Great Kit to repair my ole Dewalt Random Orbital Sander Hook & Loop pad
Review by DAN posted 164 days ago 1048 views 1 time favorited 12 comments Add to Favorites Watch
Great Kit to repair my ole Dewalt Random Orbital Sander Hook & Loop pad Great Kit to repair my ole Dewalt Random Orbital Sander Hook & Loop pad Great Kit to repair my ole Dewalt Random Orbital Sander Hook & Loop pad Click the pictures to enlarge them
I’m on my 2nd Dewalt random orbital sander …
As anyone who uses hook and loop sanders know, if the sand paper ever comes off while working ,the Velcro pad on the sander gets messed up real quick . Sandpaper will never stick right again.
I’ve gone thru the process of replacing the factory replacement part four times. Three times on the oldest sander and one time on my newer piece, Not cheap.
I found Ali-Gator-grit repair kit for 11 bucks at Lowes. It comes with two Velcro replacement pads and some glue.
I bought it figuring the factory part would eventually give out … About a year later it did.
My experience is the Velco in the Ali-Gator-grit kit much, much stronger, have never had a sheet of sand paper come off and still holding very well after over a year of abuse. Much better then the original equipment.
Highly recommended
View DAN 's profile
DAN
6442 posts in 878 days
12 comments so far
View BTKS's profile
BTKS
485 posts in 360 days
posted 164 days ago
Thanks, know how to fix it now. Have you had the white, for lack of an exact term, resistence ring wear out. I’ve had to replace mine once or twice now but never the hook and loop. I’m sure it won’t be long though.
BTKS
View DAN 's profile
DAN
posted 164 days ago
I have never had that part fail, but when taking the sander apart , I noticed the wear. I kept the old ones.
View USCJeff's profile
USCJeff
899 posts in 963 days
posted 164 days ago
Got a nice Bosch sander. Same issue. Does fine if under load, but pick it up and the paper is thrown. Did this after a half year. Will give this a shot before buying the $30 replacement that might or might not work 6 months later.
-- Jeff, South Carolina
View Don K.'s profile
Don K.
1095 posts in 222 days
posted 164 days ago
Thanks for the heads up Dan…I get tired of buying those darn $30+ replacement kits every years for my sanders….I will give this a try next.
-- Don S.E. OK
View Durnik150's profile
Durnik150
536 posts in 217 days
posted 164 days ago
Great information! I have torn through 3 finish sanders in the last 2 years. The most durable of the three has exactly the problem you described, the velcro surface is coming loose. Now I have an option to tossing it in the trash. Thanks Dan-If that’s who you really are (the unkknown woodworker).
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
25801 posts in 1296 days
posted 164 days ago
I’ve never had to replace a pad but I did get a conversion kit to go from PSA paper to Hook and Loop. I guess your kit does that also.
Thanks Dan.
View cabinetmaster's profile
cabinetmaster
8564 posts in 453 days
posted 164 days ago
Where you really mess up a pad is if you use the outside edge more than the flat part. We have people at work who try to use the OS to sand moldings and crown molding. That really messes up a pad.
View Tony's profile
Tony
812 posts in 925 days
posted 164 days ago
Thanks for posting Dan, I will have to try and get a couple of those – Similar subject, have you thought about using the “PAD Saver” from Mirka – they are aimed at protecting the Velcro when using Abranet sanding disks, but they also work equally as well on normal sanding disks.
By the way – do they give a web address for the product on the packaging, I cannot find them in Google. Found them – http://www.gatorgrit.com
16847 posts in 472 days
posted 164 days ago
Hey Dan you look eceptionally happy today.Thanks for the review.
14922 posts in 746 days
posted 163 days ago
Nothing like a Gator to get you out of a sticky situation.
View huff's profile
huff
1616 posts in 180 days
posted 162 days ago
Thanks Dan, I have a sander with the same problem right now. It’s been driving me crazy for the past week and hated to spend the 30+ dollars for a new replacement. I think I’ll run down to Lowes tomorrow. Thanks again for the info.
-- John @ Myrtle Beach
View DocK16's profile
DocK16
710 posts in 982 days
posted 162 days ago
AH yeah I can use one of these. Thanx
-- DocK, WV
