Delta 22-580 13-Inch Benchtop Planer
Review by GaryK posted 669 days ago 4617 views 1 time favorited 18 comments Add to Favorites Watch
Delta 22-580 13-Inch Benchtop Planer Delta 22-580 13-Inch Benchtop Planer Delta 22-580 13-Inch Benchtop Planer Click the pictures to enlarge them
I have had this planer for going on 2 years now. I have nothing but praise for it.
I got it used but like new condition.
It has 2 sppeds. A dimensioning speed of 60 cpi allows you to shave rough wood to its desired thickness
quickly with no snipe. Then a quicker finishing speed of 90 cpi, your wood comes out ultrasmooth and ready
to go. The double-sided M2 steel knives are powered by a 15 amp, 120-volt, single-phase motor.
It has a blade zero indicator (which lets you set the cutterhead to the exact thickness of your wood), a
cutterhead lock (which eliminates snipe), and easy blade-change.
It also includes infeed and outfeed tables, which make it easier to glide your wood through the machine.
It max width is 13” and max height is 6 1/2” and a minium of 1/8”.
It comes with a video tape explaining all machine functions including changing the blades, which
are 2 sided. They basically drop in.
Is heavy at about 95 pounds, but that helps keep it in place.
The bad is that you have to buy the dust connector for about $30, but you can mount it it in either direction.
I have had zero problems and zero snipe.
All in all it’s a great buy.
Another thing that is a great addition is the Wixey planer gauge shown below. Imperial or Metric button
with auto power off to save battery. It will display decimal and fractions. ie.. ”.750 3/4”.
View GaryK's profile (online now)
GaryK
9535 posts in 885 days
18 comments so far
View mrtrim's profile
mrtrim
1698 posts in 777 days
posted 669 days ago
sounds like a great tool gary
14932 posts in 748 days
posted 669 days ago
That looks like a great addition to your shop Gary.
View cajunpen's profile
cajunpen
5968 posts in 962 days
posted 669 days ago
Gary I have the next model down from yours – and I also have the Wixey planer gauge on mine. Your review is right on the money – it’s a great little machine (as long as you have DC connected).
3710 posts in 876 days
posted 668 days ago
Great review Gary.
You sound quite pleased with it. It’s funny, I see some commercial shops going to smaller planners such as yours, and getting rid of the big units, as they take up too much space.
I went the other way, and upsized. The first time I used the larger machine, I kept looking around for the rest of the wood. I just couldn’t believe I was finished already.
I still use my smaller one on jobsites though
View Jeff's profile
Jeff
996 posts in 990 days
posted 666 days ago
I have this same unit. I completely agree with the review. The cost of the dust chute is annoying but use it for a day without the chute and you will get over it…
-- Jeff, St. Paul, MN
View Dorje's profile
Dorje
1767 posts in 893 days
posted 666 days ago
I’ve had the same planer as you guys for just over two years as well…I finally purchased the dust collector attachment last month. It was the last thing on earth I wanted to drop $30 on, but I’m tired of getting on my hands and knees to pick up all the shavings off the floor. However, I don’t have a dust collector. Not sure the shop vac has enough cfm to handle it, nor the holding capacity (this is the reason I pick it all up by hand and only vac what I miss). The planer sure seems to push the chips and dust our pretty forcefully, so I was thinking that just routing a short length of 4” hose into a garbage can could do it. The hose would go directly in the lid with a filtered vent for air to escape but dust and chips to stay put.
For those that own this planer, what’s your gut on my silly idea?
Thanks for the review Gary – it’s right on. I love this planer and wouldn’t trade it for the Dewalt 735.
I mean it.
Of course having missing parts when I first got it was a drag, but Delta had them to me in a week or so, and I could still use it from day one. If I recall it there was no knife tool and the bolts to hold on the handles were missing. At least, that’s what I remember.
Still wouldn’t trade it.
Dorje
posted 666 days ago
While I’m at it – do you know where to get a good deal on knives. I meant to stock up a while back when I saw them at Lowe’s in the $30 range, but never did. Of course, they are not an item that Lowe’s stocks any longer and the woodworking outfits want about $50 for the set.
What do you think?
View Dadoo's profile
Dadoo
1723 posts in 887 days
posted 663 days ago
The knives are double sided and very easy to change out. I bought the dust chute and added a 90 degree elbow to blow the sawdust into a trash bin. It’s still messy but 99% of the chips end up in the can. The chute works great but will clog easily, especially when planing wet wood, or planing too deeply.
You guys are right though with this being one of the best planers I’ve ever used. I’m definately satisfied and would recommend this unit to anyone.
Thanx for the great review Gary.
20733 posts in 719 days
posted 662 days ago
Gary, I have the same tool and have used mine for several years w/o any problem. I have planed serveral hundred feet of cherry and maple and only have a minor nick in one of my knives. Today I added a dust collector to it and have the Wixey gauge on order.
Your review is right on the money.
posted 662 days ago
Dorje, In answer to your question about dust collection I doubt if it would work very well. You are dealing with such a large shavings volume that I am sure it would just clog the hose. I have seen some posts that advise against using a shop vac for dust collection because it just doesn’t have enough pull, not to mention enough volume, to handle this job. But I am going to try it anyway and see if it can work.
If it doesn’t then I can always continue to wheel my planer outside or maybe use this as an excuse to buy a legitimate dust collector.
View TroutGuy's profile
TroutGuy
100 posts in 608 days
posted 605 days ago
I have had this planer for a couple of years, and I agree—it works great! I haven’t run as much lumber through it as I would like (darn day job), but what I have done comes out beautiful.
As to dust collection, I too hated to drop the extra $$$ for the chute, but when connected to my big shop vac (Rigid 12 gal x 5 hp), there isn’t enough dust on the floor to worry about. Yeah, it fills up fairly quickly, but until I can afford a ‘real’ DC system, it’ll do.
-- There is nothing in the world more dangerous, than a woodworker who knows how to read a micrometer...
Dorje
posted 604 days ago
I now have the dust collection attachment, with a 10’ run of 4” hose…I put the 2 1/2” shop vac hose 3-4’ into the 4” hose and the vac picks everything up without clogging…
Doesn’t have the capacity of a DC, but sure beats picking chips up off the floor!
GaryK
posted 604 days ago
Dorje – Makes a big difference, huh?
View damnHippie's profile
damnHippie
29 posts in 672 days
posted 603 days ago
I don’t have this particular planer (I have a DeWalt 734), but until I got a dust collector I used a shopvac attached to the dust chute of the one I have. It worked pretty well, but like Dadoo said if I planed too deeply or planed wet wood, chips went a’flying. Now with the dust collector, post-plane sweeping is at a minimum.
-- 10 fingers, 2 eyes, and healthy lungs. for now. :P
Dorje
posted 603 days ago
GaryK - let’s just say it makes enough of a difference to set it up each time!
dH - I’ll have to get a dust collector one of these days!!!
View 220grit's profile
220grit
3 posts in 283 days
posted 283 days ago
I too have this machine. The dust collection attachment and a extra set of knives came with the planer as a package (purchased through Amazon.com) Have Jet 1100cfm dust collector plumbed into it. Very satisfied, great machine. Also over $100 less than the DeWalt 2 speed 3 knife.
-- Michael,Oregon
View Chipster's profile
Chipster
4 posts in 289 days
posted 257 days ago
I have been looking at planners and this one caught my eye. Been watching Craigs list to see if I can make a bargain. Will a garbage can separator work with this unit?
-- If you build it, you will have fun!
View thiel's profile
thiel
95 posts in 189 days
posted 172 days ago
Oddly enough, I had this machine WITH the dust chute, but without a dust collector for a while. It spit the dust right out.. no bogging at all and a pretty tight pile of dust… so, I’d bet that anything that will catch the dust (a can, bag… whatever) will catch most of it.
That said, this IS the machine that caused me to get a dust collector!
Does a beautiful job. I’ve used it a ton and it’s just great.
-- Laziness - Apathy = Efficiency
