Quality Machine, Quality Customer Service, Highly Recommended!
Review by PurpLev posted 214 days ago 1788 views 1 time favorited 33 comments Add to Favorites Watch
Quality Machine, Quality Customer Service, Highly Recommended! Quality Machine, Quality Customer Service, Highly Recommended! Quality Machine, Quality Customer Service, Highly Recommended! Click the pictures to enlarge them
I received some appletree logs from someone on craigslist, and was contemplating how I can get them into project lumber. I had looked around for small mills, but it wasn’t really worth it since I only have a few smaller logs… then it got me to think, maybe I can do it myself… hence started the interest in bandsaws.
the more I researched about it, the more I was fascinated by the capabilities of a bandsaw and all the things it can do. I have a fairly limited budget, and so I began looking for older 12” saws on craigslist and similar places while at the same time reading reviews and doing more research on each machine I saw.
it came down to it, that none of what I found would be worth it in the long run, since it will not be able to resaw my logs (size capacity, and power) and eventually I’d be upgrading it anyways, so I figured, i’d rather get one that will work NOW, not later… then I read some good feedback on the Rikon deluxe.
it is a bit over what I had expected to pay, but I figured it’s still reasonable for what it is, and will probably be my last bandsaw – I was right about that one (for the foreseen future..lol).
Assembly
The saw comes pretty much assembled for most parts. it is HEAVY! BUT! a 1 person CAN do the job, with proper planning and careful fabrications of assisting devices (to take it out of the box, place it in the right place..etc). I’m not advocating to do it on your own, but personally I was able to do it (don’t have anyone around that could have come for help)
I recommend getting a mobile base for it, and start assembly right on that base… that way, each piece is slightly lighter than the whole saw, and once put in place, will not have to be moved again – ever! (it’ heavy)
make sure that all the nuts in the cabinet space are tight (ratchet works best) so eliminate as much vibration as possible (don’t worry, when the saw is operating there is almost zero vibration going on – this thing is solid and steady but when you crank the wheels etc, there is a tendency to rock the machine ever so slightly).
Tuning
Tuning of this machine is super east, there are really nice large wheels for everything – I mean everything. I’m not going over how to tune a bandsaw in this review – there are plenty of those tutorials online, all I can say is that the controls on this saw are convenient, properly placed, and work very well. smooth to operate, and stay locked in place when needed.
the only exception I found was the blade tension wheel which is on top of the saw – I think positioning it under the frame would be more convenient to use – BUT it would lower the maximum resaw capacity of this saw. you only tension the blade when putting a new one on, so it’s not that big of a deal – I’d rather keep the 13” resaw capacity… just a note to mind.
Dust Collection:
There is only 1 4” chute at the lower wheel area which is partially covered with a metal plate on the inside to prevent people from sticking their fingers in there and getting hurt from the spinning wheel. I’ve read that some people had problems with that plate (it would block air flow and hinder dust collection) but I’ve yet to experience anything of that sort. at the end of operation there is almost 0 dust in the lower frame assembly, and absolutely 0 chips/cutoff pieces. I do run this with a Jet DC1100 connected to it .
there is no dust chute that is positioned at the lower guide assembly like other saws have (even the Rikon regular 14” saw) and there is dust that gathers around that area that doesn’t get into the lower frame to be pulled in by the DC. a quick blow with compressed air takes care of that.
Fence
very easy to use. switches from low profile to normal profile in less than 2 seconds. (2 thumb screws, and a T slot) so far the fence and the saw are very accurate and easy to use.
it also comes with a built in resaw round bar that attaches to the middle of the fence and can be taken off… I haven’t used that one yet, but if I’ll need it – it’s there.
Edit:The Fence rail only accommodates the fence traveling on the left side of the blade, while some fences are capable of traveling on both sides of the blade.
Table
Table is rather large, has 2 T-slot miter slots on each side of the blade. good for most operations, and for those that require a REALLY large surface – a sled can be used (usually those projects requires a sled anyways, so it’s not really the table’s limitation)
Table tilt mechanism is rack-n-pinion which is excellent! for some reason, many saws on the market don’t have that., but this one does. the table tilts 45 to the right, but for some reason only 5 degrees to the left, and not the regular 10 degrees that is found on most other saws. you can see both the tilting mechanism, and also the ramp in the lower frame construction which hinders the table from tilting more than ~5 degrees to the left (there is a bold that helps bring the table to 0, but can be swiveled to the side the allow the table to tilt until it comes in contact with the frame which gives about 5 degrees angle.
This is something that I didn’t really understand, nor payed much attention to when I was researching for a bandsaw. I guess you can’t realize everything until you start gaining experience with it (just like everything else in woodworking and in life in general).
not too biggy (but it’s there), I can make a fixture to get a 10 to the left… with the 13” resaw capacity, I’m not limited by height of fixtures.
Blade Installation
FWW claimed that it takes too long to replace the blade on this saw. it doesn’t. but I can see what they meant. both doors on the saw (upper and lower) have to be open a full 180 to the back, to be able to slide the blade out, and theres also the connecting frame between them the the blade has to slide in and out of. Also to get the blade out of the table you have to disconnect (bolt) a metal bar that holds the fence in place… and reconnect it later…
time to change a blade ~20 seconds… I wouldn’t consider this a deal breaker … really.
Blade tracking
see tuning… very easy, and with a window you can see the blade on the wheel it’s very intuitive.
Blade Tensioning
see tuning – very easy, and with a window you can see the blade tensioning dial, it’s very intuitive (yeah, almost a copy paste of the tracking part)
however, the tensioning dial did get bent over when I was tracking the blade and shifted the wheel outwards… apparently this is a known issue which might render the dial inoperable and useless, but I check the tension using my finger in the front of the blade, and haven’t really tried using the dial anyways.
EDIT: The Rikon Deluxe saw comes with a built in quick blade detentioner. some people claim this is a marketing design set back in the days, some people stand by it, either way – this one comes with one as a standard control – I like that. you can always choose whether to use it or not. but it’s there if you chose to use it.
Blade Guards
These are ball bearing guides both under and over the table. easy to setup – lockable with allen screw that mounts and stays on the saw’s frame. adjustments are done using oversized thumbscrews, I have used the factory original guides on both 3/4”, 1/2” and 3/32” blades with no problems what so ever. they are adjustable front to back, and can accommodate each of those blades properly.
Operation:
The saw runs amazingly smooth, 0 vibration (at least nothing noticeable) and very quiet… if you’ll step a few feet away, you might forget that this thing is on!
with a good blade (I got the 1/2” woodslicer for it) this saw cuts super smooth and precise! out of the box (so to speak) blade cover is using rack-n-pinion mechanism ,and lock in place solid. on-off buttons are large, and easy to access. I’m running this saw on a 15amp breaker, and it has never cause any problems (unlike my DC)
Conclusion
This bandsaw was well worth the money and time I had waited until I could get it (yes, I had to hold off when originally wanted to purchase a lower grade saw, and save a little more) it does what it needs to do, and it does it VERY WELL! doesnt complain, and always asks for more.
low maintenance, easy setup, easy controls, great performer! highly recommended.
Customer Service
With recent questionable CS issues that have floated around, I thought this is worth mentioning – Rikon CS is superb! they are responsive, responsible, don’t BS, and (seems like) they want to see their machine working as it should in the hands of it’s owner – hands down! any question or concern I came up with I was answered promptly with a very positive attitude from really cool people. Thank you Rikon! I almost forget that good CS still exists.
View PurpLev's profile
PurpLev
2732 posts in 540 days
33 comments so far
View Chris's profile
Chris
300 posts in 249 days
posted 214 days ago
Great blog on the saw. My only issue is with your statement on tensioning the blade “you only tension the blade when putting a new one on”. I have always been told to not leave the blade tensioned , particularly as I may go months between using the saw. For all I know this is an old wive’s tale, but there are aftermarket blade de-tensioners available. Of course that might be someone cashing in on a popular misconception.
Or of course, the Rikon may have an integrated blade de-tensioner, in which case please ignore this misguided rant ;-].
-- Chris
Chris
posted 214 days ago
So I went and looked at an ad for the Rikon, and it does appear to have an integrated quick tension release. Please ignore my earlier post. Great looking saw.
-- Chris
PurpLev
posted 214 days ago
Thanks Chris for pointing that out, everything about this saw is so intuitive and simple, that I forgot to mention that one as well… I edited it in.
View 3fingerpat's profile
3fingerpat
905 posts in 560 days
posted 214 days ago
Excellent review. I have been looking into this BS for some time now and also have put it off due to financing. But was going to purchase it with our tax return, that was of course until my wife’s van broke again. So now it’s either a new car or the Rikon…..hmmm, I think I am going to get my wife a bus schedule.
View newTim's profile
newTim
245 posts in 499 days
posted 214 days ago
Nice review. I’ve had the Rikon Deluxe for over a year now and really like it. I also appreciate the customer service. There may be a little trick you’ll have to learn to reset the tensioning assembly. The whole assembly is held in place by a square bolt that can be unscrewed if you over tension or don’t release the quick tensioning bar. It is not a safety issue and won’t happen when the machine is running. Just something that can happen when tuning or changing blades. Basically you insert a larger slot screwdriver tip through the spring to hold the bolt in place while threading it to the assembly. I don’t know all the part names so this is not clear. Once I fugured it out it was simple and the guys back at Rikon will help. BTW, same thing can happen with the 18” bandsaw.
-- tim hill www.newcalshop.com
PurpLev
posted 213 days ago
Thanks newTim thats a good tip, never really had any issues with the tensioning assembly though, mine works pretty smoothly (and I don’t always remember to release the quick tensioning bar… read- mostly not)
3fingerpat – does you wife REALLY needs to leave home? (I know…that was bad…lol)
View MyOldGarage's profile
MyOldGarage
95 posts in 319 days
posted 213 days ago
Very cool. I’ve been thinking on a bandsaw—I think I can get my grandfather’s old one to see how it all works, but someday I’m sure I’ll be on the upgrade path. (It’s an older Craftsman 14” I believe.) Nice review!
-- Bradley Miller, Blue Springs, MO - http://myoldgarage.blogspot.com
View John Gray's profile
John Gray
1748 posts in 777 days
posted 213 days ago
Nice review! Thanks!!!!
3710 posts in 871 days
posted 213 days ago
Hi Purplev;
Great review.
Glad to see a good company review.
View Tomas's profile
Tomas
27 posts in 880 days
posted 213 days ago
Purplev – I was interested in your experiences with resawing – obviously by the pictures it looks like this machine excels at resawing. I bought a junky harbor freight bandsaw so I am nervous about jumping into another 14 inch bandsaw and I am thinking of getting a 17 inch bandsaw just because I had a horrible experience trying to resaw with the HF saw – the blade had too much drift and I felt I had to really push the wood, the machine screeched through the cut and I just gave up on resawing. I was wondering how happy you are with the speed of resaw cut and the ability to saw a straight enough line on your resaws and do you think your machine can handle dense wood resaws to your satisfaction – if you were mainly going to use the bandsaw for resawing, would you still recommend your machine or go to a bigger model? – Tomas
View kiwi1969's profile
kiwi1969
600 posts in 334 days
posted 213 days ago
If it,s so quiet I hope you remember it,s running if you walk away. I,ve read about a guy who wired a light on to his saws on/off switch to remind him it was on because it was so quiet he would simply forget. Not that you should walk away without switching it off first, but we,ve all done it. Good indepth review.
PurpLev
posted 212 days ago
Tomas, One of the main reasons I got the bandsaw was for resawing – as I stated in my first paragraph, I received some Apple Logs that I had to slice down (I still have them by the way… and should really get down to cutting them up already… too many things have higher priority right now and little time at hand). but I did resaw this 11'' laminated board with extreme ease, and with a very good looking cut – both in precision, and in smoothness of the cut faces. I resaws a ~1 1/8” thick material into 2×1/2” boards , and I’m even able to use the 1/16” leftover veneer “cutoff” from that resaw for my front face of the box (I laminated it onto 1/4” birch ply for added thickness) – so, yeah, I’m extremely happy with the resaw capacity and capability of this saw – this is why I chose this one over others, and I’ve never had to regret it. the more I use it, the more I like it.
kiwi – I never forget to turn it off when I step away …. I do it on purpose ..lol (ok, j\k my workshop is so small, that you can’t really walk ‘AWAY’ anyways)
View Kindlingmaker's profile
Kindlingmaker
1469 posts in 418 days
posted 212 days ago
I too have this saw and love it. ...and I abuse things!
View BigStick's profile
BigStick
17 posts in 309 days
posted 200 days ago
Rikon 14 is a good saw and dollar 4 dollar worth the money. Just a few problems I didn’t like was the light was on the wrong side, back lighting. Also the bearing blocks we made from aluminum and were a problem from poor taping. Set screw on one was crooked but the Customer service was great and sent a new one the same day. 2 days later I was up and running. Nice machine and Rikon is really trying to put out a good products for the price.
BigStick
-- Tommy, Pa, www.bigstickmfg.com
16577 posts in 469 days
posted 200 days ago
Good review
View MikeinNJ's profile
MikeinNJ
17 posts in 197 days
posted 196 days ago
Hello Purplev, I purchased the same saw after it received good marks in a wood working magazine. I mainly purchased it because I liked the resaw capacity. However, after putting it together ( and I agree with you about the poorly written manual ) I wasn’t happy. I cannot hold a straight line even cutting in soft wood when resawing. I have used different blades, changed the speed but stilll no luck. I currently have it running with a Timberwolf resaw blade. Is there anything I seem to be missing?
PurpLev
posted 195 days ago
Mike:
quote: ( and I agree with you about the poorly written manual ) I actually didn’t have any issues with the manual.
now for the problem – have you checked the wheels to be coplanar to each other? you may need to readjust the lower blade to get a better cut. I can only assume tension on the blade is sufficient yet nor overly done? are the guides close enough to the blade to support it yet not touching it (unless pressure on the blade is excerted)? are the guides (top) close enough (1/4”) to the piece being resaws? if it’s too far that might cause the blade to drift.
there are different causes with a bandsaw for different behaviors – what exactly happens with your cut? what does “not straight” mean? does it mean you get a wavy cut but in a set direction? or does the blade drift into the fence? does the blade drift away from the fence? ( this would be better discussed in a tool setup forum, but since we’re on the subject – might as well address it here)
can always call Rikon (they are here in MA) and get a very good and helpful support from them. they would know more than anyone the mechanics of their units. they helped me.
MikeinNJ
posted 194 days ago
Purplev, thanks for the quick response. I will check on what you have mentioned. I do remember that the blade drifted from the fence. As for the other things, I wont be able to check out until Sunday, but will let you know how I make out. Lastly, I apoligize for the manual comment, must have been another review that I read.
MikeinNJ
posted 186 days ago
PurpLev, hello again. I had some time between work and little league to look at my Rikon bandsaw. If you remember I had some problems with resawing. I found that the bottom guide bearing was way off and re-adjusted it. Everything else looked fine. So, I started her up and found a piece of Oak (9” wide) and sliced it in half. Although it cut much better, it still took more effort then I think it should have, it took nearly 5 minutes to cut through at a lenght of 10”. Maybe I am expecting to much, at least the high pitched sqeaul is gone.
PurpLev
posted 186 days ago
5 minutes for a 9”x10” – no , thats not right. should be more like 30-40 seconds at most. what blade did you use for that cut (brand, TPI, hook type, width)? was the cut straight? was the cut clean or had ripples? was there burning in the wood? did the wood not feed any faster? or you didn’t try?
MikeinNJ
posted 185 days ago
Purplev, I cant remember what brand, but timberwolf sticks out in my mind. The blade is 5/8”, 5TPI and is a Hook style blade. There was no burning but there were many ripples. As for the feed rate, I was already nervous that I was using to much force. Do you think a wider and a skip tooth blade might help. Which would you recommend? Thanks again.
PurpLev
posted 185 days ago
Mike, for resawing – and especially such thicknesses (9”) you should use a 3TPI blade, with 5TPI you have too many teeth in the lumber at one time which adds resistance, and also means you have less gullets to clear the wood dust away. 5/8” should be ok. I would start with a different blade if you believe the saw is tuned up properly – I started using this bandsaw with the factory supplied 5/8” blade, and was getting poor results (not as slow as 5” to resaw- but still some resistance) and the cut would have ripples, and really rough edge. I then switched to the Woodslicer 1/2” thick blade from highlandwoodworking.com and the results are night and day – I now can pass along 11” thick material with ease, and the cut is almost jointed smooth.
MikeinNJ
posted 184 days ago
Purplev, I ordered the blade, let you know how it works. Thanks for the help.
MikeinNJ
posted 179 days ago
Purplev, I got the new blade today. I installed the 3/4in. 3tpi Woodslicer blade. I started with a good 10” inch wide piece of Oak. It was like night and day. I was so amazed, it took no effort at all to feed the work into the blade—if I wanted to, I could have pushed alot faster and the saw never skipped a beat. The finished cut was so smooth that little sanding would be necessary. I am very grateful for the assistance and very happy that I stumbled upon this fantastic web site. Thanks again, I can’t wait to find a nice log to re-saw.
PurpLev
posted 179 days ago
haha, welcome to the club. driving around now will never be a “it’s just a fallen log over there” anymore :o)
3fingerpat
posted 175 days ago
Purp, how has the saw been for you now that you have had it a while?
Have you put a mobile base on it yet?
Any changes or recommendations from your experiences so far?
PurpLev
posted 175 days ago
pat- I got the mobile base that woodcraft sells (the one you install on a 3/4” plywood platform). I got it before I bought the saw, and it works great. I don’t really move the saw much as it has a designated spot that works great for it -but from time to time I’ll have to move it and the base moves freely – no tipping over or anything of that sort, also not top heavy.
changes to the saw – not really unless you consider replacing the blade a major change- I’m still using all the “factory” parts. no upgrades – everything works like it should, smooth, and without a hitch. I’m using the saw quite often, resawing, cleanups, mortises, ripping, dovetails, curves. it is still quiet as the first time I used it, and still as powerful, hasn’t slowed down at all.
as I mentioned – I did get a 1/2” woodslicer blade from highlandwoodworking.com – as the name suggests – it slices wood like butter – pretty remarkable. see MikeinNJ’s expression about it 2 comments above – it’s THAT good.
3fingerpat
posted 175 days ago
Thanks, I did read his comments. Okay, that seals it for me, Rikon it is. Thanks again for your review, very helpful.
View EdC's profile
EdC
457 posts in 732 days
posted 150 days ago
Purple,
I bought the 14” Rikon Deluxe last week and didn’t get a chance to set it up till last night. No offence meant but your going to ruin your body lifting things like that saw. I’m a big guy. but there was no way I was goimg to take a chance, lifting it by myself. Who knows maybe I’m wimpimg out in my old age.
First off Rikon should hire someone who knows how to write a manual, that is one of the worst manuals I have ever seen.
We got the saw fastened to the base and I was sitting in front of the saw looking at where the Trunion sits, thinking about how the table mounts to the Trunion. Then I noticed that the Lower Trunion Assembly is broken in Two places. If you look in your manual on page 20, it is part number 180. You will see there is a bolt in the front of the Trunion that attaches it to the saw frame. The Trunion is busted on both sides of that bolt hole. So others with this saw may want to check their saws, to make sure this isn’t a weak point.
I called Woodcraft about the problem yesterday and they were great about it. I live 50 miles away from there store, so it’s a good bit of the day going to their store and home again. They said they will be at my house at 8:00 am tomorrow with a new saw that they will assemble for me.
Hopefully I will be as happy with my saw as you are with yours. The reason for buying the Rikon was based on the positive reviews it has recieved. As well as the great features it has, such as the Resaw ability.
-- Ed - Milan, IN
PurpLev
posted 149 days ago
EdC – no offence taken :) thanks for sharing you experience- I’m sure it’ll help he overall feedback on this machine that others can benefit from.
as far as weight – I highly recommend getting help putting this together, no questions asked – however, I myself (and I’m sure others as well) sometimes don’t have that available at most times, and as such, I merely suggested that although not recommended – it IS possible to put this things together by youself – most definitely not with brute force though! I used several lifting jigs (pullies, and straps) to assist me with that.
sorry to hear you ran into manufacturing defects, but esp. in todays economy it is expected for each brand to have some errors – Rikon shines when it comes to backing up their machines, and taking responsibility for it – as you can see for yourself. hopefully Woodcraft will make it easier on you, as this is a great machine to have at your disposal. Enjoy!
View Rick's profile
Rick
63 posts in 102 days
posted 101 days ago
Hey PurpLev. I just wrote a review for this bandsaw on L.J. You have a little more experience with it than I do so I’d like to ask you a few questions. I’m now noticing a little vibration and I can surely tell that this bandsaw is on when standing a few feet away. Is everyone elses Rikon lack ANY vibration and so much quieter than mine? I just tried to rewaw a plain old 2×4 and it was kind of slow going through. I’m using a 3 tpi 1/2inch Lenox. That was my very first cut with a bandsaw and I didn’t know what to expect. Maybe I need a 6 tpi or more blade?
Thanks.
PurpLev
posted 101 days ago
congrats woodplay – this is a good quality machine. Yes – mine is vibration free – even though it’s on a mobile base! the only noise I started hearing as of late has to do with the wheels squeaking – but it’s just noise, without vibration.
make sure everything is nice and tight – also the lower cabinet bolts needs to be tightened down. and try to run the saw without a blade in it – if you still get vibration – it’s the motor, if not – than something with the wheels is causing it.
as for the Lenox blade and quality of cut – I only used 3 blades on my saw – the factory supplied one which is a crappy blade, I’ll only use it for backup if I must. but for all other cuts I use the woodslicer 1/2” 3tpi. after reading good reviews on it here on LJ I picked one up (highlandwoodworking.com) and could not be happier – the saw slices through 12” boards with ease, and produces a very clean cut. for resawing you want the least amount of TPI because there is a lot of material that is being removed, and you need lots of gullets to take that material away.
View azwoodman's profile
azwoodman
62 posts in 273 days
posted 49 days ago
PurpLev, Great review! I am saving up for a bandsaw (convincing the wife that I “need” it) and this one has been on the radar. Im glad to hear that its working well for you.
-- -Spencer, Gilbert Az (http://www.azwoodshop.com)
