| Review by CutNRun | posted 151 days ago | 723 views | 0 times favorited | 15 comments | ![]() |
- DeWalt MBC Release 25
- Brand: DeWalt | Category: Radial Arm Saws
I have always liked radial arm saws. My first power tool purchase was a Craftsman radial arm saw. I only had the one saw and I could do most operations with it – ripping, cross-cutting, mitering; all achievable. The Craftsman (long gone) couldn’t hold a candle to the accuracy of this saw. The arm is cast iron that was aged prior to having the ways machined. The motor was a special built unit that has a flat bottom for extra clearance over the cutting surface. I purchased this saw off of Craig’s List for $25.00. I have since put ~$200.00 into the table, cabinet and mobile base, but have a saw that is very accurate, if a bit underpowered.
It will cross-cut 14” wide stock. With a dead flat table, I was able to use a dial indicator and adjust the table parallel to the arm to within +/- 0.002”, front to back and side to side. This dimension is repeatable after the arm is moved and returned to the previous position. The same can be said for the squareness of the blade to the table (+/- <0> tool. Any power tool can be dangerous when not used properly. I see this old DeWalt as a welcome addition to my shop.
-- CutNRun - So much wood, so many trails, so little time
15 comments so far
Dusty56
home | projects | blog
3466 posts in 583 days
posted 151 days ago
An oldie but a goodie…....so true ! Congratulations on your purchase ….nice looking saw : )
CutNRun
122 posts in 741 days
posted 151 days ago
Forgot to mention – I found another MBC and an MBF (same saw with 3/4 HP motor) for $20 each, again on CL. I will pick them up tomorrow. Not sure where I’ll put them, but couldn’t pass up the opportunity.
Bill White
111 posts in 855 days
posted 151 days ago
Oh you dog. I sure would like to have one of those puppies. My 1978 C’man has served well, and is still in use for crosscutting now that I have a TS. Well done. Are ya sure that ya don’t want me to keep it a while? You Know, wax, polish, drool….....
Bill
pommy
958 posts in 586 days
posted 151 days ago
I’m with you as far as oldies are better i love older tools what ever they maybe its simple logic THEY SIMPLY DO NOT MAKE THEM HOW THEY USED TO ….............
Andy
-- cut it saw it scrap it
hafwit
8 posts in 511 days
posted 151 days ago
Hey, I have a slightly (just barely) newer version of that same saw. It’s no where near the condition of yours, but it works great. Nice find!
Heavy, isn’t it?
-- Pete
JustinMcCurdy
4 posts in 151 days
posted 151 days ago
Nice work. I just finished a GWI 58’ and am working on an MBC 58’ to match. There is a lot more work invloved than meets the eye. I am hoping to avoid having to paint it though.
16841 posts in 472 days
posted 151 days ago
cool saw
Splinterman
4826 posts in 256 days
posted 150 days ago
The plastic fantastic range of tools today afre nowhere near this kind of quality…..good one CutNrun.
Occie gilliam
310 posts in 191 days
posted 150 days ago
How true, i bough a used craftsman that was made in the eightys and ite not so good
thanks for the head”s up
-- Occie down in Costa Rica. come down and see us some time. I'll keep the light on for you Occiegilliam@yahoo.com
hokieman
50 posts in 649 days
posted 150 days ago
I believe the RAS is the most underrated power tool in the shop. As you said, you can do most all operations on it that you can do on a table saw. When I first started woodworking 25 years ago that was my first purchase. Yeah, ripping on it can be a bit hairy but I just like it’s versatility. I find cutting dadoes on it easier and safer. the tool you got is awesome. You found a good one!
Derby
27 posts in 167 days
posted 149 days ago
Looks great!
I have an MBF Rel. 206 saw in the corner of my shop that I’ve had for several years without using. Everything I’ve seen on the net says it’s a 9” saw but I haven’t been able to find anything bigger than 8-1/4” in my area.
Any suggestions about sources for blades and replacement knobs? Is/did your MBF come with the metal base cabinet as well?
-- "Lumber is just sawdust in 'solid' form!"
gdickey76
16 posts in 183 days
posted 149 days ago
Great saw. I have an old 12” DeWalt GP. These are great machines. I built my new shop with it. Wouldnt mind having another one just for cutting angles. Old machines are the best in my book. I wouldnt trade my old ones for the best new one out there now. They are well built.
CutNRun
posted 149 days ago
Derby – Forrest Sawblades offers 8” and 9” models. They actually have an 8” blade specifically designed for radial arm saws. You can also locate some Freud 8” blades on Amazon. For the low powered MBC’s and MBF’s, people often recommend thin kerf 8” blades. You can find a lot of information on the DeWalt saws at
http://people.delphiforums.com/snotzalot/sawdust/
You can also learn a lot at: http://www.owwm.org/
As for parts, you can try Original Saw Company, or Wolf Machinery on-line.
My MBC didn’t come with any cabinet, nor did the second MBC or the MBF that I picked up over the weekend. I may part out the MBC, or just keep it for spare parts myself. I expect to refurbish the MBF.
25801 posts in 1295 days
posted 149 days ago
Great looking saw. The proof is in the performance. And it sounds like you have it tuned in.
Steuss
22 posts in 425 days
posted 148 days ago
I’ve had a 7770 DeWalt 10” radial-saw since before 1980 when I bought it new. It’s a wonderful saw and the older ones (such as yours) are actually better saws than mine. Between this saw and my Delta 10” Contractor Saw, there is nothing I can’t do in my shop. I actually designed the Eze-Angleguide for use with this saw to cut angles without swinging the arm and sold 13,000 copies of it nationwide. And I made every one of them myself on this saw. You’ll really enjoy this saw and never will you need another—they last forever.
-- Dick, Novato
