| Review by PurpLev | posted 121 days ago | 954 views | 0 times favorited | 12 comments | ![]() |
- Scheppach Tiger 2000 Wet Sharpening System
- Brand: Scheppach | Category: Sharpening Accessories
I got this used a couple of days ago. the price was right and I had wanted something that I could speed sharpening up, and get a hollow grind for freehand honing/touchups.
before getting it, I tried to gather as much information about this, as I haven’t seen too many reviews on the unit except for KnotScott’s review here, and some other reviews on Amazon (which I always take with a grain of salt). it seemed like all the reviews were raving about how good the machine is, which made me feel a little more comfortable buying it even as a used machine.
From some reviews It seemed that Grizzly is selling the same unit under their own name, but in terms of operations and all, they are identical, and so I checked on Grizzlys website, and found some references as to how to test the machine, and how to make sure the parts are in good condition. on top of that, the previous owner was kind enough to email me the user manual for the actual unit which was a big help. I also noticed that teenagewoodworker has the same unit as well, and after a PM he verified that he was pleased with it. so I set out to check the machine. when I saw it it was definitely in a “used” condition, but in an acceptable way. the wheel however seemed like it lost it’s roundness, although it had a flat face which was good. I was a bit nervous about that, especially since I never used nor seen any of these machines, but decided to take the chance, and buy it anyways. good decision!
I only had a chance to inspect the unit more thoroughly a day later. I used a dial indicator, and checked for runout. the shaft itself had a ~0.003” runout which I thought was somewhat insignificant, but the wheel had a runout of ~0.030”. I’m not sure if it’s because it’s not centered on the shaft, or because the wheel got out of round. I think I’ll have to get a diamond dressing stone to try and bring it back to normal (I’ll have to get that accessory anyways for the long run), and if not – I found that Rikon is the distributer for Scheppach in the states, and they are located a few blocks from my house… so convenient.
The Sharpening
OK, so this review is about performance… lets get to it. But let me start by a little introduction:
I am not afraid or have anything against sharpening. until today I was using the “Scary Sharp” method religiously with out a hitch and was very fond of it – it is simple, effective, and very affordable. the only “high price” item I had was the Veritas MK-II honing Jig which is terrific. I used to grind my blades on 100 grit paper, and later on started using Diamond stones (got a set on sale at rockler at one time), and then once I had achieved the desired angle, I would flip the jig to the microbevel position, and hone that on the higher grit diamond stone (600) and the 1000 and 2000 grit wet papers to get a mirror finish on the tip. of course I also lapped the back to the same mirror finish.
I was always happy with the results, and proud of my edges.
So this is what I had as a set standard to compare against.
After deciding that I’ll try out the scheppach 2000 even with the lumpy wheel, I filled the bath with water, and spun the wheel to soak some up… it soaked so much, that the water left in the bath wouldn’t reach the wheel anymore, and I had to fill the bath again. I used the plastic angle setter accessory to set a worn chisel in the straight-edge holder, and turned on the machine.
I didn’t know if this would start splashing water all around, so I was standing to the side of the machine. to my pleasant surprise, the wheel spins at a comfortable speed that water is not being splashed all around, but stays in the bath. wonderful.
I used the dresser stone to make sure the wheel was set to the lower 250 grit which took a mere couple of seconds, and started grinding the chisel against the direction of the wheel to get a more aggressive cut. after a minute or 2 I had a completely new hollow grind on the chisel, something that would have taken me a good amount of time using sand papers (to set a completely new grind on a bevel). so far, I’m pleased, impressed, but not too excited as this is what the machine is supposed to do – just glad to see it does it well.
I then used the dresser stone to set the wheel to 1000 grit (another couple of seconds) and put the chisel back against the wheel. it took several seconds to clear all the marks from the previous grind, and I could see a finer finish on the bevel, still a bit rough though but better than before.
I then swapped the support arm to the honing leather wheel side (this time positioning it to hone WITH the direction of the turning wheel as to now dig into the leather), and since the chisel is still in the straight edge holder, it is still set for the same angle – cool. I failed to apply machine oil to the leather as the instruction suggest because I didn’t have any at hand, and figured for testing only, I’ll skip it, but for future use, I will indeed condition the leather. I applied the honing paste to the wheel with a piece of wood, and turned on the machine, with circular motions using the wooden piece I spread the paste evenly across the leather strop. I then started gently and evenly pressing the tool against the leather wheel, and within about half a minute I was presented with a nice clear finished hollow bevel on the chisel.
I really enjoyed the simplicity of the entire process, it’s easy, fast, and effortless – all favored by me after a long time of really working to get good edges. however this new hollow bevel looked a bit less shiny then my scary sharp method edges. without a second thought, I put the edge to the back of my arm, and “shaved” – didn’t really see anyhing happening – in all fairness, I never really got a good shave out of my scary sharp chisels either – although they were really really sharp. I put the chisel on the table, and brushed the back of my arm with my other hand …. holy cr@p …. I’m missing some hair…. WOW.
I’m Impressed and excited. no. I don’t think I’ve ever had anything THAT sharp – and I HAVE sharp edges on all my blades. I just stood there with a smile….
now I need to explain to people at work what is this patch of hairless skin on my arm…
And this is just straight out of the machine. I’m sure the edges can be touched up even more if I so choose to. time and experiences will tell. the new honed blade cuts nicely into end grain and leaves a nice mirror finish on those as well. I cannot stress how pleased and happy I am with this purchase! touche Scheppach… why did you stop selling though? if anyone is interested – Rikon still has some, and Grizzly sells the same model and a bigger 10” version as well which is from the same manufacturer.
and the cherry on top is that since the edge is a hollow grind- touching up an edge is a simple matter, and requires no jigs since it can be done freehand – that alone is worth gold.
Thanks for reading,
Peace.
12 comments so far
home | projects | blog
25795 posts in 1293 days
posted 121 days ago
Sharon: I’m glad that you found this tool useful. I owned the Tormek and was not impressed with it. It did a good job but was too slow for me. Thats when I designed my own Sharpening station.
I sold mine to another LumberJock.
PurpLev
2732 posts in 541 days
posted 121 days ago
Karson, I was thinking about that when I purchased it – I could try and mount auxillary MDF discs next to the honing leather wheel (similar to the turning tools honing wheel accessory they sell) if the sharpener would not be enough. but I’m curious – what did you feel was missing when you were using the tormek? and how does your current setup compare to that?
16598 posts in 469 days
posted 121 days ago
Good review Sharon
acanthuscarver
156 posts in 604 days
posted 121 days ago
Just about a month or so ago I got the Grizzly version. I too think it’s a great tool. I learned to sharpen on a 60 rpm grinder and hone on oil stones. For the last 25 years I’ve been stuck grinding on a “high” speed grinder (1720 rpm). At this point I’ve gotten used to the speed with which I can grind my tools but, with students now working in my shop, it’s nice to have a grinder that doesn’t ruin chisels and plane irons with novices at the wheel. It does take a good bit more time to grind bevels but the quality of the grind is vey nice. I still hone with King stones afteward but I’m very pleased with the tool overall.
Great review with lots of good info. It’s good to find like minded sharpeners out there.
Oh, and the explaination for the hairless patches…just tell them you’re a competative swimmer. It cuts down on drag when you really get going. If you’re like most woodworkers, and you sharpen a lot, sooner or later those little arm patches will spread to other hairy appendages.
-- Chuck Bender, period furniture maker, www.acanthus.com
CessnaPilotBarry
1263 posts in 595 days
posted 121 days ago
I’ve found that an assortment of sharpening tools work best for me.
My Tormek is collocated with an 1800 RPM grinder. The grinder is used for gross reshaping and serious defect removal. The Tomek is used for typical cleanup and sharpening. I’ll often do quick freehand touchups using only the leather Tormek wheel.
Waterstones are used for tools that can’t fit on the Tormek, like scrapers, router plane blades, marking guage cutting wheels, and my marking knives. When doing hand work, I like to keep the 4000 & 8000 stones and a spritz bottle within a step or two for constant chisel touch-ups. I like DMT diamond plates best for flattening backs and truing waterstones.
It looks like the Scheppach would fit nicely into the system in place of the Tormek.
Chuck, I don’t want to know where your other hairless patches are! 8^0
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
PurpLev
posted 121 days ago
I agree Berry, I am not forgoing all my sand papers, and diamond stones – I still have scrapers, marking knifes, and for a quick touch up I’m not going to fire up a grinder. but as a main sharpening device I’m sold on this one.
I might pass on on my MK-II if I decide that it is no longer needed though.
I never used a “regular” high speed grinder, so I cannot compare or comment on that, but it seems like the Scheppach is putting a new edge rather quickly…obviously comparing it to “scary sharp” anything will be faster :)
Chuck – I don’t think they’ll buy into that one unless I sharpen ALOT more blades…lol
crankyrocker
19 posts in 504 days
posted 120 days ago
I too bought the scheppach about six months ago and was equally impressed. I have the Veritas Mk II jig too but haven’t really used it since I got the new system. All I know is that my tools are definitely sharper than they’ve ever been.
Bovine
36 posts in 220 days
posted 120 days ago
I’m curious—Is there really a difference in these similar systems? I mean Grizzly has one, Jet does too, and of course Tormek has two. I’ve been thinking of the Jet and Grizzly since the Tormek is so expensive. I’ve heard the jigs are interchangable on these systems too.
-- Kansas City, KS "Nothing is as permanent as a temporary solution"
PurpLev
posted 120 days ago
Bovine – yes there is a difference. for one, the Scheppach, Grizzly 8” and Tormek T-3 wheels are smaller and narrower than the Grizzly 10”, Jet, and Tormek which are all 10” wheels, 2” wide. second the material of the wheel is different for each brand, reviews claim that the tormek wheel keep their grit for longer between dressing, and also they can be dressed to a higher grit. Tormek also runs slower than the Scheppach and Grizzley, and the Jet has a variable speed. the Tormek and Jet motors can withstand a more constant use than the other brands. these are the main differences. how much of a real difference they make? that’s debatable.
I’m quite pleased with the “low end” model at the very affordable price – again, for me this is a huge improvement. for a shop that does sharpening 24/7 maybe this won’t be enough.
Other than that – accessories are all interchangeable between brands as far as I see except for the jointer/planer blade sharpening accessory (from reviews online).
Bovine
posted 120 days ago
Thanks Purp. I do all of my sharpening with waterstones which do a decent job. But like you, I’ve been looking to see if there was an easier way. Sorry this might have been more appropriate for the forums, but I was really interested in your review of this one. Thanks a bunch for sharing your experiences!
Don K.
1095 posts in 219 days
posted 119 days ago
Sharon,
Thanks for the review….I have been kicking around the idea of buying the Grizzly version…but was not sure if it was worth it or not, and did not want to drop $400+ for a bigger name brand one. After your review…I am going to go ahead and order the Grizzly version…thanks again.
-- Don S.E. OK
Gerry
7 posts in 133 days
posted 73 days ago
Sharon,
Your review is of great help, and thank you. I too have been looking at sharpening systems, and am attracted to the grizzly solution. One more item on the growing list…..
-- -Gerry
