A great accessory for your router
Review by GaryK posted 192 days ago 904 views 6 times favorited 28 comments Add to Favorites Watch
A great accessory for your router A great accessory for your router A great accessory for your router Click the pictures to enlarge them
Using either one of two wrenches for replace a router bit can be a real pain. Especially if it’s in a router table.
This nifty little thing will allow you to replace your router with an allen wrench.
This “Eliminator RC Quick Change Chuck” is a combination bit extension and one-tool chuck.
Unlike other extensions, it replaces the nut and collet on your router thus minimizing run-out which can occur with some extensions.
I hesitated getting one of these things for a long time, but finally broke down and got one.
Now I don’t know how I could have done without one for so long.
I use a ball nosed tee-handle allen wrench to make it real easy, but a normal “L” shaped allen wrench still works great.
I have been using this for about 1 year and it works great. It seems to be built very strong and is well made.
It’s expensive, about $55, but if you use your router a lot it might be worth it to you.
Here is a video showing it: http://www.youtube.com/watch?v=HDy0xeiq08g
Looking online I found that they have 4 different styles that will fit the following.
Now I have only the Porter-Cable one, so I can’t say anything for the others.
1 Porter-Cable® All except 890 series routers.
2 DeWALT® 625, Elu® and freud® FT2000EP and FT1700VCE and all Festool®, Trend® and Fein® 1/2” routers.
3 DeWALT® 616, 618, 621 and Hitachi® M-12VS, M-12VC and M-12SC routers.
4 BOSCH 1613AEVS, 1617EVS, 1618EVS, 1619EVS routers.
They also make a sleeve for 1/4” bits.
Made in USA.
View GaryK's profile
GaryK
9521 posts in 881 days
28 comments so far
16598 posts in 470 days
posted 192 days ago
Thanks Gary
I wondered how well these worked , I don’t think I could afford one for all my routers but a couple would be cool.
View tenontim's profile
tenontim
1319 posts in 637 days
posted 192 days ago
Thanks for the review, Gary. I was wondering how these would work also. I have a router table that’s a pain to change the bits in, and I need to replace a broken chuck anyways, so I think Ill give this a try. I have the 1617 Bosch, so I’m in there.
-- Tim -- http://tmuli.com
GaryK
posted 192 days ago
a1Jim – I have 7 routers but so far only one of these. I’m planning on getting a second.
It comes real handy on my Legacy mill.
25795 posts in 1293 days
posted 192 days ago
I have seen these that are on a shank so they would fit any router, but I like the idea that they replace your existing nut on the router.
I might have to get a couple of these, but the router in my table is a Ryobi so i’ll have to go with the generic version for that.
GaryK
posted 192 days ago
Karson – I’m sure that you are talking about one of these:
My concern about this type is the about of lateral stress it will put on your routers bearings. Such a long extension would apply a lot leverage. Not to mention run-out.
View majeagle1's profile
majeagle1
426 posts in 389 days
posted 192 days ago
Great review Gary, thanks alot…............ I had not seen one of these yet and now am sure to get one for my PC mounted in my router table. Wow, to be able to get rid of the 2 wrenches!!!!
Have you tried the 1/4” sleeve? I am guessing that it would be designbed where there would be no problem with any slippage or anything…......
-- Gene, Majestic Eagle Woodworks, http://majesticeagleww.etsy.com/, http://www.flickr.com/photos/majesticeagle/
GaryK
posted 192 days ago
majeagle1 – They won’t slip. It looks like the one in the picture above. Most any 1/2” to 1/4” adapter will work.
Dick, & Barb Cain
7034 posts in 1192 days
posted 192 days ago
Looks good, but with my 3 1/4 HP Triton, the shaft automatically locks when you raise it to change a bit.
That’s one of the reasons I bought the Triton.
View Mike Lingenfelter's profile
Mike Lingenfelter
457 posts in 1006 days
posted 192 days ago
I’m in the process of upgrading my router for my router table. I was looking at this guy, and plan to add it to my order. I also looked at the Xtreme Xtension, but I liked how Eliminator threaded onto your router.
-- http://theinquisitivewoodworker.com/
View RedShirt013's profile
RedShirt013
116 posts in 554 days
posted 192 days ago
Nice review Gary, I’ve wondered before if these are just gimmicks but now I really want one. Kind of disappointed no Milwaukke routers on that list though.
I am curious what’s on the other side of that chuck opposite to the screw to balance it out. Or is that what the hole on top is for?
-- Ed
View Mark Shymanski's profile
Mark Shymanski
1555 posts in 605 days
posted 192 days ago
This is a cool tool, and I appreciate that you rate it so highly Gary. Like Dick I have a Triton router which locks when I raise the bit, but I will keep this in mind for future routers.
View DocK16's profile
DocK16
710 posts in 979 days
posted 192 days ago
Gary
I have both the chucks shown above. I bought the “Xtreme Xtension” chuch first but I had alot of vibration using larger bits and to be honest I haven’t used it since I first bought it. The Eliminator chuch was a different story and I found it worked fine. It is especially nice when using the Z-axis with the legacy. It was near impossible task trying to hold the bit in an upright router with one hand and then trying to use 2 wrenchs to tighten the chuck (a three handed job) this chuck eliminated that problem. Guess that’s why they call it the Eliminator chuck.
-- DocK, WV
View Les Hastings's profile
Les Hastings
953 posts in 666 days
posted 192 days ago
I have one on my Legacy. It does work very well and makes it a snap to change bits
-- Les, Wichita, Ks. (I'd rather be covered in saw dust!)
View pitchnsplinters's profile
pitchnsplinters
252 posts in 330 days
posted 192 days ago
You’ve convinced me. Definitely adding one to my wish list. Father’s day is just around the corner.
-- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits.
View cabinetmaster's profile
cabinetmaster
8490 posts in 451 days
posted 192 days ago
Les, you stole my comment. WE also have one on the legacy and it is biter sweet.
View molarman's profile
molarman
37 posts in 710 days
posted 191 days ago
Gary – nice review. I have had one of these in my router table for about 7 or 8 years and I love it. One word of caution though. When I first began using it I used a “T” handle allen wrench as you mentioned you use. I found that every once in a while my depth of cut would get deeper as I progressed. I first blamed this on inconsistent downward pressure on the workpiece. Well I eventually discovered that the bit was slowly walking out of the collet. Following that epiphany, I placed the appropriate sized allen wrench (cut off so as to be the correct length) in a smallish ratchet handle allowing me to increase leverage when tightening. No problem since. You may not have the same problem, but be careful. Other than that, I have had no issues with it.
-- Woodworking is not a destination....it's a joinery !!! http://smilesrus.com/pages/woodgallery.html
View Joe Lyddon's profile (online now)
Joe Lyddon
481 posts in 945 days
posted 191 days ago
Here is a comment from another forum on the same subject…
That may save someone from a serious problem.
CAUTION!!
I have an “Eliminator” on my table based router. There is an adapter for 1/4” shank router bits. If you place the adapter with one of its compression groves where the securing screw of the Eliminator hits the groove, the bit will not be secure. The securing screw of the eliminator needs to be adjacent to the compression grove of the adapter.
Rich
Huntington Beach, CA USA
http://www.woodworking.com/dcforum/DCForumID8/15581.html
GaryK
posted 191 days ago
Thanks for the warning Joe.
Makes sense. Don’t line up both the grooves.
View Tim_456's profile
Tim_456
45 posts in 488 days
posted 191 days ago
thanks Gary, great review. I’ve been looking at this but was concerned about the bit coming loose. I’m probably overly paranoid but a peice of steel spinning at 20,000 rpm coming loose kinda scares me. Especially when i’m looking right at it:D Anyway, it looks like this is definatly a solution to the knuckle smashing wrenches.
thanks!
T.
14915 posts in 744 days
posted 191 days ago
Thanks Gary. Interesting accessory but I think I will stick to the two wrench system.
View USCJeff's profile
USCJeff
899 posts in 961 days
posted 190 days ago
Did anyone else get the heeby jeeby’s when they first heard of this chuck? Something about spinning carbide in a “quick change” chuck sen some warnings off. The concept, brilliant. Sounds like it is great in execution as well. $55, should last a long time though I suspect. Might have to reconsider, anything to avoid trying to find that wrench I just saw.
-- Jeff, South Carolina
View BTKS's profile
BTKS
480 posts in 357 days
posted 190 days ago
Thanks, saved me from getting the extreme. A little accessory I’ve been needing for some time now.
BTKS
View DaveR's profile (online now)
DaveR
1517 posts in 613 days
posted 190 days ago
In case you aren’t aware, there is a longer version of the Eliminator Chuck called the XL Quick Change Chuck for the DeWalt, Freud, Festool and Fein routers. I have one and it is very nice when you need a little extra reach. It adds 5/8” to the plunge depth.
There’s also 1/4 in. and 8mm reducing sleeves available that have a shoulder on them so they won’t fall down into the chuck when the router is inverted.
-- Until you spread your wings, you'll have no idea how far you can walk.
Joe Lyddon
posted 190 days ago
To correct the link for the XL Quick Change Chuck:
http://www.thecraftsmangallery.com/Merchant2/merchant.mvc?page=W/PROD/RC/13-195
DaveR
posted 190 days ago
Thanks Joe.
View Loucarb's profile
Loucarb
943 posts in 338 days
posted 190 days ago
Thanks for the review Gary. I am always fighting the wrenches on my Porter-Cable.
3710 posts in 872 days
posted 189 days ago
Great review Gary.
This will save me from buying a new router every time I want to use a different bit. I was running out of space for routers!
GaryK
posted 188 days ago
I just found a brand new one on Ebay. I got it for $31.00.
Now I’ll have one for my Legacy Mill and my router table.
