| Review by Greg Wurst | posted 126 days ago | 1245 views | 0 times favorited | 13 comments | ![]() |
- Grizzly 18" Open End Drum Sander
- Brand: Grizzly | Category: Sanders
I finally got a chance to spend some time with the drum sander and I though I’d give you my impressions.
http://grizzly.com/products/18-1-1-2-HP-Single-Phase-Open-End-Drum-Sander/G0458
It arrived largely assembled except for the stand. It weighs a metric ton, so while I moved it and mounted it myself I’d highly recommend getting someone to help you. If you don’t have a mobile base you’re not going to be able to move this very easily.
I ran a few boards through it after resawing them on the band saw and it worked very well. It comes with 80 grit sandpaper installed, so it needs quite a bit of additional sanding afterwards to be ready to use. Replacing the sandpaper is about a 5-10 minute job assuming you have the new paper cut to the correct shape. I didn’t switch to the finer sandpaper and just put the 80 grit back on to see how it worked.
Here’s a little video of me running a piece through the sander. It was very cupped in the middle (free-handed it on the band saw as a test), which is why I had to run it through so many times:
Here's some before and after pictures of some of the pieces I ran through:
Let me summarize some of the pros, cons, and warnings:
Pros -
Noise – Very quiet. You don’t even need any hearing protection when it’s running.
Dust collection – Excellent. Hardly any dust escapes the machine.
Speed control – Adjusts from 2-12 fpm, so you can vary depending on the wood type.
Plus, it just works well and does the job it’s supposed to.
Warnings –
The 1 1/2HP motor draws 15 amps, and they recommend a 20 amp circuit. It runs ok on my 15 amp circuit, but you can’t have anything else running on that circuit. A battery charger was enough to pop the breaker.
You have to make very small passes or you’ll bog the machine. They recommend only a quarter turn, but sometimes that was possibly too much. Definitely use your planer to get you in the ballpark or you’ll be there all day.
Cons -
Belt tracking – I fiddled with it all day and could not get it to stay in the middle of the rollers. It insisted on settling to the right side. It stays there so it’s not a real huge issue, but one you should be aware of.
Paper changes – Not too horrid but definitely time consuming if you want to go through a range of grits. If I was filthy rich I’d have several of these machines with all the grits I’d need. Not a problem specific to this machine though.
A great machine and I am pleased, but I can’t give it 5 stars since I had the belt tracking issues. To me 5 stars means a product is stellar, and while this machine is very good I just can’t say it’s 5 stars good. If I could, I’d have given it 4 1/2 stars though.
13 comments so far
home | projects | blog
17211 posts in 477 days
posted 126 days ago
good review
Don K.
1095 posts in 226 days
posted 126 days ago
Excellent review…thanks for posting. This is on my wish list and will be the next large tool I bu. Thanks again for the honest review !!!!
-- Don S.E. OK
jerryz
109 posts in 179 days
posted 126 days ago
Ditto for me too
Splinterman
4935 posts in 261 days
posted 126 days ago
Nice review.
ND2ELK
6240 posts in 674 days
posted 126 days ago
Nice looking sander. Thanks for posting.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
Kindlingmaker
1479 posts in 427 days
posted 126 days ago
I too have one of these and will buy a different brand the next time. My belt also will not stay put and tracks to the right. There are no lock washers on any of the small screws on the inside and vibrations will loosen them. I had the top front sheild come off while sanding; make one heck of a sand paper shrapnel explosion. The lubracating is a pain in the bottom if you lube it as the manual says and if you don’t lube it it will start to scream at you. The return roller at the top is almost worthless even if you have someone else return your board for the next pass. The other thing with this machine is that that is no logical way of attaching extened infeed and outfeed tables to it since the tables go up and down and the head stays put. Drum sanders are great but this one could have been thought out a bit better.
poroskywood
198 posts in 264 days
posted 126 days ago
I also just got one of these. Have you had any trouble with picking up burn lines? I have. They appear randomly, The tech at grizzly told me to spray the paper with PAM cooking spray. That seemed to help but makes a mess. Also he said to run through at the 12 setting (fastest). That also seemed to help, I think it gives the piece less time heaqt things up. I do however still pick up a burn line and it really bums me out because I have to change the paper once one appears. On narrow stock I can shoot the piece in between the burn streaks, but on a wide top it’s over with. This mostly happens on 150 grit and up. Any insights? I’m 75% happy on this one. I LOVE my Grizzly planer, jointer, Table Saw so….. 3 out of 4.
-- There's many a slip betwixt a cup and a lip.--Scott
Greg Wurst
717 posts in 732 days
posted 126 days ago
I haven’t had it long enough to notice any burn lines developing on the sandpaper, but it’s something I will look-out for. I haven’t tried any of the finer grits I bought yet. Faster speeds would help mitigate it, but would reduce the sanding quality. I suspect making really shallow passes would help as well.
I’ll have to check on the screws in the machine to look for loosening during use. I can see how feed support could be an issue on long pieces. Adjusting a roller stand constantly would be a pain. For the uses I plan for this I don’t foresee many problem, but I’ll update this review as time goes-on.
20831 posts in 722 days
posted 125 days ago
Thanks for the review, Greg. I have had a drum sander on my list for some time now and have been considering this one. The info that you provided was helpful.
Kindlingmaker
posted 125 days ago
When it comes to burning, I have mine set at the fastest speed and DO take shallow passes. If a burn appears I flip the board over and do the other side at the drum burn area using even shallower passes and that mostly removes the burn from the drum paper. I also keep working the wood at different feed spot, left to right and then start over again to keep hot spots from developing. Also with the drive belt on mine it is not completely flat in that the middle is lower than outsides but close. ...and yes this machine is contantly being adjusted and tentioned. It may sound like I am a bit negative about this Grizzly but it does work for what I do right now and I just wanted to let you know what I have found with mine.
matt garcia
733 posts in 572 days
posted 125 days ago
It operates very similarly to my Jet 16-32, including the power that it requires. I have to turn the lights off in my garage, and run an extension cord from the greenhouse to my vacuum when I run mine. I also have to run it when the sun is up!! Looks like you are getting very good results from it though!! I considered this model when I was looking at a drum sander. I eventually bought the Jet because of my employee discount, the locking casters, and the infeed/outfeed table extensions. I’m going to be using mine more now that I will be veneering!!
-- Matt, Houston Texas
brunob
1476 posts in 1069 days
posted 125 days ago
I have one and don’t know how I got along without it. Regarding burns: I check my belt every few passes. As soon as it darkens in one spot, I get out the belt dresser stick. That helps slow down the burn.
Also, once you’ve done a few belt sanding drum changes, you can get it down to a couple of minutes. I get my belt sandpaper in 50’ rolls from Klingspor.
-- Bruce from Central New York
simonGee
29 posts in 183 days
posted 105 days ago
nice review
thanks
-- Simon, Illinois
