DAILY DEALS Rockler 3-Pc. Roundover/Beading Bit Set at Rockler  |  DeWalt Gauge Narrow Crown Stapler at Tool King
G0513X2 17" Bandsaw
Review by Don K. posted 129 days ago 1248 views 0 times favorited 31 comments Add to Favorites Watch
G0513X2 17" Bandsaw No-picture-s No-picture-s Click the pictures to enlarge them
This will be kind of a “Duel” review….One over the G0513X2 17” Bandsaw, and one over Grizzly’s customer service.
I received the Bandsaw several weeks ago, but because I had been so busy….I did not have time to even un-crate it. It stood in the corner of my shop for about a week and a half before I could even open it up and start to put it together.
I opened up the saw, looked it all over….no scratches,dents,blems etc..so we’re off to a good start. As I looked through the directions to make sure I had everything….I noticed I could not find a bag of hardware. Now there is VERY little assembly to do on this saw…basicly four bolts for the bed…four bolts for the fence….and one knob/crank handle that needed to be added…(This knob raises the blade guide)....the bolts I could have lived with out…but I needed the knob/crank handle.
Now I have never really had to deal with Grizzly about a problem like this…and was afraid that since the saw sat in my shop for almost two weeks before I noticed the missing parts…they would give me some trouble.
No such thing…I called Grizzly’s customer service, told them what happened and why it took me so long to call them, all they said was..”We are very sorry for the inconvenience, what parts are you missing ?” After I told them what was missing they said “It will be shipped out tomorrow !” ...two days later the missing parts were sitting on my front porch. Not bad imo !!!!
Now on to the saw…. As I stated earlier…about eight bolts and one crank handle is all I had to put on. As far as adjusting all the settings….again, VERY easy…..very easy to follow and precise directions. I really did not know what to expect when it came to adjusting this saw….I have a great old Rockwell bandsaw that runs like a dream….but it is a cranky old thing…some days it is a breeze to adjust a new blade…and other days it takes forever and just will not hold a adjustment.
This G0513X2 17” Bandsaw took me about 30 minutes to adjust everything…and that was only because I was not used to this saw. Now that I know where all the different adjustments are and how to use them…it only takes about five to ten minutes to change out blades and to reset all the rollers to fit the new size blade….I was ALL smiles !!!
Accessory’s and options ?? IMO this is a very well thought out saw, it has two different see through windows…one to see what your blade tension is at (Has a nice very easy to read scale for this) and another to watch the top of the top wheel to see how your blade is tracking. It has a large easy to use lever to release blade tension…and all of the adjusting wheels to set the tracking, raise or lower the blade support etc are large and easy to use.
The cast iron table is large and very easy to adjust and true up to the blade. It has cast iron wheels instead of aluminum and once I had the blade set proper ran smooth as silk and with no vibration. It also comes with a over sized re-saw fence that attachés to the existing fence in about five seconds.
Power ??? The largest lumber I have resawn so far is 12” wide mahogany…...Once I got used to the saw and how to set up the fence….I made several dozen 1/16” thick slabs, all came out smooth as glass and it never bogged down a bit.
When I had done these same cuts on my old rockwell….lets just say I would still be out in the shop pushing the wood through.
It also has a very neat “Rack and pinion” for the cast iron bed that works very well.
This is a GREAT bandsaw…plenty of power, plenty of nice options, good dust control…that I would highly recommend to ANYONE…it also has free shipping.
The ONLY negative thing I found was “One” adjustment for one of the bottom blade rollers…all of the rollers are locked with allen head bolts/screws…all work very well and all the allen wrench’s are included. But one allen head under the bed toward the back….could not be adjusted with a allen wrench, when you but in the short end of the allen wrench you do not have room to turn it up and down with out the long end hitting the bed or the saw body….and you can not put in the long end because it is to long and hits the saw body and goes in at a angle…this is a easy fix by just swapping out the allen head for hex head bolt.
I have seen several reviews about members not even using the blade that comes with it…and I agree…when I ordered the new saw I ordered a full set of Timber wolf blades to go with it. I am sure the factory blade would do fine for some light sawing….but there is no way it would stand up to any serious hard wood…so I didn’t even try it…but put on a new timber wolf during the adjustment and set up stage.
Here is a close up picture of it
saw
And in this one you can see (Kind of lol) how big the re-saw fence is.
fence
-- Don S.E. OK
View Don K.'s profile
Don K.
1095 posts in 204 days
31 comments so far
15541 posts in 455 days
posted 129 days ago
Hey Don
Most excellent review It makes me want to trade in my Lauguna. I guess i missed the posting of you shop before ,It looks cool with all that new Grizzly tools . Thanks bud
Don K.
posted 129 days ago
Thanks Jim.
-- Don S.E. OK
View roadrunner0925's profile
roadrunner0925
34 posts in 499 days
posted 129 days ago
mind if i ask what the going price for one of those is?
-- wm, brandon,ms
View Joe Lyddon's profile
Joe Lyddon
470 posts in 930 days
posted 129 days ago
Very nice BS… Grizzly DOES care and has very good customer service.
I have the G0555… I love it…
Don K.
posted 129 days ago
roadrunner0925 $995.00 shipped to your door.
Heres the link
http://www.grizzly.com/products/17-Bandsaw-2HP-w-Cast-Iron-Trunnion/G0513X2
-- Don S.E. OK
View verndog's profile
verndog
13 posts in 262 days
posted 129 days ago
That is a beautiful saw Don. Ive been looking at the Grizzly BS myself and am really glad to hear they have good customer service. I am undecided if I really need this much saw for my first BS? Ive been thinking of the GO555X since others seem to be happy with it also. I don’t think I would be doing much re-sawing. Thanks for the great review!
-- Vern, Southern CA
Don K.
posted 129 days ago
verndog Thanks, and I agree….if you know for a fact that you will not be doing much re-sawing…I would go for the G0555x myself. My friend has one and loves it. My old Rockwell works great but just did not have the power for all the re-sawing I was doing. I am going to keep my Rockwell for smaller things and intricate cuts and use the new Grizzly for the heavy work. I did buy a couple of smaller Timber Wolf blades for the Grizzly for smaller jobs. But for now plan on just leaving on the re-saw blade.
Joe Lyddon Thanks, as I told verndog…the G0555 is a great saw also !!
-- Don S.E. OK
View Marco Cecala's profile
Marco Cecala
90 posts in 911 days
posted 129 days ago
I just tool a break from setting mine up. It arrived yesterday and I am looking forward to resawing with a carbide tipped Timberwolf blade. I will report on the blade soon.
Don K.
posted 129 days ago
Marco Did you get the same saw ?
-- Don S.E. OK
View JerryS's profile
JerryS
73 posts in 488 days
posted 128 days ago
Excellent review and thanks for posting it . This saw is looking better and better all the time. Did you order the Timber wolf blades from Grizzly also ?
Don K.
posted 128 days ago
JerryS, yes I did….I really can not coment on how good the price for the blades was or was not…When I ordered the saw I just ordered some blades of different size and teeth. The price was not bad at all….but a person may want to shop around on the blades to make sure they are getting the best deal.
The Timber wolf blades run from $24 to $34 per blade depending on size, tooth count etc.
-- Don S.E. OK
Marco Cecala
posted 128 days ago
Don;
Yes I did.
View Lenny's profile
Lenny
117 posts in 405 days
posted 128 days ago
Hi Don. As usual, you offered a nice review here. Best wishes for much enjoyment with the new BS. The window feature may have become the standard. My Rikon has them too. That’s a nice convenience. Take care.
-- And on the eighth day God was back in His woodworking shop!
View Brad_Nailor's profile
Brad_Nailor
1192 posts in 835 days
posted 128 days ago
Great review Don! I am sure this review will show up on the Grizzly website as well. I think I am going to end up with an all Grizzly shop myself. This band saw looks fantastic….and after the review I read on here on the Steel City I was thinking of buying…I’m all about this band saw!
How is the dust collection? I love the fact that it has two ports and the insert has holes in it to draw the sawdust away from the cut area…is it effective?
Don K.
posted 128 days ago
David, If you look at my shop pics…it is becoming all green for sure lol….The dust system works very well at keeping the dust out of the machine and works pretty well at keeping it out of the work area depending on what you are cutting. For normal use it sucks all the dust down and out…..when doing some serious re-sawing (Like 12” mahogany) it still gets it out of the work area pretty much…but does tend to build up a bit under the table near the rollers. Nothing really bad and only needed blowing off after several cuts.
-- Don S.E. OK
View blackcherry's profile
blackcherry
711 posts in 701 days
posted 128 days ago
The only problem I can see is that you’ll be spending more time on your non-grizzly tools ie. honey due list…great review and please don’t smile too much. ENJOY!!!!!!!!Blkcherry
View grizzman's profile
grizzman
454 posts in 181 days
posted 127 days ago
great looking saw don, its one tool i dont have …but its on top of the list…...thank you for a great review and enjoy that new saw..grizzman…..ive got bandsaw fever…......
-- The Grizzone
Don K.
posted 127 days ago
Well grizzman…with a name like yours…you should have atleast “One” Grizzly tool !!!
-- Don S.E. OK
View pauldeo's profile
pauldeo
25 posts in 204 days
posted 127 days ago
Hey all. I can totally agree with Don’s review. I purchased almost the same saw 2 months ago. I opted for the G0513X2B – magnetic brake, extreme series. The saw is amazing. There is no comparison to my old bandsaw. I opted for the Wood Slicer resaw blade and am happy I did. I was like a kid at christmas. I went through all my old scrap the first afternoon resawing the biggest, hardest pieces I could, and the saw just laughed at them 12” standing resaw on hard maple? Smooth and easy!
Don K.
posted 127 days ago
pauldeo Thanks for the confirmation….I came super close to buying the same saw you have…..Really glad you like yours !!
Quick question…were are you buying your Wood Slicer blades at ?
-- Don S.E. OK
View Durnik150's profile
Durnik150
536 posts in 200 days
posted 126 days ago
Great review Don!
To toss my opinion in on this topic: I would think that this BS is a step up from an entry level saw. Unless you know you are going to have a huge amount of resawing to do, a 14” is probably the place to start. I have a straight-forward Ridgid that does the job for now. A close friend of mine has a Grizzly 14” with the riser kit and it is a great tool! With the riser is cuts about 12” on a resaw where I’m limited to just less than 6”.
You provided great information and I’m glad you are happy with your saw!
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
pauldeo
posted 125 days ago
Charles,
I thought about a 14” with riser block, and it would probably have been fine. But, given that I am moving towards a commercial shop as of August 1, I wanted to make sure I had more than enough band saw than I would ever need, and something I would not likely wear out anytime soon. If i was moving forward solely as a home or hobby user, I would probably gone smaller and saved the money and the footprint.
Don – http://www.highlandwoodworking.com/index.asp?PageAction=VIEWCATS&Category=295
Don K.
posted 125 days ago
pauldeo Thanks for the link !!!
-- Don S.E. OK
View Greg Wurst's profile
Greg Wurst
713 posts in 710 days
posted 121 days ago
I am so going to buy one of these. I’m even debating selling my motorcycle to get the $$ and the room in my garage. That’s a nice homemade base you have on the saw. I assume you had some help lifting that beast onto it?
View blackdogwoodshop's profile
blackdogwoodshop
71 posts in 606 days
posted 113 days ago
Don, Thanks for the review. Have you used a 1/8” blade on this saw? I have heard that others have trouble setting it up for this as some people say the back thrust bearings won’t come forward enough to support the back of a thin blad like this.
Thanks,
Daniel
-- Daniel, Southern Indiana -- "Have nothing in your home that you do not know to be useful or believe to be beautiful." -- http://blackdogwoodshop.etsy.com
Don K.
posted 113 days ago
Daniel,
I have ran many different size blades on it…mainly to see how it worked. I have not had this problem.
-- Don S.E. OK
blackdogwoodshop
posted 113 days ago
thanks!
Don K.
posted 113 days ago
Daniel,
Maybe it has been redesigned or something. As I said in my review…I use it mainly for re-sawing…but bought a full set of blades to go with it. While I was “Playing” with it….I set it up on several different size’s just to see how hard it would be to set up…find any problems etc. Even on the 1/8” blade, it seemed to have some more adjustment left in it. Not much mind you…but enough to set the 1/8” properly.
-- Don S.E. OK
blackdogwoodshop
posted 113 days ago
I appreciate the feedback. I think I’m going to order one and give it a try for myself!
Don K.
posted 113 days ago
Daniel,
Your welcome, I hope you are happy with it. I know I am…NO regrets at all, it has been a GREAT addition to my shop. And dust control is GREAT !!!
-- Don S.E. OK
View BuilderBob59's profile
BuilderBob59
14 posts in 143 days
posted 89 days ago
I just wanted to comment I have the 514X2 and found the OEM blade was not so good for resawing. I bought the 1/2 inch wood slicer and that blade cut like a hot knife through butter but there was unbelievable blade drift. I then purchased a 1 inch timber wolf and the saw cuts straight as an arrow and almost half as fast as the wood slicer and real smooth. I had to crank the blade tension almost full limit to eliminate the blade flutter. I personally do not like the blade guide adjustment mechanisum as I feel like I’m about to strip out the set screws and when tightening the set screws on the guide bearing cams the set screw somehow moves the cam. The dust collection is good and the saw runs pretty smooth. My saw wobbles on the Shop Fox base. All in all it is a pretty good saw for my uses.
