Craftsman jointer
Review by Spoctor posted 06-12-2016 10:50 PM 4875 views 0 times favorited 7 comments Add to Favorites Watch
Craftsman jointer No-picture-s No-picture-s Click the pictures to enlarge them
I work at Sears and had walked by this jointer many times, noting its $229 price tag. I walked by it again the other day and saw that it was being closed out at a fraction of that price. I jumped.
It had been on display for a good while. The blade guard had been broken off and the spring lost. The push blocks were also missing, but those are easy to replace. The safety key was missing from the power switch. Fortunately, three of my other power tools have keys that fit it.
This jointer weights 57 lbs., has a solid feel, and runs with little vibration. It has a granite infeed table, outfeed table, and fence. They are glassy smooth and offer little resistance to the workpiece. The fence is set just slightly too far back, so the workpiece will have a slight ridge at the very back. This problem can be solved by placing a thin washer over each mounting bolt between the fence and mounting bracket.
I was surprised at how quiet this machine is compared to my other shop tools. Also, the 2 1/2” dust port does a great job when connected to a shop vac.
One or two downsides. While common parts like bolts and washers are still available, many of the unique parts are not. The drive belt and blade guard, for example, are no longer available. The cutter assembly had a good deal of cosmoline on it which spattered on the infeed table during operation. It took a while to clean the cutter assembly with a tar remover. I attempted to remove the blades for cleaning but all eight bolts were so tight I was afraid I’d bend the allen wrench.
At this point, I have only attempted to remove 1/32” at a time from a 2×2 piece of oak. This jointer does that with ease.
Overall, I am very pleased with this jointer. Maybe that’s because I actually enjoy refurbishing a basically sound tool.
View Spoctor's profile
Spoctor
8 posts in 623 days
7 comments so far
View diverlloyd's profile
diverlloyd
2525 posts in 1767 days
#1 posted 06-13-2016 10:05 PM
are the bolts the hold the blades left hand threads? and how do you like the granite?
Spoctor
8 posts in 623 days
#2 posted 06-13-2016 10:33 PM
The bolts are right hand threads and I did finally break them loose but it felt like the small allen wrench was going to bend or even break just before they broke loose. I actually like the granite so far. There is almost no drag and rust will never be a problem. Also, the granite is dead straight and square. I read a review where a fellow had something heavy fall on his brand new jointer and it broke one of the granite tables. A cast iron table wouldn’t have broken, I guess, but I’m fine – and careful – with the granite.
View lcwood's profile
lcwood
216 posts in 2674 days
#3 posted 06-14-2016 04:08 AM
sometimes this can help: do a small tap with a hammer in the screw head to unlock it before try to unscrew it
runswithscissors
2658 posts in 1934 days
#4 posted 06-14-2016 04:41 AM
Another way to loosen stuck screws is to cut off an allen wrench of the right size and figure out how to chuck it in an impact driver. You have to fiddle around with various driver combinations to make it work (sockets, square drives, etc.). The impact driver can loosen most anything. Be sure to apply lots of pressure so the hole doesn’t round out.
Spoctor
8 posts in 623 days
#5 posted 06-14-2016 01:18 PM
I had thought about the impact driver solution but I would have had to buy some things so I just worked at it until the allen wrench finally broke them loose. Yes, the allen wrench now has a bit of a curve to the long end. I had forgotten about the hammer tap trick. Thanks for reminding me!
View Bill White's profile
Bill White
4862 posts in 3870 days
#6 posted 07-17-2016 02:39 PM
Check with Cutech for replacement parts.
Bill
-- bill@magraphics.us
Spoctor
8 posts in 623 days
#7 posted 07-19-2016 08:03 PM
Bill,
I see one 6” jointer on Cutech’s site. I can find no specs for their drive belt. Are you sure that belt will fit my jointer or are you just giving me a possible alternative?
