| Review by Karson | posted 196 days ago | 484 views | 2 times favorited | 20 comments | ![]() |
- Wood Glide WOODWORKING LUBRICANT & RELEASING AGENT
- Brand: Wood Glide | Category: Other
I’ve used this product for years. I picked it up at a wood show and I’ve not seen it since. You can buy it online, but I need to find a supplier.
I use this product on bandsaw blades, especially good when resawing. I also use it on my Mortising machine to lubricate the drill bit in the chisels.
It makes the chips slide easier and cuts down on the heat generated by all of the wood going through the chisels.
20 comments so far
home | projects | blog
3046 posts in 918 days
posted 196 days ago
I have been using PAM vegetable oil but it’s a bit messy if you are not careful.
Does your pack have an address Karson?
25803 posts in 1297 days
posted 196 days ago
Their address is:
Product #1008
From: PAR Enterprises 4333 East Sam Houston Parkway
North, Houston, Texas 77015, 888-222-2225
Don K.
1095 posts in 223 days
posted 196 days ago
Thanks Karson,
I take it that this does not affect the wood come finishing time ??
-- Don S.E. OK
16978 posts in 474 days
posted 196 days ago
Thanks
3710 posts in 876 days
posted 195 days ago
Thanks Karson.
Emeralds
155 posts in 459 days
posted 195 days ago
I’ve been using Boeshield T-9 which seems to work well but the cans are small and I go through it realatively quickly. (probably using it too much). I’ll check this stuff out to see how it compares. Always looking for something that works better.
-- JMP
ND2ELK
6215 posts in 671 days
posted 195 days ago
Thanks for the info. Looks like a great product.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
PurpLev
2762 posts in 545 days
posted 195 days ago
thanks for the info. I use DriCote (got it from LeeValley.com) myself with good results. I put it on all my blades.
20733 posts in 719 days
posted 195 days ago
Thanks for the post, Karson. I will have to look into this.
posted 195 days ago
Emeralds: This is not for the tools to keep them from rusting like T9 is. I spray this on the blades for easy in cutting.
It does not stain the wood or impact any finishing.
PurpLev
posted 195 days ago
Bob #2 – PAM contains Silicone… and is actually not recommended for such porposes as the silicone can get on the wood, and cause finishing issues.
actually, we went to William Sonoma a while back, and they had their demo. they we re introducing a new non-stick pancake maker. they specifically said not to use PAM on it, nor anything that contains silicone as it wears off and eats up the non-stick layer.
PurpLev
posted 195 days ago
Correction – regarding PAM:
I checked , and PAM does NOT contain silicone. but it still is not suitable for non-stick surfaces as it builds up a layer that cannot be taken off. there are also reports of it gunking up on other applications. I personally would stay away from that – but if you are getting good results from it- go for it.
posted 195 days ago
I generally don’t have a problem with my blade on my 18” bandsaw.
What does gunk it up is sawing any type of conifers (pines etc)
as the pitch wants to coat my blade making a mess on the tires as well.
I use a bit of Pam then and clean up after with WD-40 on a piece of 3m abrasive pad.
I dont remember what the guys running mills were using. I never thought to ask.
PurpLev
posted 195 days ago
cool, I guess if you clean it up with WD40 afterwards, it wouldn’t gunk up, and should work well.
Kindlingmaker
1475 posts in 423 days
posted 195 days ago
Karson, The product sounds really good but the price… Does it last a while?
GaryK
9536 posts in 885 days
posted 195 days ago
I like the Teflon based non-silicone sprays.
Also a real nice on is Dyna-Glide. You can find it at: http://legacywoodworking.com/products.cfm?product=12 It’s good for all kinds of things.
14932 posts in 748 days
posted 195 days ago
Thanks Karson.
cabinetmaster
8637 posts in 455 days
posted 195 days ago
Karson, I have some of that too that I got from The Woodworkers Choice at the woodworking shows. But since they no longer exist I do not know where to get it either.
CessnaPilotBarry
1285 posts in 600 days
posted 194 days ago
Karson,
Is this stuff significantly better than Dri-Cote? I only ask because I buy DC locally. If it’s that much better, I’ll give it a try.
Thanks!
Barry
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
posted 194 days ago
Barry: I’ve never used Dri-Cote. I had a little mini can and I don’t know what ever became of it. So I can’t compare the products.
I guess I got it at The Woodworkers Choice like cabinetmaker said. I bought a can of it and T-9 at the same time.
I don’t have the rusting problem in this shop that I had at the other one so the T-9 can sits and waits.
