| Review by TreeBones | posted 1591 days ago | 17141 views | 1 time favorited | 13 comments | ![]() |
- Wood-Mizer LT40HD Hydraulic Portable Sawmill
- Brand: Wood-Mizer | Category: Other
After twelve years of use I can say this is a first class band saw. I have put mine through the test. The largest log I put on it was a 48” diameter, 26’ long Redwood that weighed over 17,000 pounds. Wish I took photos of this one. I cut over 80,000 bdft on that one job. The throat is 28” and with logs placed perfectly it can cut slabs this wide. Breakdowns have been essentially non existent and maintenance requirements are minimal, blades, roller guides and belts are the common replacement parts. I replaced the engine with a Kohler 25 HPG when the original Onan 24 HPG wore out after 850,000 bdft. The accuracy is such that I can cut a 20’ sheet of 1/8’ veneer with ease, as long as the blade is kept sharp. A dull blade is the leading cause of most all problems you may hear about. I run a 1-1/4” wide blade with a 9 degree hook. It trailers well and I have had it on some narrow, steep dirt roads with plenty of switch backs and even places where there are no roads. Production rate is as Wood-Mizer advertises, 2,000 bdft of 1” X 12” a day as long as the logs are around 30” diameter and at least 16’ long, its a real work out but can be done by one person in 8 hours. The LT40HD has a hydraulic loader and turner. They make many larger and smaller mills with different features. I will always give this band saw mill the highest recommendation. You can find more details on my web site.
I wanted to add an update. Recently I have been working as a sawyer for another sawmill service who is running a 2000 model LT40 Super Hydraulic with set works, diesel engine and debarker. This saw has several upgrades from my saw and I have found this brings more maintenance and break down issues. To summarize; the more add ons you have the more maintenance and potential down time you may have, caused by break down issues. Sometimes simple can be better. My new experience may be influenced partly by the lack of regular maintenance and repairs of this particular mill.
-- Ron, Twain Harte, Ca. Portable on site Sawmill Service http://westcoastlands.net/Sawmill.html http://westcoastlands.net/SawBucks2/phpBB3 http://www.portablesawmill.biz/concrete/
13 comments so far
GaryK
home | projects | blog
10251 posts in 1793 days
#1 posted 1591 days ago
Now that’s a bandsaw!
3811 posts in 1826 days
#2 posted 1591 days ago
Nice machine Ron.
How do you handle pitch build up on a production tool like that?
TreeBones
1755 posts in 1828 days
#3 posted 1591 days ago
I use water to keep the blade clean and cool, around 10 gallons an hour. Some operators will add soap, pinesol or similar additives to the watter to help but for me water works just fine.
RobS
1332 posts in 2111 days
#4 posted 1591 days ago
Impressive operation. Thanks for explaining.
-- Rob (A) Waxahachie,TX
Obi
2201 posts in 2042 days
#5 posted 1591 days ago
I should be up there within the next month to do this small burl. I’ll call you or e-mail you.
-- http://ye-olde-cabinet-shoppe.com/
rikkor
11294 posts in 1679 days
#6 posted 1590 days ago
Quite the bandsaw. I like the pic with the rainbow.
RobG
71 posts in 1627 days
#7 posted 1589 days ago
That is a very sweet operation. Thanks for sharing. Maybe one of these days I can park one of those out behind my shop!!
-- Woodworking is Life. Anything before or after is just waiting.--S. McQueen sort of
Tomcat1066
942 posts in 1601 days
#8 posted 1586 days ago
NICE! I definitely need to find someone with one of those! The place I’m moving to has an oak tree that really needs to come down, but I’d like to find someone who can turn it into lumber for me to build with.
-- "Give me your poor tools, your tired steel, your huddled masses of rust." Yep, I ripped off the Statue of Liberty. That's how I roll!
Mark A. DeCou
1891 posts in 2210 days
#9 posted 1585 days ago
Oh, would I love to have one of these babies….......or you as a neighbor. Either would work.
Thanks for the writeup, I’m still saving my pennies, and when the kids are out of college, maybe then. I have about 16 years to go.
thanks for writing this up.
-- Mark DeCou - American Contemporary Craft Artisan - www.decoustudio.com
Dick, & Barb Cain
8556 posts in 2104 days
#10 posted 1583 days ago
Thanks for this review.
I watched a demo of this saw at an logging show quite a few years ago, when it first came out.
The inventor of it was the demonstrator. I’ve always wanted one.
At the time it a little under $1500.
A little to much for my wallet.
fred4999
107 posts in 1289 days
#11 posted 1030 days ago
Hello again Treebones,
I too have a Wood-Mizer LT40HDG24 that I bought new in 1997. I cannot say enough about the mill and the folks at Wood-Mizer. It is a great machine. What few things that needed fixing I was able to do it myself in the middle of the woods with some occaisional troubleshooting tech (at no cost) help from Wood-Mizer.
I agree about keeping it simple, if I were to buy a new one, it would be basically the same machine.
-- Fred, Georgia
Mike Pientka
129 posts in 894 days
#12 posted 892 days ago
A thorough review. Thanks
-- Engineer by day, Woodworker by night, Original Approach LLC, Windsor CO, www.original-approach.com
chuckyb
5 posts in 210 days
#13 posted 210 days ago
http://www.youtube.com/watch?v=wzrxHjCRpJE<<< If you all like that you might also like this fella’s mill, it’s a set of 3d plans he has for a mill he built. He has others available also and everything is free with measurements ect. also advice.
