| Review by woodfly | posted 197 days ago | 1396 views | 1 time favorited | 30 comments | ![]() |
Well I’ve had the saw for almost 6 months now so I thought that it was finally time to get around to the review.
I have been saving for my “first” table saw for several years now and finally had the money to get almost any one that I wanted. My first inclination was to go with a Powermatic. For the most part I have seen very few negatives when reading reviews from other buyers/ owners. The big issue was the $$$ even though I had saved enough. The question was go with the Powermatic or go with something for less $$ which would in turn leave me with money for additional tools for the shop. I chose the latter and in retrospect it may not have been the best decision.
I choose the Steel City after reading some reviews and seeing them at the WW show. The quality appeared good and the price was attractive and for some reason the Granite appealed to me.
I purchased the saw at the local Woodcraft store just before Thanksgiving. The “deal” included the WWII blade and some blade cleaner. I think it was something under $1400.00, which included a mobile base and dado insert.The saw actually arrived in less than a week and I managed to get it into my basement shop with a little help and a big dolly. As previous reviewers have stated the shipping container is a heavy cardboard box over a welded tubular steel cage and pallet. After taking off the cardboard I noticed that one of the top steel rails on the cage had a large bend in it, however after a close inspection, I could see no damage to the saw. There was a cardboard box with a lot of the hardware in it that had a pretty large tear and it looked like some of the small plastic bags had started to come out through the hole. I was concerned that some might have already been lost, but after checking for all the parts, everything was present and accounted for.
Assembly: After unpacking and getting the saw onto the mobile base, which I also pruchased, I was ready to start the assembly. The first step was to get the Granite extension on. There are 3 studs that screw into the fixed table top onto which the extension is then bolted. FIRST PROBLEM—One of those studs was not threaded properly. While it looked like it was threaded, it actually only had rings cut into it instead of spiral threads. I didn’t even know that was possible. Regardless, all progress stops because if you can’t complete step 1 you can’t go to step 2. I called customer service and they sent the part, which arrived about 4 days latter. I finally was able to get the extension on but had a devil of a time getting it even and level with the rest of the top. It could not be adjusted the way the instructions stated and I finally had to shim it, which was the only way to get it level. The rest of the assembly went OK, however I kept noticing how much wooble there was to the saw as I was puting it all together. I began to suspect the mobile base. Before getting things completely assembled I tried to make sure everything was level but the saw still wobbled too much. I even shimmed the mobile base to where it was not touching the floor and there was still a lot of movement. I finally decided that the base was to flimsy for the weight of the saw and took it off the base and put it right on the concrete floor. That solved the problem. Don’t buy the Steel City mobile base.
Assembly complete, saw running, sawdust being generated, now for some observations:
1. The table extension has a pretty pronounced crown right in the center. On one of the photos, you can see by the level just how much.
2. There seems like a lot of vibration when the blade is tilted 45 degrees. (Steel city says they all do that) You tell me LJs, is that true?
3. The “nickle test” I don’t think so, unless its a roll of nickles!
4. The blade insert that came with the saw was unusable. The four leveling screws on each corner of the were so proud of the top (see photo) that anything you tried to push through would either stop when it hit the high spots or ride up over them, sometimes leaving you with a piece of wood in the middle of a turning blade that you could not push on through. I serious safety issue if you ask me. I called customer service and thay sent another one that was even worse. I finally took a grinder and flattened the high spots out and it seems to work OK now. When I called customer service concerning the issue again their answer was that they were redesigning the insert and one would be sent to me. That was 5 months ago. I made another follow up call a couple of months ago and they told me it was still in the design phase, but suggested that I buy a zero clearance insert. After all my trouble you might think they would send me a zero clearance insert instead of offering to sell me one. I did buy a zero clearance insert, but not a Steel City. I bought a LeeCraft and it works great. I’m not even going to go into the issues with the Steel City dado insert I bought, which was also unacceptable.
5. The Riving Knife (which I love) is supposed to have a quick disconnect, but it does not work properly. Customer service is supposed to be sending me that part also. I’m still waiting and have little to no hope that they will come through.
6. During assembly almost all factory adjustments had to be readjusted. The 45 and 90 degree stops, riving knife alingment, blade to table, miter slot to blade, fence to blade etc.
Sorry,I didn’t mean for this to get so long. I guess I’m just venting a bit.
There are some pros. Once everything was set up, I have not had to make additional adjustments.The saw makes good, repeatable cuts, has good power, and is pretty solid. (once I ditched the mobile base) The fence is very nice, smooth and solid. The Granite is dead flat and I don’t have to worry about rust.
The cons – Quality control could and should be much better and quite frankly Steel City customer service is bad. Apparently they are content to just tell the customer what they want to hear without following up or doing what they say they will do. There is more vibration than I think there should be. Not sure the Granite will “last several life times” and based on my experience so far, I dread the day I may have to call SC customer service to collect on any warrantey needs.
So there it is. Would I do the SC again. No. But it is what it is and I will make it work. After all, its just my opinion right?
-- Mike
30 comments so far
jwicks
home | projects | blog
32 posts in 503 days
posted 197 days ago
I have the 35900G (1.75HP with granite top) which I bought last July.
I had a similar problem with the insert and was also told it was being redesigned. After a few e-mails they eventually sent me a zero clearance insert (made by Leecraft) which has worked fine. I’ve never received a replacement insert, but I always use the zero clearance one or the shop made dado one. I bought a Leecraft dado insert but haven’t used it yet.
I also had to adjust the riving knife to blade alignment, miter slot to blade alignment, and 45/90 stops. This was initially a pain but once I adjusted them I haven’t had to adjust since. As for the 45/90 stops, I use the Wixey angle gauge anyways and don’t rely on the stops.
I replaced the riving knife and blade guard with a Shark Guard after providing measurements and photos to Lee. That works nicely as its easy to add/remove the guard, and gets basically all of the above table dust.
-- Jon
16805 posts in 472 days
posted 197 days ago
good reveiw to bad about your touble.
hokieman
50 posts in 649 days
posted 197 days ago
This is a big disappointment. I have a SC cabinet saw with a steel top and it is great. I am sorry to hear their quality has slipped. I had some problems with my switch and they were very responsive so I would continue to press their customer relations folks until you are satisfied with the product.
CessnaPilotBarry
1273 posts in 597 days
posted 197 days ago
Well written review…
I would have expected SC to fix the vibration and replace the extension table and insert. Sorry to hear they didn’t help you there. I hope they come through on the riving knife.
I fully expect every heavy iron tool to need to be adjusted, as heavy things are not normally treated as fragile during shipping. Kind of like I expect to tune a piano after moving it. I have not been disappointed, regardless of manufacturer! <g> My real expectation is that the tool should STAY adjusted once it’s on site.
Once you get the saw dialed in, I think a lot of the bad will fade. These days, $1400, including a WWII is a great price! You’ve done a good service by clearly posting your experience.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
20668 posts in 717 days
posted 197 days ago
This is a well written review. It is a bummer to hear about the problems that you are having with the saw. One of the selling points with any tool, for me at least, is how customer service and technical support respond. Sounds like you should have had better support than you received.
kosta
371 posts in 249 days
posted 197 days ago
Granite is as bad luck as walking under a ladder I dont like it at all now there are some better things about granite then cast iron but its has to many problems over time
-- kosta brownsville brooklyn my home
PurpLev
2752 posts in 543 days
posted 197 days ago
nice review, sorry to hear this experience with SC… I was in the market for a saw, and after speaking to SC I got that feeling about them, and ended up shying away from their product and choosing a different brand. as far as setting up out of the box – I did the same (well, I did take my top off which would void any previous alignments) but I dont think thats a bad thing – it’s actually good that you get more familiar with the saw and it’s tunning right off the bat – makes it easier to do now when things are still in assembly, and you have the manual in front of you than later down the road when you’re in the middle of a project and have to stop and go back to square one… no biggy.
kosta- you keep stating that granite is such a horrible thing with so many problems – thats the 3rd time I see it – but you never explain or detail what you’re talking about ?!? do you have any bad experience with granite? any personal issues with it? any facts? related links? I’m curious….
Don K.
1095 posts in 221 days
posted 197 days ago
Thanks for the review, I was seriously considering a S/C cabinet saw (Found a heck of a deal on one) But like Purplev has already said…I just had a feeling. Two different tool distributors told me they feared S/C was going under and was dropping the S/C line (One was my local Woodcraft store) and the other one who was dropping them said he had hell getting them to back their warranty on their mini lathes, So I went another direction.
Sorry for all the troubles you are having and hope it all works out for you.
-- Don S.E. OK
Brad_Nailor
1216 posts in 852 days
posted 197 days ago
Great review…makes me think twice about wanting a SC saw…
Skarp
178 posts in 221 days
posted 197 days ago
Looked at getting one myself, but once the ‘wow’ factor was gone about the granite, I decided that chipping + weak t-slot + inability to use magnetic hold downs = no go. In fact after much deliberation I decided a Festool plunge saw was the ticket. I love the thing. Maybe down the road a few years and a MUCH larger shop worth of time I’ll get a Euro style sliding table saw. Until then I’m set. Except for a lathe. And a dedicated mortiser. And a CNC. And a laser cutter. Well maybe not exactly ‘set’..... Anyhow good luck with the customer service!
-- Ooo, er.
woodfly
14 posts in 243 days
posted 196 days ago
This is why I think this forum is so valuable. If we can share our individual experiences then just maybe it will help the next guy make a more informed decision. We all work awfully hard for our money and when we decide to pull the trigger and purchase a product (especially a big ticket item) then at the very least we should expect the companies to stand behind their products. I know it is only one persons opinion, but when you can see a “trend” in those opionons then there is probably something of substance there to base your next purchasing decision on.
-- Mike
Dusty56
3463 posts in 583 days
posted 196 days ago
Thanks for the review…you just made me happier about my JET purchase ! : )
jwicks
posted 196 days ago
Just wanted to add to what I wrote above, since I’ve actually been very happy with my Steel City saw.
I’ve had very good luck with their customer service, when you call a real person answers who knows the saw and often you’ll even be placed in contact with Jim or Scott Box who I believe own the company. The insert that comes with the saw is definitely a problem but that is easily corrected with the Leecraft insert (was only a little annoying since I bought the saw so early that the Leecraft inserts were not available).
After the initial adjustments to the saw that I mentioned above, I’ve had no issues and really like how the saw performs. I’m also glad I bought the granite, no issues there either, but obviously not for everyone. The only thing I’d change is I wish I’d bought the 50” rails.
-- Jon
woodfly
posted 196 days ago
jwicks—I found it interesting that even back in July when you bought your saw, they were “redesigning” the insert and apparently still haven’t gotten it right. I do have one question for you since you have esentially the same saw; Do you get a lot of vibration when you tilt the blade to 45 degrees? For that matter does anyone get a lot of vibration at 45 on any saw like SC told me? This is my first real saw and honestly I do not have anything to compare it to. All I know is that if I have anything setting on my extension table, it WILL be on the floor. I learned that the hard way.
-- Mike
Dusty56
posted 196 days ago
Woodfly …..NO vibration on my JET cabinet saw …..I don’t see how they could describe it as “normal”
jwicks
posted 196 days ago
Woodfly, yeah I’m surprised to hear that they haven’t corrected the insert yet. I’ve never noticed vibration at 45.
-- Jon
PurpLev
posted 196 days ago
woodfly, I have the Ridgid granite saw – very similar but only 1.5HP motor only so maybe that makes a difference- but I get 0 vibrations on 45 degree bevel cuts.
what I’ve noticed about SC is that it always seems like they are chasing after their tails… redesigning things forever…. website updates with long delays… marketing machines that they have never seen before (35920 was at the store, before it ever arrived at SC headquarters… they have yet to see it – but the customer could have…. – I did). just a bit finicky… I know they are doing the best they can, but their choices seem a bit unusual to me.
BTKS
485 posts in 359 days
posted 196 days ago
Woodfly, too bad about the short comings. A thoughtful and well written review. I purchased and reviewed in Jan the same saw except I have the cast iron top. Vibration?, I have little to none at any angle setting. Nothing on the saw moves when the blade is running. My insert only needed one or two layers of tape at the back corner to lock it nicely. Once the recessed allens were leveled it has been solid and smooth. The mobil base is useless. Shimed mine down to the floor too. May take it out soon but I may build in some boxes and drawers to stiffen the left side and give me somewhere to put accessories. I have not had a need for customer service from headquarters yet. The tech department was very helpful up front (prior to purchase), we’ll see if it holds true later. Hopefully I won’t need them.
I have to admit, I’ve been quite pleased with the saw and the two speed 14 inch SC bandsaw I picked up at the same time.
Hope it all works out for you. The only thing I can think of to check for vibration would be all the mounting bolts at maximum angle settings. Also, check the wear plates and set screws on the dovetail ways. One may be out or never guaged. If the wing mounting bolt wasn’t threaded right who knows if the way bolts were either.
I must have got lucky because the riving knife alighnment and function are good. The locking finger nut is tight but I may replace that with a star nut or something similar.
Well, best of luck, BTKS
pickles
52 posts in 308 days
posted 195 days ago
i have this saw and only issue i have is vibration, so much some times that the paddle on the on/off switch rattles and shuts the saw off while i’m using it. The on/off switch feels cheap compared to the rest of the saw. Otherwise no problems.
pickles
posted 195 days ago
Btw, I love the granite! I’ve found that it also makes a great surface to sharpen chisels with water and wet/dry sandpaper. I bang it all the time with very large boards with no ill effect.
woodfly
posted 195 days ago
pickles-Is your vibration issue regardless of tilt angle? Have you asked SC customer service about your vibration problem? I’m wondering if they would tell you that it was normal like they did me. I just don’t understand why one saw will vibrate and someone elses won’t. As BTKS suggests above, I will have to do some more investigating as it appears I’m on my own as far as SC is concerned. Any other suggestions as to cause would be appreciated.
-- Mike
pickles
posted 195 days ago
the vibration occurs at any angle, in fact i’ve only cut a bevel a few times. My old Delta contractor saw cut bevels very poorly, so i got accustomed to using my jointer to sneak up on the bevel i needed. This saw cuts a bevel beautifully but still vibrates. I didn’t calll SC.
grizzman
532 posts in 198 days
posted 195 days ago
well i havent been in the market for a table saw since i bought my delta 13 years ago…..ive had zero trouble…never a vibriation and ive never needed to call for service…i dont know why maybe you guys dont consider a delta saw…but the steel city sounds like to many problems that when you buy a good saw…you should not have….powermatic is another great saw…...good luck with steel city…just think of the time you spend dealing with them you could have been wood working…...sorry you guys are having problems…grizzman
-- The Grizzone
Dusty56
posted 194 days ago
Maybe SC is waiting for one of their saws to vibrate apart and hurt someone before they correct the problem.Maybe their Techs aren’t smart enough to diagnose and correct the problem. I personally would stay on their case until they sent someone to check out your vibration. Whoever sold you the saw should confirm that there is a problem and get their factory rep out to your house without delay . I once had a vibration problem with a contractors saw , and it ended up being the drive belt. My friend had problems with the factory pulleys being out of round and causing vibration on his Delta. How many belts are on your saw ? Try loosening and readjusting them for the hell of it .
BTKS
posted 194 days ago
Dusty 56 may be on the track. Pulley allignment, bearings or pulley roundness could be the culprit. Probably not round if the vib is worse in one allignment than another, that would push me toward a bearing being bad.
Good luck, BTKS
woodfly
posted 194 days ago
I’m thinking of taking the belt off the motor pully and runing just the motor to see if there is any noticable vibration from the motor alone. Does anyone know if that is OK to do or will I damage the motor if I run it without the load of the belt?
-- Mike
PurpLev
posted 194 days ago
thats ok to do, I’m surprised you haven’t done that already. but that will give you the idea whether vibration has to do with belt/pully/arbor side of the equation, or if it’s on the motor side/mount
ChuckM
146 posts in 561 days
posted 194 days ago
Thanx woodfly for putting this out. I’ve recently got my Rigid TS 3650 and if I had encountered the kind of problems you mentioned. I think well before I hit issue #3, I’d have returned the TS to HD (it was just $499). The factory settings (90, 45 etc) were dead on and I simply couldn’t afford the time you had had to troubleshoot, experiment, fix, call the CS, etc. When I read that the customer service was kinda giving you lip service, I told myself I wouldn’t want to do anything with the Steel City and you’re right about warranty concerns. Let’s hope you don’t have call them on that… Where is the T/S made? I suppose it was imported from China or Taiwan. It’s the responsibility of the importer (Steel City) to ensure their product quality. Mine was from Taiwan but Rigid has done a great job in ensuring quality. Based on your review, my $499 TS would perform better than yours in terms of the nickle test and Rigid’s mobile base is second to none for sure.
Thanks again for sharing .. if more users tell us how good or bad a company may be, they all will perform better.
-- The time I enjoy wasting is not time wasted
woodfly
posted 194 days ago
I don’t know where it was built, off shore certainly, but one thing I do know, is that Customer Service is here in the states so there is no excuse for the lousy way it has been handeled. They are the ones who have dropped the ball and have chosen to compromise their company and their products’ reputation, and with a crummy reputation how long can a company remain in business?
OK, time to move on. I will udpate if anything changes or if I resolve any of the issues.
Thanks for all your input LJs.
-- Mike
jerryz
109 posts in 173 days
posted 152 days ago
I would like to offer my 2 cents on the “Granite Issue” it is undenaibly the most stable material on earth after all it was formed a couple of million years ago, and that is why when you need the utmost stability it is the material of choice in machinery of extreme precision.
However it is also true that said machinery in my experience uses slabs of Granite that require forklifts and overhead cranes to move.
My concern of using a granite top on a table saw is that the ones I have seed are hardly thicker that 2” at most. Granite is fragile is the sense that it is intrinsecally hard and therefore it is a bit on the brittle side, you don’t want to bang it, OK you can, but don’t complain when it cracks, and it will eventually. True now days with miracle glues it can be repaired, however the precision you had, has gone out the window.
The most delicate areas are those 90 deg areas, the miter slots, the joint were the extensions meet and the borders of the table, they are very easy to chip precisely because the material is brittle.
Soo I am building furniture, do I need sub-millimeter surface precision??? I don’t think so. The only advantage I see for the Granite is it’s apparent lack of maintenance and yet if you want to have a slick surface and I believe the consensus on that one is pretty clear, then you should still wax your granite surface.
Unless you don’t use your Table saw enough and a granite top won’t rust.
On the Mobile Base issue. Thankfully I had read this review and therefore went looking for something more substantial.
See I have a Craftsman 22124 with Cast iron top a clone of the SC and I need to be able to move the TS in my very restricted garage space.
Therefore I purchased a General International Model 50-030 Universal mobile Base.
It is a bit of an overkill since it is rated up to 900lbs. but includes the extension table wheels.
But I am very pleased with it. It is sturdy and well made. Wasn’t cheap mind you, $179 at WoodCraft.
Well worth it however. There is the link to that base in case someone wants to have a look at it.
http://www.woodcraft.com/product.aspx?ProductID=834087&FamilyID=20995
Just my humble opinion, you don’t have to agree with it, we can all agree on something let’s concentrate on that haha.
