| Review by Trikzter | posted 110 days ago | 540 views | 0 times favorited | 4 comments | ![]() |
- Ryobi MITER SAW QUICKSTAND™ model # A18MS01
- Brand: Ryobi | Category: Other
I bought this Ryobi Miter Saw stand a few months ago and I love it. The picture shows it set up, but the legs will fold in and you can carry it around or for storage. I don’t have enough room to have a saw set up all the time and I have to set my saw up outside to cut for now.
For the first time use, you have to attach the cross “sleds” or feet if you will, then attach the saw and the feet to the cross bars. It’s best to tilt the front towards you and then let the weight of the saw will get the back hooks on the second rail rather easily. Then just push down the black handle locking levers and the saw is on nice and solid. When you are finished, just lift up on the levers and the little feet has a built in handle, just grab the handle and tilt towards you.
On each end their is work support “rollers” (although they don’t actually roll) which can be adjusted up and down and in and further out for longer pieces. Just loosen the knobs and it can be adjusted most anywhere you need them to be located.
Bought at HD for $99.00, worth it for me. Here is the HD description:
The A18MS01 Miter saw quickstand has quick release mounting saw brackets, an integrated measuring scale. Positive stop to allow for repetitive cutting. The adjustable arm extends for added convenience. Holds up to 400 lbs. Pads allow saw to be placed on any surface.
- Accommodates most miter saws
This tough steel stand is ideal for all of your projects needs, from jobsite to home site.
Quick release mounting brackets allow you to easily mount and remove your miter saw from the stand.
Tool-less height adjustability of material supports
400 lbs holding capacity
Pads to place saw on any surface
Assembled Depth (In Inches) : 54.7 In.
Assembled Height (In Inches) : 9.1 In.
Assembled Weight (In LBS) : 55.87
Assembled Width (In Inches) : 10.8 In.
Energy Star Compliant : No
Height : 9.10 In.
Length : 54.75 In.
Weight Capacity : 400 Lbs.
Width : 10.9 In.
I have a Ryobi 12” miter saw attached to the mounting brackets, but I think the 10” Delta miter saw should easily fit it as well.
-- Rick... A tree knows more about wood then I do.
4 comments so far
dbhost
home | projects | blog
623 posts in 129 days
posted 109 days ago
Good review!
-- Trying to follow the example of the master.
17005 posts in 474 days
posted 109 days ago
Thanks for the review
Napaman
3492 posts in 974 days
posted 109 days ago
I am not sure if this is the exact model we used…but when my father in law came to help with our new shed he brought this…and the words out of his mouth: “This is just about the best thing I have ever bought.” Or something to that effect…and he builds homes…nice homes…so he has A LOT of tools…
I am not sure which miter saw he had…makita??? but I know it wasnt ryobi—-just to confirm this stand works for all types…
It was easy to make adjustments and move out roller supports…
FormerFramer
9 posts in 122 days
posted 108 days ago
When my old miter saw crapped out on me, I went to HD and bought a new one, and got this stand at the same time. My saw is a DeWalt 12”, and it works great!! Best $100 I’ve spent on tools in a long time.
-- National Sarcasm Society; Like we Need your Support
