Lasted <1 day
Review by PurpLev posted 122 days ago 654 views 0 times favorited 13 comments Add to Favorites Watch
Lasted <1 day No-picture-s No-picture-s Click the pictures to enlarge them
seems like I had my share of disappointing experiences with tools last couple of weeks, but I guess a bad review is more valuable than a good one as it can save the agony of others. so here goes:
I had a dewalt cordless grinder for years, and although I have very limited use for it, I find it very valuable, since when the time comes – there’s nothing else that can do that job as good. unfortunately my 18v batteries all died on me, and currently there is no justification to spend the ~$100 per battery replacement, and so I started replacing all my cordless tools with corded versions since I’m not a contractor anymore, and don’t really need the cordless abilities.
Since I do not work with metals much, I don’t really require a very powerful angle grinder, nor one with extra features such as variable speed, etc. so I figured I’ll get something simple, on the cheap, that will do that I need it to do once in a while (grinding off nails, wire brushing clean wood… thats about it). having good experience with the PC Circular Saw, and seeing that this grinder is very attractive in price (~$40 after tax) I bought it with no second thoughts.
The unit looks good out of the box, feels solid, and comfortable to hold. upon usage I noticed it was vibrating much more than my cordless dewalt did – but give the fact this one spins at 10K rpm and the cordless only at 6.5K rpm that was acceptable.
after cleaning some bowling alley slab from the protective layer of tar for reclaiming the lumber I wanted to change the used wire brush attachment with a new one is where I got stuck: the wire brush was locked tight on the thread, putting some pressure on it to release it caused the spindle lock to break. from the looks of it, the spindle lock is based on plastic parts, compared to my dewalt which incorporates a metal lock. at this point, there was no way for me to lock the spindle to remove the used wire brush attachment, and the entire machine including the wire brush on it went back to the store.
while at the store, I happened to look at the PC 18v Cordless tools, and it seems that PC utilizes lots of plastics (locking mechanisms etc) on these tools as well compared to metal parts on other brands. just thought I’d mention it here if anyone is out and about and looking to buy something like that – just keep that in mind.
definitely did not pick up another one of the same… and cannot recommend this unit to anyone else. worth spending twice as much and get the dewalt, or similar others.
Thanks for reading,
Peace.
View PurpLev's profile
PurpLev
2733 posts in 541 days
13 comments so far
3035 posts in 914 days
posted 122 days ago
Those plastic geared and fanned drills and grinders sell for about 20 bucks here. They have a place for occasional light duty. I use a drill like that ( $15.00) for sanding bowls.
I bothers me to see Brand Names liike Porter Cable trying to repackage this entry level stuff as their own.
Is there any special reason I should continue to pay them more for the name?
Sorry for your waste of time. – Shop that stuff at Harbor Freight.
7608 posts in 1111 days
posted 122 days ago
Thanks for the review.
It’s a shame that PC seems to have been in decline since being purchased by Black & Decker.
25792 posts in 1293 days
posted 122 days ago
Sharon:
I also say go to arbor Freight. Some may say they are cheap and i say that’s why I’m buying them. I’ve got the HF grinder and a Dewalt. The HF one had a plastic cover come loose. Duck tape solved the problem. The grinding end works great, and If I ended up with a power wire brush forever I’d probably still find a use for it. I can’t see buying their replacement warranty either. If I use the grinder 10 times in the two year time frame that’s probably a lot. Paying extra for two years (10 uses) seems like a waste. If I used it every day. Then probably.
16683 posts in 470 days
posted 122 days ago
Hey Sharon
I have done what karson says I bought 3 on sale and put different disc on them they work fine other than the loose head problem and they were $7.99 ea.
Craftsman on the lake
812 posts in 331 days
posted 122 days ago
In the summer I use grinders more than any other tool. I weld a lot for fun and profit and cut metal and clean up using 4” grinders. I have had so many of them. Many name brands (dewalt, makita, milwauki) right down to some $10 ones from harbor freight. Most last a summer. They cost about $60. The harbor freight ones lasted 20 minutes each. I purchased three of them at once. Last year I purchased a Craftsman one from Sears thinking that if it dies I’ll just bring it back. I ended up purchasing the extended three year warranty for about $7 thinking that I’ll kill it before that and get a new one.
The bottom line is that I’ve beat on this grinder for two years. I’ve cut a hundred cuts in angle iron and pipe and ground slag of all those welded joints that I cut. It will probably last just beyond the three year extended warranty. If it does it will have outlasted any grinder I’ve ever used.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
PurpLev
posted 122 days ago
hmmm… $7.99 for each at HF… that IS quite a deal… I just know myself, and I hate to throw away things that ‘look’ functional, or things that I ‘think’ I can use for parts… but I guess thats another option out there.
I’ll check out Sears, they have a store next to my office, I did get the wire brush from them (that completely dissolved after an hour of use…. then got a DEWALT brand one that looks like it’ll last a bit longer).
for what it’s worth – I have my cordless dewalt, and had it for more than 5 years now – I got it when it just came to the market, and it has seen some serious work in mason and lots of metal. and its still going strong, my problem is the damn batteries, last time I wanted to get a dewalt battery then needed a co-signer.
Thanks for the ideas guys, I’ll have to look into those once I figure out my next adventure in metals. for now I’ll try to manage with my cordless and a very very short runtime (5-10 min) and my Bosch Rotozip with the wheel attachment (now that is a terrific tool… should write a review on that one)
View Bret's profile
Bret
82 posts in 387 days
posted 121 days ago
What I find interesting is that DeWalt and Porter-Cable (and Delta and Oldham blades and…) are all made by Black & Decker. A guy I spoke to a Lowe’s a while back said they were repurposing all the various brands and that PC was on its way to being the replacement branding for the old Black & Decker Firestorm line. (see http://en.wikipedia.org/wiki/Black_&_Decker)
You’d think there would be less disparity between the build quality of these tools, but apparently not….
-- Bret, Colorado
PurpLev
posted 121 days ago
I understand the business plan, it’s not like B&D is “making” all the tools, they just control the factories that make them financially. you can look at the different “brands” like different product lines from a “single” brand, aka “entry level”/”prosumer level”/”pro level”.
but all that is political talk, I’m more concerned with the end product and how well it performs be it black/yellow/red/blue/polkadot orange. and this one didn’t quite stand up to it.
View MedicKen's profile
MedicKen
457 posts in 355 days
posted 121 days ago
I picked up a Bosch set from HD a few months ago. It was a twin pack for $99. I dont know if they still have it, you might look into it. The Bosch has worked well and I havent had an issue….
View reggiek's profile
reggiek
705 posts in 163 days
posted 121 days ago
I’ve had my makita grinder for several years. It has lasted through quite a bit…including grinding concrete, metal, wood, plastic and some acrylic. I got it at a tool show for about $40…don’t know what they cost these days…but then I haven’t had to look for another.
I quit buying PC after their sale as I had heard they were using cheap foreign parts and had gone to a less or “inexpensive” format….(sad as my great PC biscuit jointer is starting to show its age – I don’t think I will replace it with a PC). It’s annoying to me that some of these manufacturers that had a very good rugged product have gone that route. It also worries me when I need to make a purchase that the product I have relied on and expect to continue the same quality is now a cheaply made piece of @*^+.
View GaryCN's profile
GaryCN
175 posts in 827 days
posted 119 days ago
I have a Hilti HG450 corded that has lasted for years, I’m not sure what I paid for it but I’m sure that it was over $100
-- Quando Omni Flunkus Moritati
View kosta's profile
kosta
371 posts in 247 days
posted 113 days ago
you know that dewalt and porter cable are both owned by black and decker that might be why
-- kosta brownsville brooklyn my home
PurpLev
posted 112 days ago
not quite Kosta- the Dewalt that I have (and it’s a cordless one) is superb! – I just ran out of batteries, but the tool itself is class-A.
on a side note – we just got the Bosch set of 2 grinders, they are smaller, but for my needs more than enough. so far all my Bosch tools have been top notch and their service is second to none.
