile base as I decided to use it.
Oh my. Shame on me for waiting. Three of the four casters are unusable right out of the brand new box. Needless to say, I’m well past the 12 month warranty period. Shame on me is all I can say now.
The D2057A and the G1023RL were my first Grizzly purchases, so I was unaware. At least you got some use out of yours. I am reluctant to order anything else from Grizzly, because of the five major pieces of machinery that I ordered, I had to send back three due to either severely damaged crating or undamaged crates containing damaged goods. In all those instances, I purchased from other companies.
