Great & Quiet Portable Belt Drive Compressor
Review by Cato posted 126 days ago 610 views 0 times favorited 7 comments Add to Favorites Watch
Great & Quiet Portable Belt Drive Compressor No-picture-s No-picture-s Click the pictures to enlarge them
When I discovered that my loud old direct drive unit would not supply enough air to run my new framing nailer I started searching for a portable belt drive replacement with a 4 or higher CFM @ 90 PSI, which is supposed to be adequate for framers. I wanted a belt drive because I knew they were quieter, and I couldn’t stand the noise of my old one.
I searched on the web and found this compressor to be highly rated by contractors, and it was supposed to be very quiet with plenty of power to run framing nailers.
Boy have I been pleased as punch with this unit. I had seen in it my local Lowe’s but assumed it was another loud direct drive. Wrong, went on the DeWalt web site and found that it was a oiless portable belt drive, with low 1750 rpm speed,78dB noise factor, 1.8 hp and 5.2 CFM @100 PSI, and an unusually high PSI of 200.
Since it was a bit pricey but what I needed I took advantage of a 10% discount Lowe’s was running at the time on nailing compressors and bought it. Good move
Got it home and opening the box the unit was completely assembled and ready to go. My only additions were getting a couple of new sections of air line, and a 25ft. section of heavy duty extension cord.
Turning it on in the shop I was immediately pleased. It quietly chugs along and reaches 200 PSI in about a minute. Top regulated pressure is 140 PSI which is plenty for any tool I am aware of. The cool thing is that the compressor cuts back on when tank drops to 160 PSI. It has two air outlet ports, easy to read 2 inch dials and a large lockable regulator valve. As you can see from the pic it has a roll cage, foam filled no flat tires, and underneath the tank a ball valve drain cock.
Power to spare and then some!! I’ve been framing a shed and at about 92-95 PSI, I can counter sink 3 1/2 inch 16D nails and flush them toe nailing. No stair stepping, no recovery, just plenty of air!! Wonderful.
Dropping back slightly to 90 PSI and a small adjustment to my depth of drive on the framer I can counter sink 8D nails and flush 10D 3 inch.
The nice thing when you are through is that the unit stores vertical flat against the wall, which is a big space saver. The handle extends for transport or collapses back into the unit. I leave mine extended and wrap the extension cord and two 50ft. sections of hose on it. Nice neat and tidy.
I highly recommend this compressor.
View Cato's profile
Cato
138 posts in 207 days
7 comments so far
20668 posts in 717 days
posted 126 days ago
Thanks for the revew, Cato. I am a fan of Dewalt tools and this one looks pretty good.
16841 posts in 472 days
posted 126 days ago
Good review I have tons of dewalt tools.
25801 posts in 1295 days
posted 126 days ago
Nice review.
View PurpLev's profile
PurpLev
2752 posts in 543 days
posted 126 days ago
nice review. I have their smaller compressor. It’s mostly for small jobs, since it takes a while to recover, and needs it very often, but for my 18g nailing applications it’s quite enough. I like the 2 port built-in. not many compressors have that out of the box.
View Don K.'s profile
Don K.
1095 posts in 221 days
posted 126 days ago
Nice review…thanks.
-- Don S.E. OK
View pitchnsplinters's profile
pitchnsplinters
252 posts in 333 days
posted 126 days ago
Makita MAC2400
-- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits.
View Rog's profile
Rog
51 posts in 653 days
posted 124 days ago
Great review and as luck would have it I have Dewalt tools too and have found them to be just the ticket for me. I did buy one craftsman air compressor which is loud and has only enough air to run a brad nailer, stapler and pump up tires. When I buy my next compressor it will be the Dewalt D55146 for the same reason you bought it. Thanks for the great review.
-- Feel the wood and let it tell you what to make of it.
