| Review by Don K. | posted 147 days ago | 2141 views | 3 times favorited | 31 comments | ![]() |
- Grizzly G0690 10" 3 HP Cabinet Saw
- Brand: Grizzly | Category: Tablesaws
Well, I have finally used my saw enough to do a proper review for you. As many of you know…I did some up-grades in the shop…..with a new 8” Jointer, http://lumberjocks.com/reviews/705 , A new 15” Planer http://lumberjocks.com/reviews/755 , a new 17” Band saw (No review yet) and a new Cabinet saw.
You can ask A1Jim, Todd C., Lenny and a few others….I about drove myself and them insane trying to decide what saw to buy…at first I was looking at a Steel City with a titanium top…..but with all the talk about them maybe going out of business…I decided against that.
I then narrowed it down between this saw, and a Powermatic pm2000…and while you can never go wrong with a Powermatic Pm2000….with as many new tools as I bought…every penny counted.
I was MORE than happy with the 8” Grizzly Jointer I bought…so I decided to go ahead and buy the Grizzly G0690. Here are some pictures of it in my shop…(Do not laugh, my shop is a wreck at the moment)
Let me start off by saying…. ”I LOVE THIS SAW” ...assembly was a breeze….Nickle test ??? Try a “Pocket” full of nickles….I lined up 12 of them and fired it up, not a one fell, then I turned it off, got some wood, fired it up again and made a few cuts…and again nothing fell.
Power ??? after years of using a contractor saw and one wore out unisaw…I really did not know what to expect….but it passed any expectations I may have had. For the last week and a half I have been shoving 2” thick mahogany, red oak and maple through it….and I may as well been pushing paper through it. This thing sounded like a jet engine starting up in my shop…not in a bad loud way…just sounds powerful.
It has a great quick connect riving knife and splitter, just pull a pin, pull it out, switch them or put one in…all in about two seconds. The trunnion in this thing is a MONSTER…and I mean BIG….those cast wheels for adjusting…smooth as butter. Once you get it going, you can give it one good spin and it will almost free wheel all the way the other direction.
The cast iron top is so smooth and shiny it almost looks like a mirror, (In the second picture…that is not rust…but the reflection of the yellow box on my radial arm saw…now that’s like a mirror). It comes with a factory blade insert and a dado insert, I ordered a zero clearance insert for it when I bought it ($26). While I will upgrade the miter gage in time when I find one I like on sale. The factory miter gage is actually pretty good and can be adjusted to take out all play in the T-slot miter tracks.
The fence is a knock off of a Biesemeyer fence…but after a little adjustment, it is straight as a arrow when wood is ran through the blade and down the fence.
About the only bad thing I can say, is not even about the saw…but about the shop fox mobile base I bought for it. Some of you who may remember my review over my Jointer, may remember me saying I do not like these factory base’s…that I prefer to make my own. Well I did the math…and for what I pay for the good casters I use http://lumberjocks.com/reviews/701 , I could buy a shop fox and have one together in a few moments. BIG waste of money imo…..the shop fox is rated for 700 lbs (So it says) My saw weighs in around 600 lbs…if you look real close at the pictures….you can see the wheels are already starting to bend out…I had the adjustment all the way up after a couple of days…and the rubber feet still dragged on the floor.
Since these pictures were taken…I have built my own mobile base and tossed the factory base in the storage building….I may use it someday on a smaller piece of equipment (But I doubt it).
But back to the saw…there are MANY and I mean MANY good saws out there for almost every price range. But if your looking for a power house of a saw…loaded with extra bells and whistles (But not so many that it is a pain) that cuts very true and accurate…I recommend trying out the new Grizzly G0690. I am pretty sure I just bought my last saw !!!
Edit: I forgot to add, the only tools you will need for this saw is a Phillips screw driver, a good straight edge, a 1/2 or 13mm wrench and socket and what every you wish to use to align your blade, fence etc….Grizzly sends you almost every tool you need to assemble your tools….and while they may not be “Snap-on” quality..they are not punched metal either. You get a full set of long allen wrench’s with a holder and a couple of wrench’s with the saw its self, including two big heavy wrench’s for blade changes. And then in each and every box, (Guard, fence, inserts etc) there is also the tools you will need to install just “That Piece”
Also, the directions say “Assembly time 1 hour”...lol…this may be true for a mechanical engineer….or if you want your square cut to be a triangle…..but plan on atleast 5 to 6 hours of assembly time. I get a little “Obsessive” when it comes to trying to get my tools to a perfect tolerance…I know this is impossiable with any tool…but I try anyways. With help, you can get this saw together and all the alignments done in about 3 1/2 to 4 hours….By yourself….between 5 to 6.
-- Don S.E. OK
31 comments so far
TopamaxSurvivor
home | projects | blog
2814 posts in 554 days
posted 147 days ago
Probably a good time to buy Grazzly stock:-) Glad yoiu’re happy with it.
Lenny
117 posts in 405 days
posted 147 days ago
Don, a well-written review and nice endorsement of the saw. It should prove very helpful to other LJers. It sounds like you have been putting it to good use already. Best wishes as you continue to push wood through it!
-- And on the eighth day God was back in His woodworking shop!
knotscott
489 posts in 254 days
posted 147 days ago
Good review Don. Glad to hear you like it. It looks to me like you could slide that front rail tube over to the right to gain some additional rip capacity if you wanted….you’re not likely to need the left side capacity on a left tilt saw. I did that on my former 22124 and my current Shop Fox 1677.
Is that a DeWalt PT blade I’m seeing?
Congrats and enjoy!
Scott
ND2ELK
6065 posts in 652 days
posted 147 days ago
Hi Don
Great looking saw! It sounds like it will be a good unit for you. Excellent review and thanks for posting.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
20052 posts in 700 days
posted 147 days ago
Don, this is an excellent review on the saw. I have always been impressed with Grizzly tools and their customer service is top notch. It sounds like you have a quality saw with this purchase that will give you years of service and be a pleasure to use.
Brad_Nailor
1192 posts in 835 days
posted 147 days ago
Don
Thanks for this great review. I have pretty much made up my mind that this will be the saw I will be purchasing in the next few weeks. I am so glad you posted some pictures…I have been staring at the Grizzly web page for days! Great review…for the money this looks like all the saw I will ever need…its the poor mans Powermatic!
15538 posts in 455 days
posted 147 days ago
Hey Don
Great review, sounds like your new baby will be on” board” for some time. Hope your big commission is humming right along. I’m really glad this saw worked out.
Jim
woodsmithshop
268 posts in 423 days
posted 146 days ago
Don, good looking saw, glad you are happy with it, btw, your shop looks spotless compared to mine. lol
-- Smitty!!!
Don K.
1095 posts in 204 days
posted 146 days ago
Thanks everyone, I feel like a proud papa, lol.
Knotscott….only you, L/J’s own blade guru would be able to pick a fraction of a yellow line out of all that and say “Dewalt blade” lol…good eyes.
-- Don S.E. OK
Don K.
posted 146 days ago
I forgot to add a small thing to my review…I added it here again for those who have already read the review and just hit “Read new” like I do.
-- Don S.E. OK
cabinetmaster
7973 posts in 436 days
posted 146 days ago
Great review Don. Glad we could all help with the decision. As I said before, I have always been pleased with everything I have bought in the way of power tools from Grizzly.
Schummie
119 posts in 643 days
posted 146 days ago
Don,
thanks for your great preview, it was nice to reed.
I hope I got Friday the same table saw, only the mine has a different name
and the fence is different, I hope to change this.
Is there somebody ho knows where I can buy a other fence face (?) for this fence?
This table saw has mutts different names (because he is so good, I think :-)
I hope to make a little review from my saw.
Thanks Schummie.
This is the website
-- Greetings from the Netherlands.
Don K.
posted 146 days ago
Schummie,
Looks like a twin to mine…I also know Laguna sales the same saw under their name. Go to Grizzly’s web site, and under the G0690…click parts…they will have the part# for the same fence I have….you could then order the same one I have if thats what you want.
-- Don S.E. OK
Schummie
posted 146 days ago
Hello Ron,
that’s a great idea, I need a 502 P0690502 FENCE FACE.
But I have looked on there website, but they don’t send under the $200 too Europe.
Maybe I must search for a piece off UHMW and make it myself, but where do the
sell this?
Ron, thanks for your help and mutts pleasure with your table saw.
Schummie.
woodnut
269 posts in 930 days
posted 146 days ago
Ron, you are killen me with that saw. My grizzly catalog is wet with drull from looking at that same saw. Good luck with it, maybe some day I will get one.
-- F.Little
Don K.
posted 146 days ago
LOL…The name is Don.
-- Don S.E. OK
Termite
203 posts in 186 days
posted 145 days ago
I have a Grizzly cabinet saw and a Grizzly 15” planer and I find both to be excellent tools worth every penny of their great value.
I wax the tops on all of my tools and it helps them to stay rust free and smooth working… not to mention that it helps to maintain that polished new look for a long time if you can keep from using the table saw top as an additional work table.
Enjoy your saw!
-- Each and Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Greg Little
PurpLev
2675 posts in 526 days
posted 145 days ago
great review don – looks like a great saw!
JC
125 posts in 676 days
posted 145 days ago
great review! I can’t wait to get my Grizz saw up and running
-- JC - Central PA - www.affyx.com
BuilderBob59
14 posts in 143 days
posted 142 days ago
Don,
I have the Grizzly G0652 and have the same positive feelings for my saw. I’m amazed at how fast the blade comes to speed. I would like to see photos of your design for a mobile base. I have a ShopFox base under my Grizzly bandsaw. The base actually collapsed under the weight of the saw. I welded it together which helped but now the saw wobbles so bad I think it might just fall over forward. I’m looking for a good mobile base replacement design for my bandsaw.
Thanks, Bob
USCJeff
899 posts in 946 days
posted 139 days ago
While I don’t have this model, I have a Grizzly cabinet saw that is close to it in many regards. The features on your’s weren’t available when I bought mine 3 or 4 years ago. Would’ve loved the riving knife for one. Mine didn’t come with plug, motor cover, or a DC hook up. No blade I understand. The others, really thought they should be standard. Love mine, can’t imagine you’ll feel any different
Real comment is about the base though. I got the same base as you. Your saw is about 100lbs heavier (I think). I think mobile is a relative term. It will move if you really work at it, but it isn’t quite my definition of mobile. In comparison (of sorts), I built a mobile base around the 14” Deluxe Rikon Bandsaw. Not quite as heavy, but it can actually steer with quality casters. Like you said concerning costs, this is one of those times it costs more to make your own. Have fun
-- Jeff, South Carolina
Don K.
posted 136 days ago
Hey Bob and Jeff, sorry it took me so long to get back to your questions about the base. I am on Vacation at the moment. I will be back home around the 30th, when I do I will post some pictures of the base I made for mine. It would work for any shop tool you wish to make mobile….all you have to do is adjust the size to hold the base. It holds the saw off the ground about a inch. So if you can handle your saw/band saw etc being a extra inch higher….it works great.
-- Don S.E. OK
Teddy
3 posts in 136 days
posted 136 days ago
I bought the Grizzly Hybrid cabinet saw a couple of years ago. Couldn’t be more pleased with it. The only thing I didn’t like was the blade wrench, but I have a lot of wrenches so that wasn’t really a problem. Good luck with yours. Teddy
Don K.
posted 135 days ago
Teddy,
The wrenches that came with mine for the blade are great, very heavy and well made.. I made a small hook to hang under the saw to hang them from to keep them close.
-- Don S.E. OK
Don K.
posted 127 days ago
Bob…you asked about what my mobile base looked like for my saw….I added pictures of my shop and there is some pictures of my saw with the new base. While it looks bulky…..it does not stick out past the rails and once the wheels are locked it is steady as a rock, plus with the casters I use, it rolls around very easy when I need to move it. It only holds the saw off of the ground about an inch and a half.
Don
-- Don S.E. OK
DHS
3 posts in 102 days
posted 102 days ago
Hello Don. I just checked out the G0690 floor model at the Grizzly headquarters near my home. I like the most of the features of the saw, but I noticed that the fence deflected more than I’d like. Even after adjusting it it still deflected quite a bit. How is the fence on your G0690? Thanks, DHS
-- DHS, Bellingham, WA
Don K.
posted 102 days ago
Hmmmm….DHS… I bet that it was just the way it was set up as a display….as far as ALL the set up and adjusting I did on my saw…I spent more time on my fence than anything….not because it was hard….it was very easy to set and adjust…I just wanted it perfect.
But once I had it adjusted it is perfect….no movement and straight as a string. Can I deflect the end of the fence ???? Yes, but I have to put all my weight into it. and then it is only a fraction. I have yet to have any problem with it and I have pushed some LONG, BIG wood through it.
-- Don S.E. OK
alaskawoody
11 posts in 497 days
posted 95 days ago
Don, how does the guard do in terms of keeping the dust down? I’ve read that the g1023’s spray dust back at you. What kind of DC do you use with the saw and how do they get along? :)
Don K.
posted 95 days ago
alaskawoody,
I have to admit, that I use the riving knife 99% of the time….I have a 1 1/2 horse delta d/c….and it sucks it up fine. The few times I have used the guard…there has been no problem with dust control…still pulled it all down.
-- Don S.E. OK
alaskawoody
posted 94 days ago
Don,
Thanks for answering. Sounds like Grizzly fixed the problem.
Chester
2 posts in 135 days
posted 40 days ago
I got a G0690 last spring in PA and brought it home. It has been very good. My shop is in the upstairs of the barn, so getting it up (so to speak) was a real challenge. I have everything in my shop at 36” in height, so I had to make a wooden fixed base with 2-4 stock to raise it up (it is 34” high). I upgraded from an old Craftsman contractors saw, so having a saw (any saw) that will cut squarely is an amazing experience after all of these years.
The review said that the fence was a good Biesmeyer-type fence. I could be wrong but I believe that this fence is a lot better. The Bies rides on the actual table surface of the saw, while the Grizz fence rides on a poly adjustable button on the back rail. The front of the fence rides on two poly adjustable buttons on the front rail and has poly adjustable buttons that make contact with the front and back sides of the front rail. This arrangement keeps the fence approx. 1/16 to 1/32” off the table top riding as if on bearings off the front and back rails and keeping almost perfectly in square as I slide it up and down the rails for repositioning. The Bies can slide awkwardly as it rides across the table top and does not come really into square until it is clamped-down. This is a huge difference and a huge advantage of the G0690. In addition, the fence glides so effortlessly that (slight exaggeration) you have to be careful that it does not slide right off the rails.
The only criticism that I have is that it does not have a full 30” to the right of the blade. It is shy of that by about 3/8”. I have informed Grizz.
