LED Shop Light
Review by Jim Jakosh posted 09-10-2016 05:42 PM 8055 views 3 times favorited 25 comments Add to Favorites Watch
LED Shop Light LED Shop Light LED Shop Light Click the pictures to enlarge them
I have often wanted to replace my 4ft- dual florescent light fixtures with LED lights but they have been too expensive everywhere- until now. The florescent ones come on real low when it is cold and the bulbs seem to burn out a lot and some of them hum.
During Menards Labor Day sale these 4’ Smart Electrician LED lights were on sale for $14.88 after rebate. I have been using them for about a week and I can’t believe the difference over the old lights. It seems like I’m in a different shop with all the light.
The are cool white (4000K), they have a 5’ cord with a plug and a pull switch with a chain and the housing is aluminum. The use 45 watts which is about half of the old ones.
They make a 4200 lumen one too and I’d have to wear sun glasses with them, I think!
Next time they are on sale, I’ll get 10 more to replace all the old ones!
Cheers, Jim
View Jim Jakosh's profile
Jim Jakosh
21967 posts in 3344 days
25 comments so far
View Joe Lyddon's profile
Joe Lyddon
10372 posts in 4291 days
#1 posted 09-10-2016 05:46 PM
That is a GOOD price!
View doubleDD's profile
doubleDD
8045 posts in 2282 days
#2 posted 09-10-2016 07:15 PM
Jim, I wish I would of seen that sale and I was at Menards Saturday. I bought a Honeywell 4500 lumen one at Sam’s club a couple months ago and can’t believe the difference. I installed it by the washer and dryer and my wife said it was too bright. So I put it over the workbench. Wow! I’ve been looking for a good sale but I guess not close enough.
View lew's profile
lew
12509 posts in 3994 days
#3 posted 09-10-2016 08:45 PM
I really need to replace my old florescent fixtures. I have two 8’ lights and a couple of 4’. The 8’ are still quite expensive. May do a set of 4s when they go.
I was subbing at school the other day and students from the Electrical trades were replacing the florescent tube with LEDs. These tubes didn’t even require disconnecting the ballast. They just swapped them out!
Jim Jakosh
#4 posted 09-10-2016 10:57 PM
Hi Dave. Our Menards was almost as busy as black Friday for 3 days of that sale. they also had 2 60watt equiv LED bulbs for 1.88 – no rebate. I usually pay $5 to $8 for them. I loaded up! I’m sure they have them again..
Hi Lew. I have never see LED tubes that go right into a fluorescent fixture. I wonder how many watts they would take? I have some humming ballasts so I’m glad to be rid of them. These things hit me with the same impact like the first time I used Shark Bite fittings for plumbing..WOW was the word.
Cheers, Jim
19619 posts in 2095 days
#5 posted 09-10-2016 11:06 PM
I have bought and installed at the firehouse some led replacement for T8 fluorescent. They could either be used with the ballast or disconnect the ballast and wire straight thru. They are not as efficient if you leave the ballast in. The ballast gets warm and therefore wastes energy.
View Bob Collins's profile
Bob Collins
2608 posts in 3923 days
#6 posted 09-10-2016 11:27 PM
Good idea Jim, I have fluorescent but could do with something brighter.
-- Bob C, Australia. Your best teacher is your last mistake.
24823 posts in 4090 days
#7 posted 09-11-2016 12:32 AM
Bright idea Jim (excuse the pun). I expect they will be much cheaper to run.
View michelletwo's profile
michelletwo
2773 posts in 3254 days
#8 posted 09-11-2016 10:26 AM
thanks for the info Jim..now I know what to look for …it’s getting harder and harder to see as I get older & older :-(
Jim Jakosh
#9 posted 09-11-2016 10:55 AM
Hi Bill, I don’t know how the same bulb would work with or without a ballast, but with electronics, they can work miracles!!
Hi Tony, they are about half the power and much more illumination form that one bulb!! I have two of those bent tube fluorescence light over the end of my shop and that is 4 bulbs burning when I turn that on. I’ll save 75% there.
Hi Michelle, I’m with you on things getting harder to see. These light really brighten the whole shop up and the seem to spread light sideways better than the fluorescents.
Cheers, Jim
View Blackie_'s profile
Blackie_
4883 posts in 2751 days
#10 posted 09-11-2016 12:03 PM
Great Jim. When I did my shop redo year before last, I removed and replaced all fluorescent lighting with recessed LED lighting through out the shop raising my ceiling, reducing electricity cost and removing the changing out of light bulbs.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
View splintergroup's profile
splintergroup
2511 posts in 1461 days
#11 posted 09-11-2016 02:43 PM
My shop lights are the 4-tube (4 foot) troffers, I have them wired so each pair of tubes are on a separate switch.
I decided to replace on pair in each fixture with LEDs (ballasts are bypassed). Technically the LEDs are the same brightness, but all the light is focused downwards instead of using the reflector as with the fluorescents. The net effect is noticeably brighter!
Even though the efficiency is about the same as the fluorescents, having the lights full brightness when the power is first turned on, no problems with cold temps, and none of that infernal humming, they are bliss! At $9 (delivered) per tube, the price was tolerable as well (they are now down to $6.50 at earthleds.com).
A fully recommended upgrade.
Jim Jakosh
#12 posted 09-11-2016 08:22 PM
Hi Randy, I’m right behind you on that. it is my plan for the future!!
Hi splintergroup. Thanks for the lead on those bulbs. I’ll bet others can use them too!!
Cheers, Jim
View Cliff 's profile
Cliff
1381 posts in 1963 days
#13 posted 09-12-2016 12:22 PM
Yes, Leds are the way to go….I will be looking into them in the future.
Cliff.
-- Cliff Australia : Snoring is good. It blows away all the Sawdust.
View roofner's profile
roofner
130 posts in 2522 days
#14 posted 09-13-2016 03:47 AM
Earth leds are about 10 and free shipping and tax free. They are much brighter and no flicker. You do have to rewire and remove balist not hard to do. I think they are 400 lumens. No more worry of balast burning out.
View marcsitkin's profile
marcsitkin
28 posts in 996 days
#15 posted 09-13-2016 08:53 AM
I just picked up some 4 foot LED’s from BJ’s this week, for about $18 each. They have made a huge difference in my shop. It’s like having sunlight in the basement. Love them!
-- Thanks, Marc Sitkin, Harwich, MA
showing 1 through 15 of 25 comments
