Oneida Super Dust Gorilla - 5 HP
Review by Redoak49 posted 07-29-2016 12:42 PM 6273 views 1 time favorited 10 comments Add to Favorites Watch
Oneida Super Dust Gorilla - 5 HP No-picture-s No-picture-s Click the pictures to enlarge them
Several months ago, I purchased a new dust collector. Before, I had a Jet 1.5 HP dust collector with a cartridge filter and vortex cone. It did an OK job and was piped into my shop with 4” PVC. My measurements of the flow at the dust collector were 670 CFM at the 6” port and only 450 CFM at the 4” port. The maximum static pressure was 10.25” Inside my shop, the flow was greatly reduced.
I decided that I needed something bigger to collect more of the dust and so looked at a number of the different cyclone units. I did not pick the ClearVue one because they do not provide all the parts and you have to order things like filters and dust bins from other supplier. In my mind, the final product from ClearVue is a fine cyclone. I decided on the Oneida Super Dust Gorilla. I was initially looking at the 3 HP version but the 5 HP version ended up being not too much more. I was fortunate as the wiring in my garage was sufficient for a 30 amp breaker which is required. The basic specifications were –
The specifications on the Super Dust Gorilla were
• 5 HP US made Baldor motor – 19.5 Amps
• Backward Inclined Cast Aluminum Impeller – 15”
• Max Performance 1860 CFM at 2.5” SP
• 8” Inlet
• HEPA MERV 16+ Filter
• Filter 110 sq. ft
• Height 97.5”
The dust collector is piped into my shop with a couple of 8” metal 90 degree elbows and then reduced to 6” DWV pipe.
The unit arrived on one full pallet. The pallet arrived with no damage and the driver moved it into my garage. One issue that I had is that there were a lot of individual boxes and none of them were marked. That meant that I had to open them all to find the parts and make certain nothing was missing. Only one part, a blast gate, was missing.
The choices for mounting the dust collector was either a wall mount or legs. I chose to use the legs as I did not want to have any vibration transmitted to the house. I used pressure treated 2×4 to mount the legs on. They had holes in them to prevent the dust collector from moving due to vibration. This also allowed me to level the legs as the garage floor had a slope to it.
The parts of the dust collector were very heavy and I used an engine lift to put it together. I did most of it by myself but my wife helped a couple of times. The assembly went pretty smoothly and took me about 2 days. The cone is thick steel and quite heavy and I used an engine lift to help get parts in place.
The most difficult part was putting the motor and impeller assembly on top. The 5 HP motor was very heavy and awkward. I ended up attaching it by laying the collector on its side and using the engine lift to maneuver it into place. I used the engine lift and a block and tackle to get it back upright. It was not easy.
PROS
• This is a USA made unit with a USA made Baldor motor.
• It is a heavy well built, solid unit. The cone and cyclone barrel are heavy gauge steel with good welds. The fan housing is very heavy duty plastic. None of the parts seemed cheap or under built.
• The dust collector runs smoothly and quietly. I can stand beside it and have a conversation.
• The paint job is great without any runs, scratches or other defects.
• The remote control works well through the wall from my shop into the garage.
• There is very little dust showing up in the filter which means that the cyclone works well.
CONS
• Oneida advertises that if you purchase one of their dust collectors, they will provide design for the ducting. They did provide this service but it was USELESS. I provided them with a lot of information and the limitations that I had. The design that they produced did not take into consideration anything that I had provided and only what they thought was best. It would not work for my shop. Of course, they are trying to sell ductwork.
• This dust collector has a lot of power. However, the maximum CFM that I measured was around 1650 while the specification for the unit was 1860 CFM. I have written to Oneida about this but have not gotten a response.
• I think that the filter is a bit undersized at 110 square feet. Many other brands use significantly larger filters. If I ever have to replace it, I will go with larger ones. However, the dust filter pressure is within the typical range and I have not had any problems with filter clogging.
• The remote control has no dip switches to change the code. I found out that it was on the same frequency as the fan in my wife’s sewing room. She complained several times that something turned her fan off and I was surprised a couple of times that my dust collector suddenly shut off. I had to get up to the cheap fan on her ceiling and change the dip switches on it.
• The directions could be a lot better. They are barely adequate and for some will be difficult to follow.
• In several cases, the bolts supplied by Oneida were not long enough because of the thickness of the foam seal that one had to install. I had to go out and buy longer bolts. Of course once the ½” thick foam seal was compressed the original bolts were long enough.
• A couple of times, I did call back with questions and found that the people I talked to did not know very much. At that time, the person had never even put one together or had any hands on experience.
Overall, I am pleased with this dust collector as it is a very solid, good performing unit. Oneida should take note as there are a couple of things that Oneida could change to make it even better.
I am writing a blog to better describe the unit, the build process and performance testing.
View Redoak49's profile
Redoak49
3239 posts in 1982 days
10 comments so far
View Greg the Cajun Wood Artist's profile
421 posts in 936 days
#1 posted 07-29-2016 04:26 PM
I bought the same Oneida Super dust Gorilla in 2008. It has been a workhorse and completely trouble free. I set mine up underneath an enclosed stairwell in my shop that is insulated and soundproofed with spray foam insualtion and is therefore whisper quiet. I also have a 5 hp compressor under the stairwell.
I have 6 remotes for my dust collector and in ther last 8 years I had to replace only one.
I designed my own ductwork instead of using Oneida’s design service and I bought the metal spiral ductwork from a big woodwork supply store that is about 30 miles from my home..so I did not have to pay shipping for it. Since making several design changes in my shop tool arrangement i now have some 4” pvc combined with my metal duct pipe.
-- Wood for projects is like a good Fart..."better when you cut it yourself"
View AZWoody's profile
AZWoody
1330 posts in 1218 days
#2 posted 07-29-2016 05:01 PM
I can agree with you on Oneida not knowing as much when asking questions.
I chose the Clearvue over the Oneida because I got a much better feel for how the unit would work from talking to the lady at Clearvue. She knew the ins and outs of the unit and how it works in their own shop.
Also, it was a one stop place for me to purchase everything I would need. That includes the 6” blast gates, hoses and 4” transitions.
I don’t understand why you say you have to get all the parts from other suppliers though. You can order a Clearvue unit either with or without the filters. It’s right on the main pricing list.
The only thing they don’t supply is the dust bin but that’s because everyone has different height requirements for their installations.
If you are wanting some filters, let me know. I bought the filters that came with the Clearvue but I ended up piping it outside so I am not using mine. I am pretty sure they were made by Wynn Environmental.
Going off the top of my head, it’s 2 filters that stack around 6’ high and maybe 16” across.
View Mainiac Matt 's profile
Mainiac Matt
8029 posts in 2322 days
#3 posted 07-29-2016 05:14 PM
1650 vs. 1850 cfm
I’m impressed that you actual measurements were even this close as measured cfm can vary a lot and can only be accurately predicted with a fan curve and an accurate measure of the flow losses and restriction in your ductwork. That’s why they quote 1850cfm at 2.5” SP.
My understanding is that the standard DC test setup has a manometer in a 10’ run of straight smooth walled pipe of the same diameter as the inlet sucking an open room. Also, in order to be universal, all test results would then have to be corrected to STP (standard temp and pressure) as any variation in air density will have an affect on the flow rate.
Sounds like a reliable beast approaching the upper limit of an in-home hobby shop. 5,000 cfm is the threshold for what you can have inside the shop, and beyond that, if you recirculate the air back into the shop, you get into fire suppression requirements that cost more than the DC system itself.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
#4 posted 07-29-2016 05:26 PM
Rredoak…I purchased the extra remotes from Oneida. I don’t know if they are available elsewhere at a lower cost but I do know these all work and are programmed right out the package to work with my system.
I did buy the dust bin alarm and it was a waste of money because I could never get it to work despite several calls to Oneida. I just lift off the dust container top every so often and take a look to see what the level is. This method has worked just fine for me. One thing I would have done differently would be to get the larger dust bin instead of the smaller one. Since my Oneida is wall mounted and the 8” metal pipe is already lined up with the smaller dust bin it would be a lot of work to disconnect and move everything to line up with th 55 gallon dust bin…
I read someone’s post that they cut a small opening in their dust bin and covered it with a piece of clear plexiglass. I considered doing this but wonder if it would quickly get to the point of having the view blocked from the dust inside.
The best upgrade I have done was replacing my Oneida filter after several years of use with a double filter. I used 2 of the Wynn Filters and it made a noticable increase in suction power. I added 2 cleanout ports at the bottom and when I want to clean the filters I just open them and put my shop vac hose in there and use compressed air on the outside of the Wynn filters. Works like a charm…
Redoak49
#5 posted 07-29-2016 05:45 PM
I will be posting a blog segment in the next couple of days concerning my testing. I used a straight run of 8 inch pipe and a digital thermal anemometer from Dwyer.
I really like the dual filter set up and at some point will do something similar.
View richimage's profile
richimage
42 posts in 1724 days
#6 posted 07-29-2016 08:18 PM
Great looking and sounding setup. I am in the process of upgrading from an HF “Frankenvac” (standard mobile base, Thein filter lid on chip barrel, exhaust out 6” flex hose) as my machines connect one at a time with Rockler quick-connects to the two 4” hoses. I purchased a Super Dust Deputy, 4” PVC pipe/fittings, ordered the Rikon impeller so often mentioned (it’s on the way!) and have a plan for the stack to a “top hat” configuration. Last bit I’m working on is how to raise the lid so I can remove the chip barrel for emptying.
wow! Just looking at the picture shows how ugly that setup truly is….. Better get busy on the replacement! And here is the CSU (Chief Spousal Unit) helping with the chores…
-- "Women are like modern paintings. You can't enjoy them if you try to understand them." Farrokh Bulsara (Freddie Mercury)
View b2rtch's profile
b2rtch
4861 posts in 3042 days
#7 posted 08-01-2016 01:15 PM
For years I have a clear view 5HP.
I put together alone, that was a job!
http://lumberjocks.com/topics/46709
http://lumberjocks.com/topics/46764
-- Bert
Redoak49
#8 posted 08-01-2016 03:25 PM
That is great b2rtch…...have you done any measurements on flow or static pressure. It would be I interesting to compare actual data. I suspect they are very similar.
b2rtch
#9 posted 08-01-2016 03:34 PM
No I never did.
I just know that my installation is not as good as it could be because I have to use a sharp 90 degree elbow right into the cyclone.I know enough about fluid dynamic to know that I loose a lot of suction right there but all together my installation works very well for me.
I made all the ducting using inexpensive 6.00” of the self duct from Lowes.
To prevent the duct from collapsing I made a vacuum safety valve.
It works very well.
I bought the clear view used for around$700.00
-- Bert
Redoak49
#10 posted 08-01-2016 05:50 PM
I had to use two 90 degree bends from mine to get in the shop. I used 8” long radius elbows from Oneida. After that reduced to 6” DWV into the shop. The important part is that even with reduced flow due to the elbows and size reduction I still get enough flow.
