Oneida Mini Gorilla
Review by philF posted 212 days ago 1899 views 0 times favorited 5 comments Add to Favorites Watch
Oneida Mini Gorilla Oneida Mini Gorilla No-picture-s Click the pictures to enlarge them
I was searching for a portable (one machine at a time) dust collector for my basement shop. After much research and anguish I settled on the Oneida Air Systems Mini Gorilla. Oneida cut the price to $795.00 and threw in a plastic Dust Deputy DIY cyclone. They also cut the price on the remote control upgrade to $30. I was vacillating between the Jet DC-1100 CK (Canister Filter) and the Mini Gorilla. The Jet had the higher CFM, but I wondered how long would I have 1100 CFM, was the filter going to clog? The Mini Gorilla had 600 CFM but that should remain constant do to the cyclonic design. I also like the fact that the Mini Gorilla could be upgraded to a HEPA filter. As a bonus the Mini Gorilla was made in the US.
I ordered the Mini Gorilla with the remote control upgrade and a HEPA filter upgrade. It arrived in 3 boxes via UPS in 5 days from my order placement. Shipping weight was approximately 150 pounds. I was very impressed with how the unit was packaged and boxed. The unit just screams quality. The fit and finish is excellent. I had the unit together in under an hour. The assembly was simple and straightforward.
My current Dust Collection needs are for the following, Spindle Sander, Dewalt 10” contractor saw, Jet 6.25” Jointer, Jet 14” Band saw, Lathe and miscellaneous small tools.
I have tested the Dust Collector on my Jointer and was quite pleased with the results. The sound level is much better than my shop vacuum. I do have a Dylos .5 micron air particle tester (http://www.dylosproducts.com) so I will be monitoring for small dust escapes.
-Phil
View philF's profile
philF
9 posts in 788 days
5 comments so far
View PurpLev's profile
PurpLev
2763 posts in 546 days
posted 212 days ago
congrats. hope you can edit this review once you experience more of the actual abilities and quality of the machine’s performance.
View steveosshop's profile
steveosshop
208 posts in 524 days
posted 212 days ago
Good luck with the new dust collector. You should do a follow up in a few months and let us know how the machine does for long-term use.
-- Steve-o
View Woodchuck1957's profile
Woodchuck1957
950 posts in 662 days
posted 212 days ago
A picture of it setup would be nice also. I see that the impeller is a composite material.
View Chris's profile
Chris
300 posts in 255 days
posted 211 days ago
Thanks for posting, and to echo the others please let us know how this works out. I’m looking to upgrade from an inadequate shop vac myself.
-- Chris
17022 posts in 475 days
posted 210 days ago
Congrats on your new dust collector I hope it serves you well. I have 3 dust collectors all around $ 150 each from Harbor Freight They are rated at 1200 cfm . I have some under floor ducts and some over head .I use one just for my table saw,One for my Jointer, and one for everthing else . I have waited until there on sale but even when there not there somewhere from $199 to $ 229 . I usually buy high end tools if I can afford them but these cheepie dust collectors have served me well . If your wondering how I have room for three dust collectors ,two of them are out side were I like them for removal of sawdust and noise I have remotes for the two outside.
-- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com
