Rikon lathe stand leg personal opinion
Review by playingwithmywood posted 05-19-2016 02:37 AM 2665 views 0 times favorited 0 comments Add to Favorites Watch
Rikon lathe stand leg personal opinion Rikon lathe stand leg personal opinion No-picture-s Click the pictures to enlarge them
I understand why Rikon made the legs of this stand the way they did since it is a universal stand and this design is to make it as stable as possible in all situations
but they have always annoyed the heck out of me and since the stand came with the lathe since I bought it used I finally solved the annoyance myself and only wish I would have done this sooner
I share this cause others might be having the same thoughts of annoyance
well I cut my bent legs at the angle weld and then welded them straight again
problem solved and at least in my shop the stand seems just as sturdy as it did before and now the legs do not catch on other things in the shop when I move it around
if you do not have a welder a few feet of square tube and a few holes drilled would get the same result with less effort
anyway I still give it 4 stars since I still like Rikon and the products does work like it should even if I did not personally like how the design worked in my situation and the tubing I cut and welded was a lot thicker wall than I thought it would be before I went to cut it up
View playingwithmywood's profile
playingwithmywood
418 posts in 1625 days
0 comments so far
