| Review by charlton | posted 144 days ago | 1709 views | 0 times favorited | 28 comments | ![]() |
- Steel City 50130 14-Inch Deluxe Granite Bandsaw
- Brand: Steel City | Category: Bandsaws
Disclaimer
I’ll preface my review with a warning to prospective readers that I can be obsessive about details and my day job entails finding design flaws. This review will be long. If you’re interested in purchasing this saw, you may find value in pouring over the details. Otherwise, you’ll likely be bored out of your mind.
In the beginning it was the 50100…
The bandsaw buying process was a very long and arduous one for me. I’ve always felt that the newer European-style saws to be superior yet the choice of saws with both big resaw capacity (>10”) and a small footprint are pretty dismal. The Rikon 10-325, Grizzly 0457, and Laguna LT14 series are probably the best candidates except none of them are available in Canada! Actually, the Laguna is now available but the pricing, coupled with the lack of standards approval make it less appealing.
I initially set my sights on the SteelCity 16” Industrial Bandsaw but it turns out that saw was relegated to the history books along with the Dodo and finding a store that carried one within a 100km radius proved pointless.
Resigned to the fact that I’d have to settle for one of the conventional cast iron saws with a riser, I chose the SteelCity 50100 14” bandsaw and bought the corresponding riser kit with it. Assembling the saw was fairly straightforward though one of the tapped holes used to secure the saw to the base was poorly executed resulting in a stripped bolt. I installed the riser kit from the get go and put on a Viking 3/8” 3tpi blade. The anticipation mounted as I fired up the saw and to my dismay, there was an unbelievable amount of vibration. I noticed that the included Poly-V belt had a fairly substantial twist to it that I suspected might be causing the vibration. I decided to call SteelCity to see if they would be willing to send a replacement belt and was told that it’s normal and that the twist will resolve itself in time. So I lived with the vibration…hoping with each use that the miraculous day would arrive when the saw would purr silently. After a few weeks, there was no improvement in site and I read in other forums of other people having vibration issues with the saw (also with the riser). I contacted SteelCity again and they graciously agreed to replace the saw with the forthcoming 50130! “Wow,” I thought to myself, “that’s some serious customer service!”
The 50130 arrives…
Turning the clocks ahead 3 months, the replacement 50130 saw arrived from the factory. I was told to keep the base/motor assembly and to package up the actual saw. True to their word, SteelCity came by one day, and delivered the 50130 and took away the 50100 with no questions asked. I had a nice conversation with Terry (the regional sales manager who dropped the saw off himself) and shortly after he departed, it was off to the races once again.
I’ll introduce the 50130 by reviewing what this saw has:
- “Native” 12in resaw capacity (no riser kit needed)
- Granite table
- Granite lower wheel/cast iron upper wheel
- Included fence
- Worklight
- Mobile base
- 1.5HP motor
- Roller bearing guides
It’s a pretty impressive saw on paper and if SteelCity’s reputation is any indication, this saw should be an absolute winner. Let’s see if this is the case.
The Good
The saw’s fit and finish, for the most part, is excellent. The components are all nicely packaged, screws sorted, and the paint job is well done.
The granite components really are quite nice. There is little concern for the table warping or rusting which is good. The bottom of the table is also flat which means clamping things is very convenient. There is absolutely no doubt that the granite wheel yields greater angular momentum because it takes much longer for the saw to stop. If cast iron helps the saw resaw better, then certainly the granite will be better.
The included mobile base saves you from having to purchase an external one which is good. It is, however, a two-fixed, one swivel system so maneuvering requires you to understand how to parallel park a car.
The fixed work light included with this saw is vastly superior to the magnetic base one that came with the 50100. The magnetic version didn’t have enough holding power to keep the light in position most of the time and it had such a large footprint, there wasn’t a whole lot of choice on where to actually mount it.
The saw has a cast 4-in dust collect port which is better than the 2.5-in ports on some of the other cast iron offerings.
The saw is capable of operating at two speeds, 1500sfpm and 3000sfpm. This is accomplished by moving the belt on a pair of stepped pulleys much like on a drill press.
The trunnion on this saw is nice and beefy. One many other 14-in offerings, the table supports are very soft and even applying a moderate amount of pressure causes movement of the table. This is not the case with this saw.
The saw has a quick-release lever for de-tensioning the blade. On the 50100, releasing the tension would allow the blade to be changed whereas on the 50130, even de-tensioned, there is still enough tension on the blade to prevent you from being able to change blades. You must, as a result, crank the tensioner down until the blade is relaxed enough to change.
The Bad
Unfortunately, with all that the saw has to offer, there are some warts as well. In fact, there are many warts. As this saw is based on the venerable design of the old Delta 14in bandsaw, it invariably suffers from some of the same shortcomings. You would think that after 40 or 50 years of continuous “refinement” they’d be able to improve upon the design enough to make the saw feel a little more contemporary rather than like the Ford Model T. Many of the comments that I make henceforth are likely applicable to many Delta copies. Nevertheless, since SteelCity seems like a company that’s willing to try new things and to improve upon existing designs, I’d expect them to pick up some of the low hanging fruit as they pass Go.
The first problem with this saw is that it suffers from usability/ergonomic issues.
Let’s start with the blade guard. The design of this blade guard is such that it mounts to the guide assembly and folds around the front of the guide assembly shielding the user from the blade. Almost all 14in bandsaws have guards this way except for some reason, SteelCity elected to use a guard that blocks all the way to the bottom of the guide bearings. The average human is about 6’ and the usual recommendation is to have the guides set about 1/4” above your workpiece. It doesn’t take long before you realize that you can’t see enough of the blade to guide the workpiece in making accurate cuts (unless you stoop down even lower). With the 50100 riser kit guard, it was “tough luck.” With the 50130 SteelCity “improved” the guard by putting in two small plastic windows to help the user see. I’ve worn glasses the vast majority of my life but these plastic windows make me feel like I need to have corrective eye surgery even with my glasses on. Surely they didn’t think that looking through Coke bottles was going to help the problem any great amount? Not to mention that as you cut, sawdust tends to stick to the plastic and you soon end up with a graffiti canvas…the kind where people write “wash me”.
Fortunately, the little plastic windows are removable though their absence only improves visibility by a fraction. Imagine cutting with tunnel vision.
Next up, the blade guard…again! My PC chassis have been tooless for quite some time. The good news is that the SteelCity is tooless as well, but only for the bearing adjustments. Removal of the blade guard requires the help of your friend Phillip.
A couple of knurled screws (positioned slightly differently, of course) would have made it fully tooless. Of course, no one would ever want to take the blade guard off unless one wanted to change the blade. It turns out that removing the blade with the guard on especially with wide blades (i.e. 5/8”, 3/4”) is extremely difficult. In fact, darn near impossible.
As if changing blades wasn’t hard enough with the nuisance of the blade guard, next up we have the fence and lower door. Observe exhibit A:
The nice fence rail is so long that even with the door wide open (yes, 90 degrees is as wide as it goes), there’s hardly a gap for you to pass the blade through. In fact, for wide blades, it simply can’t be done. Instead, you have to tilt the table (unless you prefer removing the fence rail).
Next up is the lower bearing guides. Everyone knows that setting these bad boys is a test of patience. In the case of the 50130, they’ve decided to push the human frontiers of patience. Observe exhibit B:
This is a photo of the bevel gauge but what you don’t see but really want to see, is the guide assembly that’s craftily hidden behind the knob. That’s right folks, the vantage point from which you are best able to set the bearings is not available. Of course, one could remove the knob (there’s another one at the back anyway) except:
that lower blade guard will pretty much hide whatever the knob doesn’t. Of course, you can peer down the hole in the table but, trust me, it’s dark down there.
A more minor quibble has to do with the work lamp and the quick release lever. SteelCity chose to use a quick release mechanism that rotates almost 180 degrees. That’s fine. However, the lamp is mounted along the trajectory of the quick release lever. The following photo doesn’t have the lamp mounted but the two screw holes are where the lamp would mount.
At least the lever doesn’t hit the mounting bracket of the lamp but you typically have to move the lamp out of the way to engage and disengage the quick release mechanism. Also, the lamp requires its own plug. It would be very nice if it could just tap its power off of the same line feeding the saw.
As I mentioned earlier, the saw has a nice 4” dust port to suck up all those sawdust baddies. Here’s what it looks like on the inside:
That little red bracket is supposed to help direct dust into the dust port. Frankly, I find the dust collection on this saw to be pretty bad. I think the dust port is too low and should be positioned closer to the lower guide assembly. Positioned where it is, dust is inevitably going to get trapped between the blade and the tire before it makes it to the dust port. Oddly, dust seems to always find a way into the holes in the lower granite wheel:
Going back to the guides, I fail to see why the guide bearings have to be adjusted fully independently. The eccentricity I can understand but the amount of thrust should somehow be locked together. Now I’m not claiming that the Ridgid BS1400 is a better saw but even it has a micro-adjusting screw that moves both left and right guide blocks in tandem. This is especially true of the lower guide assembly where it’s hard to see how far out the left bearing is relative to the blade. I won’t even complain about the fact that the thrust bearings do not have micro-adjusting screws (that are present on even the lowly BS1400).
As with most 14in bandsaws of the cast iron variety, the 50130’s guide post is not perfectly parallel and in lateral plane with the blade. This means that every time you move the guide up or down, you can expect to have to readjust the bearings. It’s annoying but it’s not a show stopper and I’ve stopped worrying about this in light of the “Ugly” issues below (which are of far greater concern).
The Ugly
It’s time now to embark upon the truly nasty aspects of the saw. The following section will be long and detailed and if your stomach has already turned, then I suggest you close your browser down now. Otherwise, proceed at your own risk.
Perhaps the biggest failing of this saw (at least this particular instance of the saw) is that the tolerances throughout are all over the place. We’ll start with the most minor issue. The blade guard that houses the blade on the left side of the saw is made of plastic and is kept in place using two bolts. It’s simple enough except the piece of plastic clearly isn’t straight. A blade under tension, though, is close to being straight so naturally a straight line drawn through a curved channel is bound to result in some tangential intersection (if you’re unlucky). Looking closely at this picture:
you’ll notice that the blade within the guard is awfully close to the side of the guard around the power switch area. Stick a straight edge against the guard:
and it’s clear that the guard is bowing to the left (which is why the blade is riding so close to the right wall). I’ve tried loosening the bolts, pushing the guard straight while tightening down the bolts again in hopes that it would retain its shape but to no avail. Now I’ve stuck a couple of shims between the power switch and the guard to make it straight.
To the more serious issues now….
As I stated above, the upper guide assembly has zero ability to compensate for front/back or lateral shift. If the whole upper guide assembly could shift left or right having to readjust the guides when raising or lowering the guide post would be of minimal consequence. However, this saw suffers from a major problem. With the guide assembly placed on the guide post as shipped from the factory, the right bearing has used up all of its eccentricity threshold and is still touching the blade when the guide post is down:
The blade is actually touching the right bearing which has been turned to be as far right as possible already. But you need not look any further than the thrust bearing to know that something is wrong. The blade is riding ridiculously close to the inner raceway of the thrust bearing. In fact, the snap ring that holds the bearing in place looks like it’s prone to hitting the blade. Now there are a couple of ways to possibly deal with this:
- Shim the entire upper assembly of the saw
- File and shim the upper wheel axle so that the blade shifts over to the left
I haven’t sat down to bust out my trigonometry yet but I suspect the amount of shimming required is substantial. What I’ve done in the meantime is to loosen the set screw that holds the guide assembly to the guide post, shift the assembly down a little bit so that the set screw doesn’t engage in the V-groove of the guide post. That way, I can rotate the guide assembly a little bit to give the right bearing a little bit of clearance. Obviously, though, this presents other problems:
When you rotate the assembly to the right, the bearing edges are no longer parallel to the blade. You can see that for the right bearing, the back touches the blade but there is a gap at the front. Conversely, the left bearing touches the blade at the front while there is a gap at the back.
Another upper guide assembly problem is the fact that the guide bearings can’t project out far enough to properly support even a 5/8” blade:
The bearing edges are quite far from the gullet of the blade even though the shaft that holds them has been fully extended.
The final issue, and the one that I’ve spent the most time (and money) addressing has been saw vibration. I don’t expect a saw of this value to be perfect but the saw vibrated so badly that I was afraid to use it. Unfortunately, as great as SteelCity’s support was in replacing the first saw, they’ve become quite silent for everything else. When I asked again for a replacement Poly-V belt, I was told that they didn’t have stock and that I could get one from Motion Industries. For all that they did for me, I was happy to fork out the tiny cost of getting a new belt. While that helped a little bit, there was still a ridiculous amount of vibration. Trying to minimize the drive train vibration, I bought new V-belt pulleys and a link belt. What’s interesting is that the shafts are all metric. The motor shaft is 16mm with a 5mm keyway while the lower wheel shaft is 18mm also with a 5mm keyway. My understanding is that 18mm shafts are supposed to have a 6mm keyway and this meant that I had to have a custom step key machined just to use a standard 18mm bushing. The new pulleys haven’t eliminated all the vibration from the drive train but I’m content with its performance at this point. This allowed me to turn my attention to the other moving parts of the saw. Surprisingly, the lower granite wheel appears to be remarkably well balanced. Unfortunately, the same is not true for the upper wheel. The upper wheel is so out of balance that it will seesaw back and forth to nearly the same rotational poise every single time. When I took the wheel off to look at the back of the heavy spot, I found this:
There were a hole slew of balancing divots drilled where the heavy spot was but clearly more material needed to be removed (but there wasn’t much more to remove). What’s more, two divots had whitish substance in them. When I picked at one of divots, the debris actually fell through and a hole appeared. I believe the divot was drilled a bit too deeply and there was a paper thin layer of metal left that succumbed when I imparted a tiny bit of force. Here’s the divot with the hole:
I’m uneasy about drilling into the cast iron wheel so I’ve since elected to attach wire to the wheel in hopes of balancing it out (though it’s made minimal improvement only). I’ve told SteelCity about the bad wheel and though initial correspondences indicated they would replace it, they’ve dodged the issue in subsequent correspondences.
In addition to the vibration, I noticed that the blade was oscillating quite violently. This led me first to measure the “out of roundness” of all wheels and tires. What I discovered was that the granite wheel had all sorts of lumps in the crown. It’s difficult to see but it’s either some sort of epoxy or glue.
The lump here becomes obvious when I started to sand it down:
There were also entire areas like this:
The dark areas are all covered with some sort of glue and are raised. All of these contributed to wheel/tire runout. Removing the tires was a mixed ordeal. The top wheel’s tire came off easily with just minor finger strength. The granite wheel tire was extremely difficult to get off (I suspect it’s a bit bigger in diameter than the cast iron counterpart). I had to use a screwdriver to dig out the tire and, in the process, chipped the granite. It was a bit disheartening at first but a little Gorilla Glue and it was good again. Here I am gluing the chip back into place:
What’s ironic is that when I was taking a photo of the wheel brush, I noticed that there was a factory chip repair as well:
This is obviously a chip but the repair job is obviously much better than mine (here for reference):
When trying to determine the root cause of blade vibration, I noticed that there were actually sparks arcing between the blade the roller bearings. At first I thought that my bearings must have been set too close and that the bearings were contacting the blade but I set them further still to the point where I was certain that contact wasn’t the cause of the sparks. I looked around and saw this:
These photos show the tire actually lifting away from the wheel. I remembered how easy it was to take off the tire and suspect that maybe the tires were slipping, building up charge, and then discharging through the blade. I drew a hash line across the tire and onto the rim and then ran the saw. Sure enough, after power-down the hash line on the tire was no longer registered to the hash line on the rim. As such, I ordered a new set of neoprene tires from R&D Bandsaw and there is no longer any slipping (and no sparking).
So how does it perform?
Ironically, I haven’t done much real cutting with the saw because I’ve spent all my time trying to fix the saw. The guide assembly issue still irks me but I’m no longer content throwing my own money at the problem. I believe I’ve repaid SteelCity’s graciousness with my own time and money. As ill set up as the machine is, it at least cuts without any drifting (at least using a 5/8” blade). I haven’t had a chance to do any serious resawing but will hopefully follow-up with a post when I get around to doing that.
It should come as little surprise that I give the saw such a mediocre rating. I don’t believe anyone should have to waste such copious amounts of time and money on a new saw. I’m ambivalent about SteelCity’s customer service (they’ve been exemplary on one hand and rather abysmal on the other). I think the granite components have merit but execution on the other parts of the saw is weak. I’m disappointed that SteelCity didn’t capitalize on the inception of its new saw by addressing all the shortcomings I’ve stated in my review. Save for the granite, I have to say that the 50130 is just another run of the mill 14” cast iron band saw. Perhaps SteelCity is content playing the status quo card but I suspect that if that’s the case, they’ll always be playing second fiddle to the field if they’re playing at all.
UPDATE (09-03-09)
A few updates here. SteelCity did get back to me eventually. They did have some miscommunication internally with the regional rep assuming that a service technician had come out and resolved the issues when, in fact, that person never received the email about my case. SteelCity did follow-up some weeks later and then promptly sent someone to look at the saw. They then replaced the upper wheel and the upper guide assembly. I believe the new upper wheel is better but the upper guide assembly, I’m afraid, likely isn’t going to be rectifiable. The technician who came to look at my saw basically did the same thing I ended up doing which was to rotate the upper guide assembly a little bit to allow for more lateral clearance for the right-most bearing. Of course, the bearing surface isn’t perfectly parallel to the blade face but for now, I’m going to have to live with it.
On a performance note, I would have to agree with most reviews that at least the saw has considerable cutting power. I’ve not had a chance to resaw to the full capacity yet but 6” QSWO seems to be no problem whatsoever. The cut quality is certainly acceptable and there is, as mentioned previously, negligible drift. This is with a 5/8” R&D Little Ripper blade.
With respect to the blade guard blocking the view, I was told that this was a requirement enforced by the standards associations (CSA? UL?). This may be true but I have to wonder why few other companies seem to be subject to this rule.
SteelCity has certainly worked hard to rectify the situation and hasn’t really forgotten the little customers so I do have to give them kudos for their service. Hopefully, SteelCity will do well and thrive despite the corporate changes that have taken place. Perhaps if they weather the economic storm, they’ll make version 2 of this saw a much more formidable contender in the 14” bandsaw category.
28 comments so far
charlton
home | projects | blog
42 posts in 301 days
posted 144 days ago
One thing I forgot to mention was that in order to get the pulleys coplanar, I actually had to shim the motor mount:
Running a piece of string showed a gap between the two inner rims which shouldn’t ever happen (ideally).
2376 posts in 233 days
posted 144 days ago
wonderfull review ,
and im glad i dont need a new saw .
ive got 6 bandsaws already !
Splinterman
4827 posts in 254 days
posted 144 days ago
Great review Charlton…....but sad that the new saw turned out to be such a hassel.
Ryan Sparreboom
85 posts in 144 days
posted 144 days ago
A thorough (if not overly nit-picky) review.
It is apparent that you got a lemon, something very uncommon for Steel City. Why you haven’t returned the saw to Steel City to deal with all these issues under warranty is beyond me. The saw has a great 5 year warranty and 10 yrs on granite parts. Instead you’ve tryed to fix everything yourself, likely voiding the warranty.
I own the same saw and have NONE of the issues you have with the upper bearings/guide/wheel alignment/balance/vibration etc.
The only point that my saw also has is the cheap plastic left blade guard on the left. Yes the blade rubs it. Yes it could have been better. But a simple shim holds it in place and now the saw runs perfectly. Cuts like a dream.
Boom
Rileysdad
10 posts in 171 days
posted 144 days ago
Thanks Charlton for a great review. You just saved me from a really bad purchase. Now, please buy a Grizzly GO457 and let us know what you think.
-- Measure twice, cut once, buy extra stock.
PurpLev
2732 posts in 541 days
posted 144 days ago
yikes!
thanks for the review. well put, lots of info, and in a very enjoyable manner.
sorry you had to go through so much pain and misfortune. this really shouldn’t be how things work.
PS. if you position the work light UNDER the table – you’ll take care of 2 things – 1. light won’t interfere with quick release lever, and 2. you’ll have ample light at the lower blade guides…
16598 posts in 469 days
posted 144 days ago
great review
DaleM
401 posts in 276 days
posted 144 days ago
While I have only the model 50100 with riser kit which this review started with, and not the 50130, I also believe as someone else stated above that you possibly got a lemon. I would think it possible that I got lucky in getting a good saw, but since I haven’t seen any other bad reviews, I have to believe for now that my good experience is the norm. I can’t speak for the newer model, but I have almost no vibration in my saw. Some of the features are common to both saws, such as the roller bearings. I find the bearings easy to see and easy to adjust (for me) and have not had the problem with the alignment being out of the range of the adjustment. I would highly recommend the 50100 to anyone, and they are still available.
-- Dale Manning, Carthage, NY
charlton
posted 144 days ago
Boomr99, this is the second saw that’s exhibiting gross vibration. I actually made SteelCity aware these issues…they were the ones that recommended a new belt. They also recommended new tires from R&D bandsaw telling me that their tires are the best. I even mentioned that I would consider swapping the pulleys/belts and there was never any indication that doing so would void the warranty. In my last correspondance with them, I reiterated that the upper wheel was grossly out of balance to which I go the reply, “Thanks for keeping me updated. I’ll pass this information along to engineering.”
I do think I got a lemon because another member has the 50130 and he thinks it’s perfect. Part of the reason I went down this whole rabbit hole is because when you get two lemons in a row, you start to think that maybe it’s your ability to set things up (granted the only thing to really set up is the belt).
DaleM, I believe SteelCity has received complaints about excessive vibration when the riser kit is installed. In one case, they replaced the person’s saw with the 16” saw (since the 50130 wasn’t available). I don’t recall whether the knob blocks the view of the lower guide assembly on the 50100…the trunnion is a bit different to accommodate the weight of the granite table.
Rileysdad, I would love to try a G0457 but as I mentioned, you can’t get them here in Canada and the Canadian equivalent (Busy Bee) just doesn’t have the same selection and quality that Grizzly seems to have.
DaleM
posted 144 days ago
Thanks Charlton. I do have the riser kit installed. It sounds like a quality control problem since it appears some of these saws never should have made it to the buyers. I’m glad I got one of the good ones, because when it works the way it’s supposed to, it’s a good saw. Sorry to hear you weren’t so fortunate.
charlton
posted 144 days ago
No worries, Dale. The vibration is bearable now and as long as I can get the saw to cut well, the guide issue can be overlooked.
Tim_456
45 posts in 488 days
posted 144 days ago
Thanks for the review, when I’m in the market for one of these, I’ll definately think twice about this brand.
woodfly
14 posts in 241 days
posted 144 days ago
Thanks for the review. I liked the detail, and I can tell you, I feel your pain. I bought a SC granite TS. (posted a review a few weeks ago) and my experience with SC customer service was much like yours. They seemed helpfull initially but after the first couple of conversations, they became non responsive and would not follow up on their promises. If you get lucky and get a good piece of SC equipment from the beginning you need to consider yourself foutunate. I do not see a bright future, if any future, for Steel City.
-- Mike
Roper
756 posts in 605 days
posted 143 days ago
very indepth review, i am glad i just bought thr rikon, no problems so far, knock on wood.
-- Roper - Master of sawdust-
25795 posts in 1293 days
posted 143 days ago
Great review of your experiences. Sorry for your problems.
closetguy
303 posts in 784 days
posted 142 days ago
I have the same saw, non-granite, that I bought a little over a year ago. I have not experienced any of these problems. The bearings are square with the blade and the top thrust bearing is positioned so that the blade doesn’t come close to the inner raceway. It’s interesting that they have windows on the blade guard because mine doesn’t have them. My only complaint is that every adjustment on the saw has a knob or thumb screw except for the blade guard. Every time I change blades, I have to go get a phillips screw driver which is real inconvenient. I guess SC is like everyone else in that their product quality is not consistent. I still think it’s the best 14” bandsaw for the price.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
Durnik150
536 posts in 214 days
posted 140 days ago
Great review. Sorry you are going through all these silly little problems that add up to big ones. It points out things anyone in the market for this size saw to keep an eye open for.
Thanks for taking the time to write it all up and good luck getting everything running well.
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
wfrs21
3 posts in 76 days
posted 76 days ago
Charlton,
If you were to buy all over again…what would you buy? I’m in the market for a bandsaw in this price range and size.
charlton
posted 75 days ago
It’s a tough call. In Canada, there aren’t that many choices. If I wanted to get one on the cheap, I’d probably go with a King bandsaw. If I was in the States, I’d almost certainly look at Grizzly.
Otherwise, I’d probably go all out and just buy a Laguna/Hammer bandsaw. It’s substantially more expensive but after this experience, I think the bandsaw is the one machine that has enough mechanical linkage to make it worthwhile to get truly quality components for. But vibration is only half the picture…some of the usability issues I’ve stated in my review make me shy away from recommending it.
KAZman
13 posts in 74 days
posted 74 days ago
Charlton:
I am BRAND new to this site and I came here specifically to find input on Steel City’s Deluxe Bandsaw——THANK YOU!!!
I’ve emailed them numerous times asking for any customer inputs or reviews – nothing but “we’ll get back to you”. Went through their archives to find another access point (like their president Scott Box) and had ALL emails returned undeliverable. I even went to WoodCraft’s team asking for input——nobody had anything until I ran into your review. THANK YOU, again!!!
I’m ready to buy a new bandsaw and loved the features and price of the SC unit – especially for resawing and am glad I didn’t order it. My sense is they may not be a long term player.
This is my first post but I will post, elsewhere, a plea for a recommendation for a viable and respectable bandsaw with reasonable resaw capacity….. If anyone has a recommendation – PLEASE help!!!
Again, THANK YOU CHARLTON!!!
Kaz
-- KAZman, Hot Springs Village, Arkansas
rodman
4 posts in 29 days
posted 29 days ago
Charlton, thank you for such an in depth report. I am new here and new to band saws. After doing my research I decided on and purchased the 50130.It seemed like a good bang for the buck. Now after spending the last three frustrating days trying to get it set up and properly adjusted, I thought I’d visit a few forums to see if there were other saws out there that were, like mine, proving to be difficult to use. After reading your report, I know now that the problem is not just with my saw, as every single one of the issues you had, I am also dealing with. Some issues are a result of terrible design, and others are a result of what can only be terrible quality control at the factory. In other words, this Steel City product is just another offshore POS. I am curious to know how your saw actually cuts wood, now that you have spent the time and $$$ to get it set up to an acceptable level. I am planning to use this saw for some resawing and veneering – nothing too large but I do need accurate, repeatable cuts. Thanks again for a great post and I hope to hear back from you
charlton
posted 28 days ago
Hey Rodman,
Even though the thing still vibrates a fair amount and setting up the adjustments is a pain (it could be so much better), the saw cuts acceptably well which is pretty much the reason I haven’t sold the thing off. I’m using a Little Ripper blade and, so far, the cuts have been at least reasonably straight. Obviously the resawed surface needs cleanup (and I suspect a little more so than veneers sawn off other bandsaws) but the cleanup isn’t too bad since the surface is almost like it’s been treated with a toothing plane.
One of these days, I may upgrade to a better saw but for now, this thing is going to have to suffice, warts and all.
Good luck!
Charlton
rodman
4 posts in 29 days
posted 28 days ago
Hey Charlton!
Thanks for the reply.
I guess the question, then, is this…..Considering the price point, and what else is available for the same $$$$ and features,if you could, would you return the saw and buy something else?
Again thanks for your imput
Jerry
charlton
posted 28 days ago
Hey Jerry,
Yes, I would. Since you’re probably in the States, I’d look at the Rikon 10-325 or one of the steel Grizzly’s. I wouldn’t consider another one of the 14” cast iron bandsaws.
Charlton
rodman
4 posts in 29 days
posted 28 days ago
OK and thanks again Carlton,
Actually I am north of the 49th….looks like I’ll continue shopping. Well taken advice regarding the cast iron units also….
Jerry
chrisnj
1 post in 23 days
posted 23 days ago
I just received my Steel City 50130 from Woodcraft after a four month wait for it on backorder. I have not tested it extensively, but so far it does not appear to have any of the issues reported in either the main review or in the follow up comments.
The only “issue” so far is the very minimal clearance between the front rail and the bottom door, as
described by charlton. It is annoying more than really problematic.
A few test cuts yielded very good results, and a fairly quiet and smooth running saw.
Chris
rodman
4 posts in 29 days
posted 23 days ago
Glad to hear that Chris, it sounds like you have received a good one. After discovering all of the “issues” I had with my saw, and especially after seeing that someone else had the exact same issues with the saw they received (Carlton), well needless to say I was a little discouraged. But I do need to acknowledge the excellent service I received from the Steel City area representative, after describing some of the problems I was encountering. He acknowledged having heard some of the complaints before, and offered some suggestions for a fix. As an example, to reduce or get rid of the vibration, he suggested to adjust the tensioning bolt that tightens the drive belt pulley, as well as to position the belt on the pulleys so that the saw runs at the lower rpm. And much to his credit, (and probably a testament to Steel City’s commitment to customer service) when I asked him how to adjust the rip fence to allow for blade drift he replied that on that fence there is no adjustment, and if that was an important function to me, then it was the wrong saw for me, furthered by the fact, as he explained it, the aftermarket fences that are adjustable do not fit on the SC granite table. So even though I had made a slight alteration to the saw, he authorized me to return it to the vendor for a full refund.
So, I was unlucky , and got a lemon. But my hat is off to Steel City for the excellent customer service I received.
Chris you have the best of both worlds – you have a good tool AND great customer service if you ever need it.
UPDATE
So as it turns out,maybe I wasn’t so “unlucky” after all…...after returning the SC50130, I did lots of homework to select a replacement, and now I am waiting for my Laguna LT16HD, driftmaster fence, and resaw king blade…...I feel like a kid waiting for Christmas morning!!!
Jerry
PS as a newcomer to this site,I would like to say thanks to the so many people who welcomed me to the site – Thanks to all…...
charlton
posted 23 days ago
It’s good to hear that the saw is acceptable for some. Some people on other forums have already relayed positive experiences with the saw so it could be that I just got a lemon (or two) but Jerry’s experience certainly seems to indicate, to me at least, that there is at least some QC problems.
I would be super happy if SC was willing to authorize a full refund but that isn’t going to happen now.
Enjoy the LT16HD, Jerry. You have me filled with envy. :)
