upgrading HF dust collector to cyclone with Grizzly and Wynn
Review by playingwithmywood posted 05-18-2016 12:49 PM 7769 views 10 times favorited 10 comments Add to Favorites Watch
upgrading HF dust collector to cyclone with Grizzly and Wynn No-picture-s No-picture-s Click the pictures to enlarge them
Ok First
if you have not bought a dust collector do not do this project instead go ahead and buy the biggest cyclone system you can afford because if you are like me your tools will grow and you collector will become too small
Like many I started with a HF collector and put in the home-aid Thein baffle and a Wynn filter when I first started out
This was good until I got a bigger joiner and more tool but I always hated the bag and the fact that all the chips were going thru the impeller
so like many others seeing people convert the HF collector to the top hat design
or now people buying the super dust deputy or other pre separators
I wanted and needed to upgrade but I did not like any options I had seen others do
so thats when after much debate I found Grizzly G0703P and then found I could by the cyclone part out of this unit for less than the plastic super dust deputy (yea I used a grizzly coupon to save money ) but still this is a metal cyclone for less money
so I guess you can see from the pictures and I am not going to go into assembly but the advantage is I was able to bolt the HF impeller directly too the grizzly cyclone using a piece of plywood as a mount between the two… this is what I did not like about the super dust deputy was the extra hose to the impeller this way I got a much more compact system made of metal
I still have a center tube in the cyclone but that is just a piece of metal duct that is working fine and is easy to remove with one screw
I also cut a hole in the top of the Wynn filter to add a flange and reused the original HF hose
anyway if I had it to do it over again I would just buy a pre-made cyclone system but since what is on the market today was not when I got started I still came out not spending to much extra money for the upgrade and have so far a good working system. This is well worth the time and money spent
I hope this helps someone and I will try to answer any questions but I did not document this well as I went so I only have the finished photo but it still needs a coat of paint
View playingwithmywood's profile
playingwithmywood
432 posts in 1832 days
10 comments so far
View CharlesA's profile
CharlesA
3358 posts in 2032 days
#1 posted 05-18-2016 02:09 PM
Glad it worked out for you. I’m a little confused by your narrative. When you had your first Thien baffle installed, wasn’t that installed so that the chips didn’t go through the impeller? I know mine is.
playingwithmywood
#2 posted 05-18-2016 02:31 PM
Glad it worked out for you. I m a little confused by your narrative. When you had your first Thien baffle installed, wasn t that installed so that the chips didn t go through the impeller? I know mine is.
- CharlesA
My narrative does suck but we are talking dust collectors
Well before people started building top hats the baffle that everyone first built went between the filter and dust collection bag so it was after the impeller this worked good at the time to put the chips in the bag and keep them out of the filter
here is a link showing the type baffle that I had
http://www.jpthien.com/smf/index.php?topic=145.0
View StumpyNubs's profile
StumpyNubs
7689 posts in 3035 days
#3 posted 05-18-2016 02:47 PM
I will be very interested to hear how this works for you long term. The HF impeller is quite small and I wonder if it will move enough air to power a cyclone of that size while still keeping the ducts free from dust buildup inside. It looks like you are using 6” hose. Are you also using 6” ducts?
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View nkawtg's profile
nkawtg
281 posts in 1486 days
#4 posted 05-18-2016 05:23 PM
I like the ingenuity of the project.
Well done.
playingwithmywood
#5 posted 05-19-2016 12:23 AM
Well done.
- nkawtg
thanks I was trying to make it as compact as I could and so far I am happy and it after lots of thinking and thinking about it and hopefully the way I did things can help a few people with their systems
playingwithmywood
#6 posted 05-19-2016 12:39 AM
- StumpyNubs
nope that is just 4” hose that I was using before this setup. I do plan on doing the 6” thing and I hope I do not end up with the problems you mention but as of now I do not see any reduction in performance with this setup. I do wish I had a head to head to compare it to the system grizzly made the cyclone for and to compare it to the super dust deputy. I still think this is a better option than the super dust deputy because I figure with this direct connection cyclone impeller collection
The key is it is working the barrel is filling and the filter and filter bucket is staying clean
the grizzly part is
P0703P013 CYCLONE FUNNEL ASSEMBLY $141.00 (not including shipping)
and the super dust deputy is about 169.00 (not including shipping)
I still think this is a better direction when trying to upgrade a system already owned and buying a semi pre made solution
View Andy612's profile
Andy612
3 posts in 1013 days
#7 posted 05-20-2016 02:16 PM
I did something similar with the following differences:
- used a Super Dust Deputy
- Shop Fox 1.5HP which has a 12 inch impeller
- the rotation of the impeller matches the rotation of the cyclone so they operate together
Like the OP I connected the Deputy directly to the impeller so no duct or flex between the two. I also upgraded to 6 inch metal duct to replace all of my flex hose apart from the connection between duct and machine (about 6 ft).
Have measured my CFM using a flowmeter and am getting around 900 CFM at the 5 inch machine port which is close to what I wanted when I set about hacking my new DC.
I still use the poly bag under the Wynn filter but have a 30 gallon fiber drum under the cyclone which collects all of the dust. Only a few spoonfuls are in the poly bag since I set this up a few months ago. I do check the ducts periodically and they stay nice and clean with this flow rate. As per StumpyNubs comment, I would recommend getting the bigger impeller as the next step as it seems to provide a lot of bang for your buck
View Mainiac Matt 's profile
Mainiac Matt
8609 posts in 2563 days
#8 posted 05-20-2016 03:18 PM
One of the things I really like about Grizzly is their parts support.
And they’re making it easier and easier to find the parts you want and order directly off the web site.
When buying near identical Taiwanese import machines, I try to go with Grizzly, because I know they will support what they sell.
-- I yam what I yam and that's all what I yam
View gotnonickname's profile
gotnonickname
29 posts in 1807 days
#9 posted 07-17-2016 03:41 PM
I too have gone down the road of building my own system. my first design is shown is posted on this site a year or so back. It used the HF portable vacuum, the plastic version of the Super Dust Deputy and a Rockler 5micron bag. I also purchased the 16 gallon dust can which matched the SDD. System worked well. I was lucky that I could wheel it outside when ever I used it. What more suck, so bought he HF 2hp system when I had a super coupon and it was on sale. Got more improvement, but still not satisfied. Changed the HF impellor with Rikon 50-200c impeller. Now it`s getting better, so I had been using this update for 6 months with the goal of updating to a Wynn filter. Just did that and boy does the system now suck. Added a magnehelic to the filter inlet so I could monitor when to blow down the filter. Table saw now works well with zc inserts and router table is now dust free. The system is still mobile and compact. Will try to get some time to take a pic and post it.
playingwithmywood
#10 posted 07-18-2016 05:33 AM
- gotnonickname
did rikon sell you the empeller with no trouble?
did you measure amps before and after the impeller change ?
