| Review by FJPetruso | posted 189 days ago | 2039 views | 1 time favorited | 17 comments | ![]() |
About 5 years ago I purchased a Harbor Freight Band Saw & the Riser Kit. I never installed the riser kit & stored it away until I needed it. Last month I failed to use my metal detector & while resawing some walnut I hit a foot peg, like the ones linemen screw into power poles, that the tree had completely grew around & ruined my band saw blade. So I took this opportunity to install the riser kit. I figured I would be playing with & tuning the saw up the whole day. But instead I was done in about 30 minutes. The kit came with a 105” blade, an adjustable upper blade guard, the riser block, a longer rod for the upper blade guide & a long bolt to install the block. Installation was simple and all the parts fit precisely & easily. Readjusting the guides was quick as was releveling the table. I was resawing quickly & had excellent results. The blade that came with the kit is a general purpose blade so I had to feed the wood slowly. I plan on replacing the blade with a 3 tooth skip tooth blade similar to the one that I ruined. I’m well satisfied with the saw & riser kit. I shouldn’t have waited to install the riser kit & would recommend installing the riser kit. The installation was easy.
-- Frank, Florissant, Missouri "The New Show-Me Woodshop"
17 comments so far
home | projects | blog
16684 posts in 470 days
posted 189 days ago
good to hear it worked so well
Bureaucrat
7206 posts in 545 days
posted 189 days ago
Good to hear the riser block worked out. Sounds like you are generally happy with your HF Band Saw. I’m considering buying a band saw to replace my 9 inch Craftsman. Would you recommend the HF for the $$.
-- Gary, South Central Wisconsin. So much to learn, so little time!
Jim
55 posts in 215 days
posted 189 days ago
I was wondering the same. I saw it the other day and couldn’t make up my mind of what kind of quality it looked capable of.
-- -- Jim - Kokomo, Indiana
Abbott
203 posts in 196 days
posted 189 days ago
Harbor Freight 14” Band Saw $339.00
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32208
Rigid 14” Band Saw Home Depot $369.00
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100041658&langId=-1&catalogId=10053&cisrc=14110944&cisku=100041658&cmmmc=shopping--google--D25X--100041658
-- Still clinging to my guns and religion.
FJPetruso
163 posts in 603 days
posted 189 days ago
Yes I would recommend the HF saw. It works very well for me & since I was planning on purchasing the Kreg band saw fence, I wasn’t worried about it not having a fence with it. It actually looks like a stripped down Jet or Grizzly when you compare them closely. It comes with guide blocks that look like the “Cool Blocks” that the local woodworking store sells. But I opted for a couple of sets of the optional roller bearing guides that they sell for $10 to $15 a set at HF. I purchased mine some years ago & paid about $159.00 . The HF band saw goes on sale frequently these days for about $275.00 + or -. (The HF retail store has it for $299.99 right now.) The only thing I may change someday is the location of the on / off switch. I would move it up to the column by the riser block like the other band saws. The interesting thing is…. the sheet metal support for the switch is already attached to the column & is punched for the holes to mount the switch box & switch. By the way, I also highly recommend the Kreg Band Saw Fence.
Pete_Jud
115 posts in 646 days
posted 189 days ago
I have been thinking about buying a riser for my delta, and didn’t know if the HF would fit, but I can’t locate the riser on the HF site. I wonder if it’s been discontinued.
-- Life is to short to own an ugly boat.
roadrunner0925
34 posts in 514 days
posted 189 days ago
i asked the people at hf if i bought this saw, would i be able to install a riser block and was it available. they said no, i didnt buy the saw. how do i get the risewr blk kit? and how much was the kit, if i may ask?
-- wm, brandon,ms
Broda
235 posts in 412 days
posted 188 days ago
looks good,
about how much?
-- BRODY. NSW AUSTRALIA -arguments with turnings are rarely productive-
Milo
100 posts in 212 days
posted 188 days ago
Ya know, I’ve got an knock off bandsaw myself. Wonder if that riser kit would work on mine. Anyone know if you can buy a generic riser kit somewhere?
THANKS!
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
Tony Z
173 posts in 683 days
posted 188 days ago
Sweet. I’m waiting for the day I hit a musket ball. It’s my dream! How much was the riser kit from HF and will it fit a Ridgid? Anyone know the answer?
-- Tony, Ohio
FJPetruso
posted 188 days ago
I purchased the riser kit when I bought the saw from their web site several years back for $50. You’re right, I don’t see the riser kit on the web site any more either. the HF band saw looks like the Rigid, Grizzly & Jet were all made from the same dies. If I saw one of the other riser kits I should be able to tell if it would fit. You might try calling Harbor Freight’s customer service # or send the queation by e-mail. I googled the riser kit & came up with these hits. You might want to check them out. It may be of help to call Grizzly tools to ask them if their riser would fit the HF saw.
http://reviews.ebay.com/Jet-Ridgid-Band-Saw-Riser-Kit_W0QQugidZ10000000003436272
http://www.sawmillcreek.org/showthread.php?t=49495
Abbott
posted 186 days ago
Yep.
FJPetruso
posted 173 days ago
Here’s some more interesting info on the riser kit for the Harbor Freight 14” Band Saw. The following is a link to the product manual for the saw. It includes the parts for the riser kit.
http://www.harborfreight.com/manuals/99000-99999/99635.pdf
Next is a link to the Grizzly web site which has a riser kit for their saw that looks the same as the Harbor Freight model. You could call their customer service & ask if it will fit the HF model. The price for this riser is $70.
http://www.grizzly.com/products/Riser-Block-For-G0580/H7316
roadrunner0925
posted 173 days ago
when i clicked on the hf link it went to a drum sander. wm
-- wm, brandon,ms
FJPetruso
posted 172 days ago
Oops! This should be the correct link…
http://www.harborfreight.com/manuals/32000-32999/32208.PDF
dbhost
600 posts in 125 days
posted 67 days ago
I have that band saw, with the riser block. Love the riser block kit, HATED the blade with a passion. That thing couldn’t cut through hot butter…
Replaced the blade with a selection from Suffolk Machinery from their Timberwolf line of Silicone steel blades and WOW what a difference!
As far as the price of the HF Band Saw. I see them FREQUENTLY go on sale for around $279.00, and with the almost always present HF 20% off coupon, they become a real baragain of a saw!
-- Trying to follow the example of the master.
36il
2 posts in 58 days
posted 58 days ago
I have the bandsaw, riser block , and the fence from Harbor Freight . The fence is not the best but for the money it did the job for right now in was around $30. I’m going to replase it later. The saw and block work good . the blade that come with it no good for resawing. I got a 105” by 3/4 3t blade and that work very good.you can get the block online and the fence. For you people that would like to get a riser block for other saw make sure the guide rod is the same tyte. 9-25-09
