| Review by EricWrights | posted 142 days ago | 980 views | 0 times favorited | 10 comments | ![]() |
- Rockwell Jawhorse
- Brand: Rockwell | Category: Safety Equipment
I do 99% of my projects alone. Believe me this one is a Lifesaver! I’m always a bit skeptical of infomercials and typically believe gimmicky tools are much more trouble than they are worth. But, thinking about all the times I’ve risked cutting boards that were unstable and chasing odd shaped items across my bench with my surface grinder, I kept thinking this thing might just be worth a try so I finally decided to order one.
In the closed position the unit stores easily and takes up little floor space. Its clever folding design sets up and breaks down in a matter of seconds. Its first job was disassembly of a small electric motor to change bearings. The jaws worked great to snugly hold the stator of the motor while I removed the through bolts and end bells. It then firmly but gently held the armature in the vertical position while I pulled the bearings. It is amazing how much control you have over the amount of pressure you apply. I also used it to hold a circular saw I was repairing(talk about an odd shape) and then to hold some boards I was drilling pocket holes in. In all instances it worked flawlessly and much easier, quicker and safer than the way I would normally do those jobs.
Bottom line is I can see I will be using this tool for pretty much every project I have going. A little expensive but it will quickly pay for itself in time saved and improved safety. If you do a lot of work alone like I do, you will find the Jawhorse is an incredible helper.
Here are some pictures I have found on the internet when I was doing some research about it.
-- Sawing, sanding, scraping, cutting? Let Rockwell Sonicrafter do the job. http://rockwellsonicrafter.com
10 comments so far
home | projects | blog
16684 posts in 470 days
posted 142 days ago
Good review Thanks
Don K.
1095 posts in 219 days
posted 142 days ago
Agreed VERY nice review. I have been curious about this tool myself as I also do 99% of my work by myself. Now that I have read a “Real Users” review over one…I will take a closer look at one, I have seen prices all over the board on this tool…if you do not mind me asking…what did it cost ?
-- Don S.E. OK
PineInTheAsh
194 posts in 161 days
posted 142 days ago
Under $200.
The Rockwell stuff has yet to make it to the wonderful east coast.
I spoke to a NJ Lowes manager about this availability and he simply threw up his hands.
EricWrights
90 posts in 144 days
posted 142 days ago
I got it for $175 + Free shipping. It shouldn’t cost over $190 as far as I’m concerned.
SCOTSMAN
2238 posts in 478 days
posted 142 days ago
I got a different version of this by Dewalt I think the base is different to yours as it has a kind of crossbracing they are great to use.It can hold a full door on its corner edge and not topple over they were oricginally made by triton of Australia. Have fun regards Alistair
Jimmy
26 posts in 233 days
posted 142 days ago
thats weird. i was in my local woodcraft in va the other day and they had one on display right next to the scroll saws. have you tried woodcraft yet? i didnt catch a price though.
-- 20 year old new woodworker. advice and tools much appreciated.
verndog
13 posts in 277 days
posted 141 days ago
I just picked one of these up last week at Rockler. The normal price was 179.00 but I had a 20% off coupon, out the door after the hefty CA sales tax it was 156.59. I really love this thing I had seen it demonstrated at the woodworking show a couple months ago. Very well made and simple to use. I am going to order the welding attachment shortly as my old workmate has scars from using it for something it wasn’t intended for. I am really looking forward to using this ingenious tool. I would highly recommend it since it has so many flexible uses.
-- Vern, Southern CA
laflaone
57 posts in 573 days
posted 141 days ago
It looks like a handy tool, and probabably well made. It just doesn’t seem to be even close to being worth $175-$200.
-- "non illegitimis carborundum"
RainyDayInterns
3 posts in 131 days
posted 131 days ago
For those interested in a closer look at the unpacking and setup of the Jawhorse, here are a few in our RainyDayMagazine FirstLook series. Click on any of the images for a larger version.
http://www.rainydaymagazine.com/RDM2009/Home/July/Week3/RDMHomeJul1309.htm#RockwellJawHorse
http://www.rainydaymagazine.com/RDM2009/Home/July/Week3/RDMHomeJul1409.htm#RockwellJawHorseSetup
Sincerely,
RainyDayInterns
-- "We Entertain When It Rains"
RainyDayInterns
3 posts in 131 days
posted 121 days ago
Here are two more :
A closer look at the construction of the Jawhorse (welds, the Jaw):
http://www.rainydaymagazine.com/RDM2009/Home/July/Week4/RDMHomeJul2309.htm#JawhorseFirstLookPart1
A closer look at the rolling and carrying Jawhore:
http://www.rainydaymagazine.com/RDM2009/Home/July/Week4/RDMHomeJul2409.htm#JawhorseFirstLookPart2
The FirstUse series will start in August.
Sincerely,
RainyDayInterns
