| Review by RUINTUIT | posted 230 days ago | 2406 views | 2 times favorited | 12 comments | ![]() |
- Husky 17181116 Heavy-Duty X-Sawhorse
- Brand: Husky | Category: Supports and Bases
This is the ultimate accessory in my garage shop. It, and it’s twin, gets pulled out on nearly every single project I take on. Sometimes it becomes semi permanent, and other times it’s out for an hour or two. I saw this table/horse about 2 years ago while strolling down the “Hey look at me, take me home” display isle at Home Depot and since I was with my wife she nonchalantly wiped the drool from my chin and said “Lets go to the plants now!” Since it was near Christmas time, I’d hoped she’d gotten the hint. SHE DID! Opened it up on Christmas day and although I can’t say for sure, I’m thinking I used it sometime for something within a day or two of that wonderful day. So that’s how I got one. Now, on to what I think of it.
The horse is nearly as light as the common plastic fold out single beam horses that everyone including 7-11 sells. It’s width is possibly an inch wider when folded. It’s height when opened is 31” It’s strength and versatility unparalleled. The table top snaps off the aluminum tube which forms the axis of the X, and snaps in on top when the X is opened. There is a lock mechanism, but I rarely use it since I use it mostly for setting things on. I’ve seen two models, one with aluminum legs which I have, and one with heavy plastic legs. I don’t know of there’s really a difference, but the aluminum looks nicer. The top is 24”x24”, plus the tops of the legs give a little more width and depth. One leg is adjustable for less than flat floors.
If you’ve got smooth garage/shop floors, the table with a load slides pretty easy if you need to move it around.
Some of the things I’ve used it for:
1. I have a piece of granite about 1.25” thick, 24”x32” that I use from time to time for sanding and checking to ensure my projects sit flat. It fits nicely on the horse
2. I have a 10” Delta miter that sits on the top from time to time while cutting molding, 4×4 posts, etc
3. I have a Shop Fox 10”x16” lathe (120lbs) that sits on it from time to time and with a 3/4” piece of pine underneath the lathe, it’s the perfect height for me at 6’1” to turn way too many pens.
4. I’ve used it to put my Dewalt 734 planer on
5. I’ve given them for Christmas to my step son-in-law….there’s a 32” tube TV on his
5. I’ve used it and it’s twin for a stable stand and throw a piece of plywood over them for an assembly table. Much more stable than the fold out horses.
6. I’ve used it as a side table when working on something and need to put my tools down on or hold parts.
7. I’ve used it as the base of a table when serving guests
8. I’ve used it to stand on
9. My Dad was so impressed he bought one for himself, for a furniture finishing stand
10. My sister saw it and he bought her one for Christmas.
11. I’ve used it to …...the list truly goes on and on.
If you’ve got a Home Depot near by, check it out…you won’t be disappointed. They go for about $40 each…so grab two.
-- Scott, Irmo SC
12 comments so far
davidroberts
home | projects | blog
245 posts in 385 days
posted 230 days ago
thanks for the review. i saw this on “Cool Tools” a few months ago. I have two B&D portable workmates that are indespensible. I’d like to pick up one (or two) of these. they look sturdy and well engineered.
-- david roberts, houston area, "A little knowledge is a dangerous thing, but that has never been a problem for me."
rtb
681 posts in 612 days
posted 230 days ago
I’ve had one of these for a couple of years and its everything Scott says it is and more. Its rare that mine even gets folded up. in many ways it better that a saw horse ( how much can you lay on top of a saw horse? )
clieb91
682 posts in 834 days
posted 230 days ago
I also have one of these and used it a lot before I built my shop table. They are quite strong and a very good tool stand. Still use it when I have projects to do outside of my shop.
CtL
-- Chris L. "Don't Dream it, Be it."
buffalosean
61 posts in 286 days
posted 228 days ago
how does the planner work on it. do you secure it staight to one stand or is it secured to a piece of lumber across the two stands?
-- Sean Buffalo, New York
OutPutter
321 posts in 889 days
posted 228 days ago
I’d appreciate if anyone can locate one now. I think they’re discontinued at Home DePot.
-- Jim
Mike67
5 posts in 235 days
posted 227 days ago
I have one of these and keep my lunchbox planer on it. Works great although I think it places the planer a little higher than ideal. Mine is the version with plastic legs and there’s a little flex in them when I plane larger boards, but not much.
I just used some clamps to attach the planer to the stand.
kosta
372 posts in 253 days
posted 226 days ago
these saw horses are a lot better then the old wood ones that weighed 30 pounds. He is a link to a good video. http://www.diynetwork.com/diy/shows_dctl/
-- kosta brownsville brooklyn my home
oldskoolmodder
707 posts in 579 days
posted 226 days ago
Like others’ here, mine rarely comes down. It’s too useful.
Greg Wurst
716 posts in 731 days
posted 225 days ago
I have a pair myself. They are used for almost everything and the best stands I have in my shop. I hardly ever get-out my other sawhorses and tables unless I need the extra space, and when I do I wish I had more sets of these stands. If they have been discontinued that would be a real shame.
OutPutter
posted 224 days ago
Sadly, I think they are discontinued.
-- Jim
dave33
12 posts in 227 days
posted 223 days ago
Damnit these are so cool. My local home depots dos’t have them either. Any idea where else to find them?
Greg Wurst
posted 206 days ago
Good news! I found some of these at the HD in Cincinnati:
I don’t know if they are available again or just what’s left at this store. Here’s the address if you’re in the area:
Pleasant Ridge #3832
3400 Highland Ave
Cincinnati, OH 45213
(513)631-1705
