It lives up to the hype
Review by Charlie H. posted 08-20-2016 10:51 PM 4000 views 1 time favorited 16 comments Add to Favorites Watch
It lives up to the hype No-picture-s No-picture-s Click the pictures to enlarge them
I have been using Freud blades on my table saw and miter saw and have been well satisfied.
The cuts on the table saw had become less than smooth so it was time to either get the blade sharpened and tuned up or to replace it.
Like most hobbyists I read about how great the Forrest blades are and I guess I have been yearning to try one out.
As it turns out over the past day or two I have been spending money like crazy on my woodworking tools and I guess I must have crossed the just get what I want threshold.
So I headed out to Woodcraft and talked to the guys there about the Forrest blades.
I had intended to get the 48 tooth thin kerf blade but after some good conversation they convinced me to get the WW10401125 box joint blade.
It is a 10”, 40 tooth blade, 1/8” kerf, alternate flat teeth #1 grind and I paid $149.99 + tax.
Well I bolted this bad boy onto the saw as soon as I got home and tried it out on a piece of 6” wide X 1” thick ash.
I cut off about 1’ and trimmed the other end, then I ripped about 1” off the edge.
It was almost like the blade was eating the wood, hardly ant effort was required to push through.
The cuts are absolutely terrific.
There was no tear out on the cross cuts and the end grain is so smooth that it rivals the miter saw cuts with the 80 tooth Freud blade.
Even though the rip cut was only a foot long the cut edge on both pieces is as close to perfect as it gets.
$150 is a bunch of money to pay for a blade but I am glad to have it on my saw and I am looking forward to using it for years to come.
-- Regards, Charlie in Rowlett, TX --------I talk to myself, because sometimes I need expert advice.---------
View Charlie H.'s profile
Charlie H.
323 posts in 891 days
16 comments so far
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#1 posted 08-20-2016 11:35 PM
I’ve had a 40t ww2 for over a year and a half and it still cuts like a champ.
View Andre's profile
Andre
2373 posts in 2047 days
#2 posted 08-21-2016 06:07 AM
Yu, keep it clean and it just keeps cutting perfect! I did pick up there Forrest Finger Joint Set which also perform incredible!
View ScottKaye's profile
ScottKaye
718 posts in 2194 days
#3 posted 08-22-2016 08:36 PM
why did they recommend the box joint blade over the regular 40th WW II blade?
-- "Nothing happens until you build it"
Charlie H.
#4 posted 08-25-2016 03:02 AM
They told me they used the blade on all of the table saws they teach classes on and it produced very good quality cross cuts and rips in addition to the flat bottom for non through cuts.
They thought it worked very well as a general purpose blade.
At this time my primary woodworking interest is small box building so a combination of short cross cuts and rips on the usual jewelry box woods is what I will be using it for.
I really don’t know if I will be needing the flat bottom cut capability of the blade.
I have been using my router to do those cuts.
The blade is still brand new to me and the only cuts I have made were just to try it out.
I think it makes a very clean and smooth edge.
Only time will tell if I would be better served with the other blade.
View splintergroup's profile
splintergroup
2515 posts in 1463 days
#5 posted 08-25-2016 05:03 PM
I’m a big WWII fan, started with a 40T and added a 48T. Excellent buys when on sale. I still have a triple set of Freuds (80T crosscut, rip, and combo) which also see a lot of use.
View Boxguy's profile
Boxguy
2779 posts in 2508 days
#6 posted 08-28-2016 08:24 AM
I use Forrest blades on all four of the table saws in my shop and on both of the chop saws. Some saws are set up with dado blades and one is set up with a flat ground blade for cutting corner splines in boxes. The idea is that I can cut a 1/8, 1/4, 1/2, flat bottomed dado with no set up time. It really speeds up my box making since I am set up for installing bottom boards, corner splines, or tops with no set up time.
These are two Craftsman table saws that I bought off Craig’s list, reconditioned, and yoked together then added a Shop Fox fence. One is set up for 1/2 inch plywood the other cuts a flat bottomed 1/8 inch cut.
The yoked saws also serve as the off-bearing table for my Unisaw that I use for all my general work of sizing scraps and boards.
The Forrest blades are expensive, but they pay for themselves in the long run with clean cuts, and they stay sharp much longer than other blades.
-- Big Al in IN
Charlie H.
#7 posted 09-02-2016 11:33 AM
I admire your setup Boxguy.
View DQuigley's profile
DQuigley
5 posts in 869 days
#8 posted 09-08-2016 11:42 PM
I just bought the 48 tooth WWII and also believe it was money well spent. Noticeably quieter and as smooth a cut as you could hope for.
Charlie H.
#9 posted 09-18-2016 02:57 AM
You know I initially posted after making a few cuts in ash, since then I have used the blade to cut padauk and maple.
I am not nearly as satisfied as I thought I was.
Particularly on the maple I get burning on rip cuts and on cross cuts there is always a fuzzy edge.
I know this blade says it is a box blade and it may very well excel at cutting shallow slots and possibly finger joints but at this time I think I would have been much better served with the regular WWII 40 tooth blade.
Since this purchase I have bought one of the Freud glue line ripping blades and it cuts the maple without burning it.
Boxguy
#10 posted 09-18-2016 08:09 AM
Charlie, When I cut woods like pakuk my blades get a coating of sap on them. This sap heats up the blade as it cuts and gives me the same results you are talking about. I have to soak them in 409 Cleaner over night and use a brass brush to clean the gunk off the blades.
Forrest blades are an investment, but I still think they are worth it. I agree that you would be more pleased with a blade with more teeth. As I understand it, the box blade is made primarily for cutting dados and box joints. I don’t think it was designed to work as a single blade. It is too wide and has fewer teeth. Sounds like the guys at Woodcraft heard the word “boxes” and sold you a blade designed to cut box joints. Keep boxing and keep posting.
-- Big Al in IN
splintergroup
#11 posted 09-18-2016 03:08 PM
I use both Forrest (40T & 48T WWIIs) and a packaged set of 3 Freud blades (FTG rip, combo, and 80T CC). They all serve me very well ( I haven’t used the Freud CC yet).
The Forrest blades are spend, but once or twice a year they go on sale at various vendors, a bit over $90 for the 40T WWII and about $100 for the 48 (free shipping usually).
The WWIIs ave a very shallow side grind which helps them get the glass smooth crosscuts. This has the side effect of them loading up with grunge quicker so keeping the teeth clean really helps over the long term.
Charlie H.
#12 posted 09-19-2016 01:58 AM
Thanks, the WWII blade does look like there is a little bit of black behind and below the teeth.
I will get the brass brush and cleaner after it and see if it comes off.
The Woodcraft guy probably did get side tracked by ‘box’ because they had several different blades in the cabinet and I was going to buy one regardless.
Just as much on me too though, I asked for the standard blade and allowed the diversion to the box blade.
It is not the end of the world.
Will probably stick with the Freud blades ordered from Amazon from here on out, I have been well satisfied with them and there must be a tool warehouse nearby because most of them are free prime same day delivery.
View David 's profile
David
13 posts in 685 days
#13 posted 03-12-2017 02:02 AM
This is an older post…. but as of March, 2017, I probably own 6 of these 40T Forrest WW2 blades. I have both the thin kerf and regular kerf. They all cost between 90~110 each. If you have a 3hp saw or bigger I would recommend the full kerf version because it’s just got a lot more carbon tooth. If you have a contractor size saw then the thin kerf takes a little bit less hp to cut.
The other thing is unless you have a REALLY GREAT (and I mean a real top notch sharpener) just send your blades back to Forrest for sharpening. You’ll get it back as good as brand new. The caliber of their sharpening equipment (I spend a good deal of phone time with the guy that runs the machine) is not something you are likely to find elsewhere. One more final thought: BEFORE you send any blade out for resharpening…learn how to clean the pitch and whatever off of your blades. Back in the day before I learned this trick… I suspect I sent in a few blades that didn’t need a sharpening…but just needed cleaned up! (I shouldn’t admit this)
Charlie H.
#14 posted 10-01-2017 03:15 PM
Hi again,
After owning the box blade for a decent amount of time I thought I would make one more follow up.
When I bought the blade (after being encouraged by the staff at Woodcraft to go with this particular blade) I expected to use it as a general purpose do everything blade with the bonus of having a true flat bottom on non-through cuts.
For the most part this blade is ok as a multifunctional blade, but as most of y’all already knew there are very good reasons for the various tooth configurations on saw blades.
This blade does a really good job when I use it for the intended purpose.
It cuts a very clean non through cut and with a backer board exit splinters are very minimal.
It also does a very good job making half laps even though cutting them 1/8” at a time is painfully tedious LOL.
This is a very good blade to have in the arsenal, but if I had a do over on buying a $$$ blade I would have chosen the WWII with the ATB tooth configuration because I mostly build smaller projects and use my router table to cut stopped dados and box joints.
This is a very good saw blade and it does the job it is designed to do very well.
117420 posts in 3818 days
#15 posted 10-01-2017 03:28 PM
Thanks for your reviews
This is a super blog about saw blades knotscott really knows his stuff.
http://lumberjocks.com/knotscott/blog/12395
