Two bad welds in a row
Review by ColonelTravis posted 08-27-2016 01:32 AM 2982 views 0 times favorited 10 comments Add to Favorites Watch
Two bad welds in a row No-picture-s No-picture-s Click the pictures to enlarge them
Not gonna buy a Timberwolf blade again. It took me hours to figure out I had a bad weld the first time, wasn’t sure what the problem was. After putting it on the floor, you can see it doesn’t lay evenly all around. Its replacement also had a bad weld. I’ve read others who’ve said this wasn’t uncommon with TW. Maybe the wolf mascot is biting the blade too hard.
The problem blades were resaw blades. I have two other smaller ones from TW that cut fine. But two duds in a row and knowing I’m not the only one who’s had this problem is enough to stop buying from them.
Ordered a 3/4” Wood Slicer from Highland, which cuts perfectly.
View ColonelTravis's profile
ColonelTravis
1953 posts in 2133 days
10 comments so far
View ArtMann's profile
ArtMann
1218 posts in 1055 days
#1 posted 08-27-2016 03:01 PM
Both I and a friend of mine had the same experience with Timberwolf resaw blades several years ago, so I switched to Woodslicers. Sometime after I switched, word got around that Timberwolf had fixed their manufacturing problem but I guess it has popped up again.
View SenecaWoodArt's profile
SenecaWoodArt
443 posts in 1858 days
#2 posted 08-27-2016 08:22 PM
I have found the same issue with Timber Wolf. They are no longer on my list. Jim Finn turned me on to SupeCut. They are very easy to work with. Prices are reasonable and I have not had a failure in the six months that I have been using them. My smaller Timber Wolf blades have given me the same issue. I would blame it on the saw or the operator, but the SuperCuts are being used on the same saw by the same operator without the issues. When my last Timber Wolf goes, I won’t waste any more money on them.
-- Bob
ColonelTravis
#3 posted 08-28-2016 01:19 AM
Bob thanks. Just checked out the SuperCuts page, which bandsaw blade have you tried? They had several different types.
View theoldfart's profile
theoldfart
10300 posts in 2690 days
#4 posted 08-28-2016 02:19 PM
I had two bad TW resaw blades, both at the weld. Woodcraft took them back and I switched to a WoodSclicer from Highland. So far no problems. Timber Wolf has an un even reputation quality wise so I will steer clear of them. My saw is a PM 14” w/a riser block.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
SenecaWoodArt
#5 posted 08-28-2016 03:40 PM
- ColonelTravis
I am using the Gold Premium Carbide Blades. I have bought the 1/2”, 3/8” and the 1/4”. They have all performed well for me. It pays to order several at a time as they charge a basic $9.75 for shipping unless you spend somewhere around a $100 and then shipping is free.
-- Bob
ColonelTravis
#6 posted 08-28-2016 08:35 PM
gotcha, thanks
View MrRon's profile
MrRon
5270 posts in 3482 days
#7 posted 08-31-2016 06:01 PM
I use Starrett blades. Their welds are so good you can’t see where they were joined. They don’t cost much more than TW blades. Their woodworking blades are sold under the name “Woodpecker”
View Grumpymike's profile
Grumpymike
2355 posts in 2554 days
#8 posted 09-01-2016 08:16 PM
Thanks for the heads up on these blades … The one on my saw is ok, but I checked two others (still in the box) and sure enough, they are not straight … Back to the store with them tomorrow.
Just as a side note, I had a blade about a year ago that mushroomed on the back or trailing edge … couldn’t get that thing to cut straight, wandered all over the place … As I was installing the new blade I noticed the flair on the back edge … After checking al the bearings and rollers as well as the blade path, nothing was found to be awry.
I do not remember what brand name the blade was, but that problem has never happened again. All blades just ‘ain’t’ the same.
I do a lot of re-sawing and keep a 3/4” 3TPI in my 14” band saw, and a 1/4” blade in the little band saw for general use.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
View fivecodys's profile
fivecodys
1272 posts in 1875 days
#9 posted 09-05-2016 08:56 PM
I ordered a timber-wolf resaw blade about 4 months ago. It was still i the box when I read your post. I must be one of the lucky ones. I just came in from the shop and I am happy to report that mine seems to be ok.
Thank you for your post and for the options for other brands.
-- I always knew I would grow old, But I expected it to take longer!
View bobasaurus's profile
bobasaurus
3549 posts in 3423 days
#10 posted 06-01-2017 06:17 AM
My timber wolf resaw blade broke at the weld this evening. Disappointing.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
