iGAGING - Digital Protractor (Rating: 5)
I have a large Bosch digital finder and liked it so much I thought I'd try this smaller version for projects that did not require the various capabilities of the larger unit. After doing so, I decided I need a few of them around for the shop and the work van.
These work well for setting and checking angles when doing blade set ups on miter saws, table saws and band saws. They give a good read-out for inner and outer angles, such as when building picture frames.
They are easy to check for accuracy by setting them at 90, placing them on a straight edge, drawing a line, flipping it over, drawing a second line over the first, then checking for variances. I found the accuracy of mine to be reliable for producing tight miter cuts and so forth.
NOTE:
GREAT NEWS. It is, now, a couple years in from the date I purchased this and I had to replace the battery for the first time. In other words, it's does not eat batteries while sitting around, like my Wixi angle meter does.
NOTE:
