Amana tambour door router bit set - slick idea
Review by Brandon posted 187 days ago 732 views 3 times favorited 7 comments Add to Favorites Watch
Amana tambour door router bit set - slick idea Amana tambour door router bit set - slick idea Amana tambour door router bit set - slick idea Click the pictures to enlarge them
I have been wanting to build my wife a roll top desk for some time but the dilemma always came in on how to make the tambour. The new bit set from Amana is a great idea! No more having to glue slats to canvas or drilling the slats to run a cable down through them. The bits worked great and made it real easy to use different woods. The one drawback that I found was in the instructions and video. They state to mill the stock to 1/2” x 1 15/16” and that is what I did. The issue comes in when setting up the finishing contour path because that dictates the size of the ball and the defines the fit. I test it and found that if I set it up to get the whole contour on the face of the slat, then the ball portion was too small. When I set up to achieve the proper ball/socket fit, then the face of the slat was flat. The pictures show the loose fit and loss of the contour with the proper fit. Unfortunately when I realized this issue, I had already milled all my stock for the desk. It looks nice, but I think that it would have looked better with the proper contour as demonstrated in the video. I would recommend an extra 1/32” to 1/16” on the stock in order to obtain the best of both. The other observation I made was in the video, Lonny Bird’s ball router bit was a 3 flute and the one I received was a 2 flute.
All in all and great idea and design, I just wish I new about the stock issue first.
-- Brandon, Maine, www.maineweddingtrellis.com
View Brandon 's profile
Brandon
28 posts in 1067 days
7 comments so far
View lew's profile
lew
4486 posts in 650 days
posted 187 days ago
Thanks!!
I, too, have always wanted to make a roll top desk. When I saw this bit advertised, I thought that might be the way to go.
View Kindlingmaker's profile
Kindlingmaker
1471 posts in 421 days
posted 187 days ago
Thank you! I too have been looking at this bit and ponerdering…
View GaryK's profile
GaryK
9528 posts in 883 days
posted 187 days ago
I remember seeing those a long a time age. If I ever needed a tambour I will take a second look at them.
16841 posts in 472 days
posted 187 days ago
Thanks for the review I’ve wondered how well these work also.
View Splinterman's profile
Splinterman
4826 posts in 256 days
posted 186 days ago
The three fluted router bit sysytem would run smoother and with better control.
View woodman71's profile
woodman71
59 posts in 219 days
posted 185 days ago
I to have always want to build tambour door but was never crazy about the building process and i seen the review in woodsmith router table secrets like the review.thanks for your input and info i guess like anything there is always a leaning curve .
View cabinetmaster's profile
cabinetmaster
8564 posts in 453 days
posted 184 days ago
Thanks for the review. I have been contemplating this for a while. I was wondering how well it would work. I might have to talk the boss into this set for the shop. We do a lot of tambour units.
