| Review by Tony | posted 236 days ago | 975 views | 1 time favorited | 24 comments | ![]() |
- Mirka Abranet
- Brand: Mirka | Category: Sanders
I have recently been undertaking a lot of experiments with the relatively new product called Abranet, made by a Finnish company called Mirka. I have been using their cloth and paper backed disks for many years, with excellent results and feel very confident with the company for quality and reliability. However, after being given some of the Abranet product to trial – I am replacing all my paper and cloth backed disks with this new product.
The Abranet comes in grades P 80, P 100, P 120, P 150, P 180, P 240, P 320, P 360, P 400, P 500, P 600, P 800, P 1000 the material used is Aluminum oxide, bonded with resin to a Polyamide fabric backing. It is available in 6”, 5” and 3” disks as standard, also available in rolls and sheets for hand and other machine sanding.
I have found that this product, when sanding white oak, with a random orbit sander last 3 – 4 times longer than conventional cloth or paper backed disks. When sanding items that have been finished with paint or oils, that the Abranet disk does not become “clogged up” and if a residue does build up, then simply removing the disk, giving it a quick shake will dislodge about 99% of any material.
Dust, yes it crates a lot of dust, because it is so efficient at sanding, but I have found that my AEG, 8 hole ROS will pick up far more sanding debris, than it would with a conventional disk (and it was extremely good before). If I add a vacuum to the extraction port, then I get virtually 0 dust.
Heat, Non really, because it is so open-mesh, most of any heat is diffused by the surrounding air. Try it on the lathe for sanding a spindle or a bowl, whereas with conventional sanding disks or sand paper, you will feel the heat pretty quickly, almost to the point of burning fingers, the Abranet is definitely “cool running” all the time.
Aggressive sanding, you get a lot of stock removal quite quickly, even with the P 120, but you also get a very clean, even sanded surface when you finish, without unsightly scratches.
Interface Pad (picture 2). This pad is an optional extra (I recommend using it), but it is designed to be placed on your existing Hook & Loop pad and has 2 effects 1 – you add and remove the disks from the pad, not the ROS, therefore saving wear and tear on your ROS Hook & loop (these ROS Hook and loop are expensive to replace) and 2, the interface pad comes in 2 thicknesses, 3 mm and 10 mm, the 3 mm is designed for normal flat surface sanding, but the 10 mm is for contour sanding. The price of the 3 mm interface pad is about $6.00 each and come in packs of 5.
The price of the Abranet will vary on your distributor, but I would think about $1 to $1.50 per 5” disk. if like me you buy boxes of 50, then price comes spiraling down – do not forget they last a longer and give a better finish, so worth the extra cost – I will almost guarantee once you have tried one disk, you will not look back in anger.
If I could give this product more than 5 stars I would – it is tremendous
Here are some links to the product:
Abranet
Effective Wood Sanding PDF
PDF Pages of sanding information
Mirka USA
24 comments so far
builtinabarn
home | projects | blog
81 posts in 278 days
posted 236 days ago
How about cost difference between the paper or film back and the Abranet?
OOPS, I wrote before I read the entire post. Thanks for posting
-- Built in a Barn Bob
builtinabarn
posted 236 days ago
Five years ago, a Mirka rep. brought some prototypes of this to my shop to use. It was defiantly an awesome product. I have asked my sandpaper dealer about the production of and the introduction of this product for years, and know body could answer me. Im glad you posted this so I can search out a source .
ND2ELK
6165 posts in 667 days
posted 236 days ago
Hi Tony
Every sight I looked at tells me about the product, which is fine. How much does it cost and where can we buy this product in the USA? Please advise?
Tom
-- Mc Bridge Cabinets, Iowa
Tony
811 posts in 924 days
posted 236 days ago
Hi Tom
Sorry I cannot really help you as I live on the “wrong side of the pond”,
I have just spoken to Mirka USA 800 843 3904 about the availability of their products in the USA. They said if individuals would like to call there free phone number – they will be more than happy to give you the details of the distributor closest to you.
I must admit the Mirka-USA website is less than helpful, with regard to contacting them (except for telephone)or listing their main distributors, but I guess with 50+ states and 1000’s of big towns, they would need a website just for distributors.
If you still have problems getting the product, let me know and maybe I can start an export business selling the Finnish made product in the USA, because you cannot find a retailer there to sell you the same US manufactured product – now that is good for the recesion (for us anyway) :) :) :)
depictureboy
306 posts in 536 days
posted 236 days ago
Google is your friend.
Woodcraft
Amazon
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
jwicks
32 posts in 501 days
posted 236 days ago
They sell them at Woodcraft:
http://www.woodcraft.com/family.aspx?FamilyID=5922
-- Jon
LonelyRaven
28 posts in 257 days
posted 236 days ago
Funny this thread came up…I saw this stuff at Woodcraft, and had trouble finding anything about it online except for Woodcraft and Amazon (as listed above).
I bought the bulk pack and the protective layer thing just this Monday, and I’m eagerly awaiting it’s arrival. They don’t make a backing pad for my Bosch palm sander, so I couldn’t get that, but it looks like it would help with the dust removal because it probably double the amount of air holes in the backing pad to improve the air flow through the Abernet abrasive sheet.
Doing a little research, it appears they also make sanding blocks with a vacuum port, but they were only 2 3/4” wide or something like that…I really wanted a 4” X 7” sanding block for larger projects where I would want to do them by hand, but need to cover a lot of surface as evenly as possible….so I didn’t order it.
I can add my own report later if anyone cares…I’m hoping to receive the shipment and start using the pads this weekend!
Tony
posted 236 days ago
Lonely Raven
Mirka do make larger sanding pads, up to 4.5” x 9”, but you may have difficulties in finding a supplier, following the comments of the thread so far – Call Mirka, I am sure they will be able to help you.
The extra holes in the protective pad will not help you remove more dust, it is a function of the holes in you ROS pad. The extra holes allow the pad to be rotated to a new position should one are become warn.
I am off to pick up my next batch of disks and pads tomorrow (500 disks, 10 boxes), the price here for one disk is about $1.59, but when you by a box of 50, the price comes down to $1.03 each and the backing pads are $20 for 5×3 mm pads, which includes a 22% sales tax on all products.
I look forward to hearing you comments on this product, I am sure you will not be disapointed
Dusty56
3460 posts in 581 days
posted 236 days ago
Excellent review , Tony . I hope you’re getting a good commission from Mirka : ) LOL
Tony
posted 236 days ago
Dusty, I only wish I was getting a commision from them. It would save me a fortune :)
Dusty56
posted 236 days ago
Hahahaha, I can see your smiling face on one of their advertisements already ! LOL
YorkshireStewart
781 posts in 795 days
posted 236 days ago
I bought some sample packs of the small rectangular sheets at a woodshow last November & just this week ‘discovered’ them hiding in my ‘shop! I, too, am very impressed and will be ordering some more. Thanks, Tony; I didn’t realise this stuff available as discs too.
-- Res severa verum gaudium - True pleasure is a serious business. http://www.folksy.com/shops/TreeGems
25793 posts in 1294 days
posted 236 days ago
I picked up 2—sheets of 400 grit on ebay for about $20.00 It seemed to be great. I did use the product with a 1/4” foam back for my Corian countertop. I went to 3000 grit for a semi gloss finish. I used it wet with dish soap in some water.
cabinetmaster
8532 posts in 452 days
posted 236 days ago
Thanks for the post Tony. I did not realize they had so many different grits. We use the 400 in our shop all the time. Great stuff.
Douglas Bordner
3421 posts in 957 days
posted 235 days ago
Thanks Tony. I’ll have to give it a try. I swear by the Abralon pads by Mirka. They come in grits 500 – 1000 – 2000 – 4000 for final rubout of finishes, and they work fast. I was going to recommend Jeff Jewitt’s homesteadfinishing.com site as a source – but it looks like it might be down permanently…
Grampa
19 posts in 328 days
posted 235 days ago
First of all, Thanks for the review.
I just got off the phone with Arturus, at Supergrit, who handles the abranet discs in all sizes, and was able to answere most of my questions. Also much better prices than Woodcraft.
Woodcraft: 10 (6” discs) any grit are 17.99, pad protector 6” are 19.99 for 2, interface pads 6” are 14.99
Supergrit: 10 (6” discs) are 8.25, 80 grit is 9.00 for ten
6” protector pads are 7.00 ea,
6” interface pads ( mirka) are about 5.00 ea
The website is www.supergrit.com
Hope this is useful to all of you Thanks Doug
-- -- Doug H, MI
LonelyRaven
posted 235 days ago
Homestead is here now, Douglas:
http://www.homesteadfinishingproducts.com/
SCOTSMAN
2238 posts in 479 days
posted 235 days ago
I am looking forward to trying it too!Alistair
FlWoodRat
582 posts in 803 days
posted 235 days ago
You can find even Mirka higher grit wet/dry at automotive refinisher/paint shop supply stores
I got a couple of half sheet 50 packs of 400, and 1200 for around $15 dollars each.
You can follow this link for some more information http://mirka-online.com/products.html
-- I love the smell of sawdust in the morning....
Scott Wigginton
45 posts in 639 days
posted 234 days ago
I wonder how well their Abranet Sheet Sanding System works? Interesting concept having DC with hand sanding.
-- Scott
Tony
posted 234 days ago
Scott When I picked up my supply of Abranet yesterday, I had the opportunity to try the sheet sanding system out.
It is worthy of separate review – In summary I found it to be excellent with absolutely zero dust (when used with a vacuum) very comfortable and solid in the hand.
Bruce (AKA FlWoodrat) the mesh system that goes above 1000g (and also below) is called Autonet or Abralon (two more products), a very similar and slightly different product, about the same price and equal in performance at the higher grits, but I have never needed to go above P1000 with the Abranet to achieve perfect results on wood.
The link provided by FlWoodrat certainly seems to have extremely competitive prices and well worth investigating further.
FlWoodRat
posted 234 days ago
TONY.
Thanks for the information. FYI, I use the MIRKA high grit Wet/Dry abrasives just for sharpening tools. I seldom go past 220 on wood or over 400 grit on a finish.
builtinabarn
posted 234 days ago
Woodworkers supply abrasives company is “A and H Abrasives”. I found after a little research, that they have the best prices.Their # is 800-831-6066, call and request a catalog. They are a great company to deal with. They also can make many custom things. I had them make some custom size sanding belts and some other custom things for my drum sander. I was really impressed.
matt garcia
716 posts in 565 days
posted 232 days ago
I just found these online myself. Went to our local Houston Woodcraft and purchased the 320 and 400 grit. I am not going to final sand with anything else. These discs are just what I was looking for for my 5” P/C random orbit sander. I was told at Woodcraft that they are also longer lasting than paper.
-- Matt, Houston Texas
