Freud Quadra-Cut Roundover Bit "Wow"
Review by Pete_Jud posted 161 days ago 749 views 0 times favorited 11 comments Add to Favorites Watch
Freud Quadra-Cut Roundover Bit "Wow" No-picture-s No-picture-s Click the pictures to enlarge them
I just ran 300 feet of 1.5 inch doug fir stair treads over a 3/4 inch Freud roundover bit on the router table to bullnose the work. I was very concerned about “tearout” as the old growth doug fir had a lot of tight knots in it. I had no tearout at all, and the I cut the bullnose in just 1 pass per side. The work is ready to install without any sanding. Great finnish. And almost no pitch buildup on the bit. This is the first Quadra-Cut bit that I have used, and I am impressed.
-- Life is to short to own an ugly boat.
View Pete_Jud's profile
Pete_Jud
116 posts in 649 days
11 comments so far
2439 posts in 237 days
posted 161 days ago
thanks , this sounds like a winner !
how many bits do they make like this ?
View JimBuchanan's profile
JimBuchanan
26 posts in 245 days
posted 161 days ago
I’m glad you had a positive experience with these bits, too. They aren’t cheap, but they perform so well it’s worth it.
-- Jim
View spanky46's profile
spanky46
737 posts in 287 days
posted 161 days ago
Good to hear!
-- spanky46 -- Never enough clamps...Never enough tools...Never enough time.
View tenontim's profile
tenontim
1319 posts in 641 days
posted 160 days ago
I was impressed with the 3 wing bits that are out, so I can imagine the cut you get from the 4 wing. Thanks for the review.
-- Tim -- http://tmuli.com
20725 posts in 718 days
posted 160 days ago
Pete, thanks for the review. I have not purchased a lot of bits from Freud but I have been looking at these and wondering if they performed as well as advertised. Based on your review I will have to add some of these to my collection of bits.
View Kent Shepherd's profile
Kent Shepherd
833 posts in 182 days
posted 160 days ago
I have that same bit and I love it. I would highly recommend it. Of course I used it in a Festool Router (Hand held)——I guess that’s cheating, huh? I’ve used other quadra-cut bits in my “normal” routers, and they really are good (The bit, that is!)
patron, Looks like Freud makes about thirty-one bits right now in the Quadra-cut—-12 profiles (different sizes of several of those) I’m sure they will be adding others as time goes on.
View Rob Drown's profile
Rob Drown
324 posts in 729 days
posted 159 days ago
I tried the roman ogee. It replaced a high speed steel bit. What a huge step up. Wow do they cut fast and smooth!!! They are a very good buy.
-- Sharp tools and thin whispy shavings make woodworking a joy.
16926 posts in 473 days
posted 159 days ago
I have some there great.good review
View Carl Henderson's profile
Carl Henderson
14 posts in 158 days
posted 158 days ago
I have about 30 Freud bits and have been very happy with them all. I also have about 1/2 a dozen from Lee Valley … they too have been very good. Have used these on pine, walnut, cherry, cedar and maple. I usually have to sand the end grain for most profiles..
-- Softouch
View roman's profile
roman
1124 posts in 790 days
posted 158 days ago
All wood that is “routed” needs sanding, regardless of the make, the feed speed, or the router
skipping sanding is just …............silly
View EPB's profile
EPB
1 post in 233 days
posted 156 days ago
I have several of the Quadra bits now after my first experience with their reverse ogee bit. They do cost more but do such a good job and the sharp edge holds up.
-- EPB
