A shocking experience
Review by RichM posted 02-18-2016 02:12 PM 2996 views 0 times favorited 9 comments Add to Favorites Watch
A shocking experience No-picture-s No-picture-s Click the pictures to enlarge them
https://youtu.be/NtslhTfdMmE
-- Rich, Learn something everyday even if it is how NOT to do it.
View RichM's profile
RichM
53 posts in 1502 days
9 comments so far
View dhazelton's profile
dhazelton
2805 posts in 2536 days
#1 posted 02-18-2016 06:58 PM
Was it from static and winter’s low humidty? Weird.
View 000's profile
000
2859 posts in 1139 days
#2 posted 02-18-2016 07:09 PM
Get one of those and you won’t need to get you a taser. lol
View MrRon's profile
MrRon
5270 posts in 3483 days
#3 posted 02-18-2016 07:54 PM
I have a 1” x 42” belt sander (not HF) and I have never had a problem with static electricity. Mine runs at 1725 rpm while yours runs at 3450 rpm. I wonder if it’s the higher speed responsible for the static electricity. What are the drive wheels made of? Mine are metal. If yours are made of a fiber or plastic, that could create the static charge; much like a Van de Graff machine.
View htl's profile
htl
4326 posts in 1399 days
#4 posted 02-19-2016 12:41 AM
I’ve got the same out fit and it has shocked the snot out of me many times.
When I was using it a lot I got to where I would keep one hand on it so it wouldn’t build up any static and sap me.
I keep wondering if it’s going to short out or something like that.
Adding to what I said before
I just watched the video and see what needs to be done.
I had been using it with the back brace on with no problem and like you was going to do some shaping and took it off and that’s when it started saping me also.
Thanks for the heads up
I was worried about it having a short in the motor or something like that.
I will be putting the back back on, been wanting to try adding a curved wood backer for shaping any way.
It is a great little sander!!!
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
View Tennessee's profile
Tennessee
2893 posts in 2754 days
#5 posted 02-21-2016 12:57 PM
I’ve got one of these, and I did leave the back on. Not a fan of the back, but I will admit I’ve never been shocked. I think I’ll pass on taking it off!
View robscastle's profile
robscastle
5632 posts in 2444 days
#6 posted 02-27-2016 09:13 AM
Dampening the belt may help, ensure though it a resin bonded type that can be water pressure cleaned othewise you may get a buffing belt.
I ground everything
The dust extractor livened me up a few times I tell you.
-- Regards Rob
View EEngineer's profile
EEngineer
1119 posts in 3853 days
#7 posted 08-07-2016 10:34 AM
Well, let’s see…
Plastic wheels for the belt to run on, a non-conducting belt and continuous belt motion – this is a Van de Graaff generator !
Or half of one anyway. It is obviously leaving the accumulated charge on the belt until you discharge it. That metal backing plate that you installed probably equalizes the charge between the belt and the metal frame of the sander.
View Liam459's profile
Liam459
3 posts in 615 days
#8 posted 05-16-2017 07:59 AM
YouTube if I inform you how to download it. Considering SnapTube where this application is not available in Google Play Store.
View Hooker452's profile
Hooker452
1 post in 579 days
#9 posted 06-21-2017 09:40 AM
after that Musical.ly Application is the one you need to have. musicallylogin.co the customer needs to supply his/her legitimate number.
