Rousseau 5000 L: finally, some real dust collection for a miter saw
Review by mzimmers posted 08-25-2016 09:05 PM 6194 views 0 times favorited 13 comments Add to Favorites Watch
Rousseau 5000 L: finally, some real dust collection for a miter saw No-picture-s No-picture-s Click the pictures to enlarge them
I really, really like my miter saw. It’s one of my favorite tools. But there’s no disputing the mess it makes: despite my efforts at locating vacuum or dust collection hoses near the saw blade, chips and dust generally ended up everywhere. This is especially aggravating in my hopelessly overcrowded work area, where clean-up isn’t always easy. Enter the 5000 L to the rescue.
Rousseau Co. has been in business longer than I’ve been in woodworking. Located in remote Clarkston, WA, they produce very high quality woodworking accessories. Most of their products have been of the table/stand variety, but recently they introduced the 5000 dust hood. Careful attention to customer feedback prompted Rousseau to add some much needed lighting on their new model, the 5000 L.
A few words about the hood itself: it’s essentially a cloth canopy over a metal skeleton, with elastic to pull in the canopy’s top and bottom. Like other Rousseau products I’ve owned, it’s made of high quality materials. In the case of the 5000 L, the cloth is a ballistic nylon, and the hardware is heavy steel. The hood is admittedly rather bulky, so plan on using up some space behind your miter saw. It’s intended to be large enough to fit most miter saws, and it easily accommodates my Bosch GCM12SD, a 12” monster of a dual-bevel glide saw. I was able to move the saw to all angle limits without the hood interfering.
A 4” dust port is located center back.
The lighting is a very nice touch. One of the more annoying aspects of miter saws, especially the larger ones, is that they tend to cast a shadow on themselves, right at the point where the cutting occurs. The wraparound LED lighting of the 5000 L does much to obviate this problem. I wouldn’t have minded if the lighting came down lower a few inches on both sides, but as it is, it’s more than adequate and worlds better than nothing at all.
Installation is straightforward and easy. I experimented with several options, so it took me about 90 minutes total to get the hood properly installed. Those who are less, er, “creative minded” will get it done in half that time. The only tools required are a drill with a 5/16” bit and a couple of 1/2” wrenches. Rousseau encourages you to situate the hood so that the hood face is co-planer with your saw fence. Height is flexible, though it would seem that lower is better. As you can see from my picture, I located the hood so that it clears my upper fences by about 1/4”.
I took a bunch of pictures of the hood installed, but after looking at them, I decided they didn’t really tell you anything that you can’t learn from Rousseau’s site, so I skipped them. I decided to include two photos that are not of the 5000 L, though, because I think these speak volumes.
In testing the hood, I made the following cuts in one session:
1. three cuts into rough walnut (about 2” by 4”)
2. several cuts into 1” by 4” hemlock
3. two cuts into 9” of 5/8” particle board
Ordinarily, this much cutting would leave me ankle-deep in dust. This picture is of the back of the shelf that’s about 8” below the saw:
And this picture is of the floor immediately in front of the saw (the floor paint is speckled):
I cannot emphasize too strongly what a difference this is. The shelf would have had enough dust to write my name in, and the floor would have been some shade of brown instead of blue. Besides the visual evidence, I felt less debris hitting my hand and arm during sawing, and the air around me just “felt” cleaner.
In short, the Rousseau 5000 L is attractive, durable, and works like dynamite. The lighting probably also makes your miter saw a bit safer to use. This is a highly recommended accessory for anyone who uses a miter saw on a regular basis.
-- M. Zimmers
View mzimmers's profile
mzimmers
202 posts in 4062 days
13 comments so far
View smitdog's profile
smitdog
404 posts in 2252 days
#1 posted 08-26-2016 01:37 PM
Very interesting! Seen several homemade hoods but not a commercial option as of yet. The proof is in the photos, if the floor isn’t covered then it’s a drastic improvement!
-- Jarrett - Mount Vernon, Ohio
View pintodeluxe's profile
pintodeluxe
5757 posts in 2960 days
#2 posted 08-26-2016 03:42 PM
I have a similar shop-made nylon enclosure for my miter saw. So you run yours with a 4” DC hose attached to the bottom of the bag, and no other hose connected to the saw, correct?
mzimmers
#3 posted 08-26-2016 05:15 PM
- pintodeluxe
Correct—the 5000 L has a single 4” port located center, back, and bottom. Some chips settle on the inside of the hood, but I for one don’t care about that.
-- M. Zimmers
View Redive's profile
Redive
1 post in 785 days
#4 posted 08-26-2016 05:55 PM
Thanks for the review. Very clear and informative.
View jimintx's profile
jimintx
834 posts in 1731 days
#5 posted 08-26-2016 09:42 PM
I can attest that this ought to work as discussed herein.
I made a comparable hood for my 12’ Bosch, using only cardboard boxes and some package tape. I also attached a 4” hose from my large dust collector. In my case, because it fit into my layout best, I attached the vac hose to the right side of the corrugated cardboard box.
I then rotate the dust collection, L-fitting that comes standard on the saw, so it is aimed to the right.
This setup archives results as are described here for the Rousseau hood.
One of these days, I may take an afternoon to re-make it using plywood and sheet acrylic.
-- Jim, Houston, TX
View Harry's profile
Harry
80 posts in 1326 days
#6 posted 08-27-2016 12:48 AM
Nice review. I have a 5000 that I got about 2-3 months ago but no lights. Sure is nice not to fight with the cardboard I had forever and worth every penny. I had to clamp some extra fabric near the dust port so it wouldn’t suck in but no big deal.
-- Harry - Professional amateur
View Grumpymike's profile
Grumpymike
2310 posts in 2462 days
#7 posted 09-01-2016 08:40 PM
Thanks for the very in depth review; Dust is always a problem with the miter saw … I have a large plastic tub that I put a dust port into and use that. On it’s best day, it catches about 2/3 of the dust.
The one thing you did not mention is how spendy the 5000L is, but I will look on the web site for that info.
We could do a whole blog on the Rube Goldberg contraptions we have made for the compound miter saws, that we love so well, to catch the dust.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
mzimmers
#8 posted 09-02-2016 02:34 PM
Hi, Mike – I didn’t include that because I didn’t have that information. This product is brand spanking new. The proprietor of Rousseau expected the 5000 L to be on a few online sites by now, but I’m not sure that’s happened. The 5000 (without the lights) is $150, so expect it to be modestly above that.
-- M. Zimmers
mzimmers
#9 posted 09-02-2016 03:45 PM
Price information: I just heard back from Dale—MSRP for the 5000 L is $169, or $20 more than the version without the lights.
-- M. Zimmers
jimintx
#10 posted 09-02-2016 03:48 PM
Well, it is sure correct that Miter saws are messy contraptions.
My collection box won’t score very high on the Rube Goldberg scale. Its just a box with a hose attachment flange. Simply turning the on-board, original equipment, exhaust nozzle so it points at the side mounted vacuum dust collector port made a huge improvement in this box style collector.
I fitted my box to the saw so that it is within 1/4 inch of the very back-most part of the saw, and up against the wall behind it. I specifically did not want anything that added to the depth of the saw from the wall. I have the saw sitting on a counter bench, essentially against the wall.
I spent the money on the Bosch so I could eliminate the rods, or anything else, that extend behind a lot of more conventional design saws. The goal was zero (minimum) clearance behind the saw. I bought this saw to replace my ancient Craftsman radial are saw, and am very happy I did that.
I looked at these type of fabric style, tent hoods, and I think they would work great. But all of them were intended to work on the saw when sitting on a stand away from the wall, and with adequate space behind the saw for the hood to occupy. I do not have that space available.
I have work task spotlights here and there in the shop, several of which are LEDs. I have employed that method to add lighting to the miter saw cut line and blade.
-- Jim, Houston, TX
View Gene Howe's profile
Gene Howe
10905 posts in 3575 days
#11 posted 09-02-2016 04:21 PM
DARN!!!
Just last week I installed a ChopShop hood from Fastcap. It does the job quit adequately. Much better than the tub like mentioned earlier. But, for a bit more, I coulda had one with a DC connection and a light.
View Fallon's profile
Fallon
91 posts in 3274 days
#12 posted 09-08-2016 08:12 PM
How much does it run?
Nevermind… $150 https://www.amazon.com/dp/B00MFGRT06/
mzimmers
#13 posted 09-09-2016 03:14 PM
- Fallon
$150 is the price for the 5000 (without the LED lights). The 5000 L is $170.
-- M. Zimmers
