All Star Performer
Review by pintodeluxe posted 03-11-2016 05:11 PM 3699 views 0 times favorited 9 comments Add to Favorites Watch
All Star Performer No-picture-s No-picture-s Click the pictures to enlarge them
This is a review of the LU86 thin kerf 40 tooth general purpose blade. I have been using this blade for all rips and crosscuts, and I must say I’m quite impressed. For ripping I was mentally comparing it to my Freud 24 tooth dedicated ripping blade. It seemed to rip 13/16” stock just as effortlessly as the 24 tooth ripper, but with a cleaner edge. There was no chipout at all with the use of a ZCI. My ripper often chips out the underside of hardwood cuts.
I also look for a blades tendency to burn. The LU86 did not burn any of my white oak boards. I even stopped in the middle of a cut intentionally to see if it would burn, and it didn’t.
For crosscutting panels I look at how clean the cut is, and to what degree it splinters. The LU86 crosscuts very cleanly, with no splintering. It leaves what I would describe as a tiny bit of fuzz on the bottom of the cut. This is really insignificant because my normal sanding routing easily takes care of this. I can compare the LU86 thin kerf to my Freud 50 tooth combination blade (full kerf) for crosscuts. The LU86 requires less force to crosscut panels, and does not have a tendency to burn in my 1-3/4 hp contractors saw. The 50 tooth full kerf would burn a little if feed rate was too slow (kind of a vicious cycle with full kerf blades and underpowered saws).
This blade is often described as general purpose, that can do most common tasks well. Sometimes tools that fall into the “Jack of all trades” description don’t do any one task exceptionally well. I think the LU86 is an exception to that rule. It rips well. It crosscuts well. It doesn’t burn. It doesn’t slow my motor down. Cuts are accurate and crisp.
I still use a full kerf combination blade to cut centered grooves for joinery, and I use a dado blade quite often. However for ripping and crosscutting tasks, this is my go-to blade.
The absolute icing on the cake is the quite reasonable price of $39. As of this posting other premium blades can run $109 and up. I haven’t used a Forrest WWII, Infinity Super General, or Freud Premier Fusion and honestly I don’t see that happening anytime soon.
I am just really pleased with this blade. A hearty thanks goes out to fellow LJ member Knotscott for the recommendation.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
9 comments so far
View WhattheChuck's profile
WhattheChuck
348 posts in 3801 days
#1 posted 03-11-2016 05:51 PM
I have a collection of Freud blades, PD, and really like them. I also recommend their ripping/hollow-ground planer. Changing blades can be a pain—but this one is worth it.
-- Chuck, Pullman, WA
View Roger's profile
Roger
20965 posts in 3044 days
#2 posted 03-11-2016 09:49 PM
Thnx for your review. I luv Freud blades
View rodneyh's profile
rodneyh
147 posts in 2905 days
#3 posted 03-12-2016 07:36 AM
Thanks for the great review. I’m currently using a Freud glue line rip thin kerf, and a Freud 80 tooth crosscut blade normal kerf. 1.75 hp saw. Both blades are pretty hammered, so I think I’ll give this blade a try for a while.
I’ve never used a ZCI. Is that a night & day improvement in cut quality sort of thing that I should get before bothering with a new blade?
Thanks
View GFactor's profile
GFactor
80 posts in 1840 days
#4 posted 03-12-2016 02:41 PM
Thanks for the great review. I m currently using a Freud glue line rip thin kerf, and a Freud 80 tooth crosscut blade normal kerf. 1.75 hp saw. Both blades are pretty hammered, so I think I ll give this blade a try for a while.
I ve never used a ZCI. Is that a night & day improvement in cut quality sort of thing that I should get before bothering with a new blade?
Thanks
- rodneyh
Here is an EXCELLENT post from Knotscott EVERY LJ Member should read:
http://lumberjocks.com/knotscott/blog/12395
Cheers!
-- To Steal Ideas From One Person is Plagiarism; to Steal From Many is Research…
pintodeluxe
#5 posted 03-13-2016 01:16 AM
Rodneyh,
No I don’t think a ZCI would give you “Ooohs and Ahhs” in the performance department. It might help reduce chipout on the bottom of the cut, but beyond that it is really a safety thing. It prevents thin strips from getting trapped between the blade and insert. I always use one, and have several for different blades and dado setups.
A good blade makes all the difference though.
woodbutcherbynight
5837 posts in 2649 days
#6 posted 03-14-2016 04:04 AM
I just got this same blade recently, works well. Been cutting alot of hardwoods doing some turning glue ups no issues and cuts sweet.
View Ken90712's profile
Ken90712
17616 posts in 3429 days
#7 posted 03-15-2016 08:49 PM
Great blade for the price have a bunch of Reds in the shop. Although my go to blade is the Woodworker II, is truly a good blade…. Not knocking this one, but there is a difference.
View Timberwolf323's profile
Timberwolf323
69 posts in 1083 days
#8 posted 03-17-2016 04:31 AM
Rodneyh,
No I don t think a ZCI would give you “Ooohs and Ahhs” in the performance department. It might help reduce chipout on the bottom of the cut, but beyond that it is really a safety thing. It prevents thin strips from getting trapped between the blade and insert. I always use one, and have several for different blades and dado setups.
- pintodeluxe
Yes and don’t forget those strips have a tendency to fire at you like rockets. (Yes I’ve personally experienced this.). Left a nick in my safety glasses. Haha.
View RibsBrisket4me's profile
RibsBrisket4me
1554 posts in 2746 days
#9 posted 03-22-2016 02:02 PM
The Freud LU86 is my most used blade. I’ve had several over the years and just get them resharpened.
A few years ago they were for sale on Amazon for $36, and I bought three.
The thickness of the carbide is really great for the price, and it cuts really great for a combo blade.
I have a Woodworker II, but the value of the LU86 can’t be beat.
