| Review by DAN | posted 237 days ago | 1112 views | 0 times favorited | 29 comments | ![]() |
LOCKTITE POWER GRAB is crap.
I glued and clamped six large landscape tiles to a plywood board with Power Grab thinking it would be an improvement over my normal method of Gorilla Glue (sometimes a little messy).
NOT
I HAVE NEVER in all my years used anything that worked so poorly. REALLY REALLY BAD.
Last night I applied 3/4 a tube to fasten my tiles to a plywood backer board. I lightly clamped the tiles with spring clamps and let it setup OVERNIGHT ... (over 20hours).
Came home from work and removed the clamps.
When carrying the large framed piece from one room to the next I needed to lift it over my head to clear some cabinets. One of the tiles fell out and clunked me in the head.
Luckily the tile did not fall to the floor and break.
I sat the framed tiles on my table saw.
Every tile came loose with only finger pressure.
The adhesive (if you could call this crap anything close to that) did not stick to plywood at all
I’m in the process of scrapping the hardened CRAP off the back of the tiles to start over.
My only positive statement is I did not break any tiles.
There is no option for ZERO stars in the rating. That is the only reason I gave it a single star.
THIS IS NO JOKE. THIS IS THE WORST ADHESIVE ON PLANET EARTH.
29 comments so far
Douglas Bordner
home | projects | blog
3421 posts in 957 days
posted 237 days ago
I tried a caulk tube of some of this to install beadboard. All it did was inspire a trip back to the big box for some good old toxic, non-water clean up Hansen’s Liquid Nails (likely known to cause three-headed salmanders AND Cancer in California). The stuff didn’t hang on long enough to get finish brads shot through it.
14914 posts in 744 days
posted 237 days ago
Thanks for the tip Dan. Will be wary of that one. Sounds like a very sticky situation.
posted 237 days ago
DAN
6438 posts in 876 days
posted 237 days ago
oldskoolmodder
707 posts in 573 days
posted 237 days ago
Nice to know. Sad thing is, that at least Liquid Nails WILL WORK, toxic or not.
timbob
6 posts in 309 days
posted 237 days ago
I got a tube you can add to your trash pile too. The stuff is useless, but the commercials were funny.
Gary
576 posts in 326 days
posted 237 days ago
whats sad about Liquid Nails working? I like Liquid Nails. It’s great on pancakes. REALLY sticks to your ribs!!
-- Gary, DeKalb Texas
John Gray
1751 posts in 778 days
posted 237 days ago
Did you contact Loctite customer service? If so what did they say?
TopamaxSurvivor
3014 posts in 569 days
posted 237 days ago
Is that the stuff where they hang a hammer from the ceiling in the commercial?
savannah505
978 posts in 479 days
posted 237 days ago
Epoxy works for me, liquid nails should do you okay too though.
-- Dan Wiggins
Cory
196 posts in 312 days
posted 236 days ago
Not sure what I’m doing differently, but I have had good luck with Loctite. I’ve used it in quite a few different situations and never had the bad results you experienced. Maybe it’s a bad batch?
-- Premium firewood created daily.
PurpLev
2733 posts in 541 days
posted 236 days ago
I have to second Cory – I have been using this stuff for several years with very good results for different applications.
CessnaPilotBarry
1263 posts in 596 days
posted 236 days ago
Dan,
Did you call the number on the tube? Is the tube freshness dated? I haven’t used PowerGrab, but I have a lot of respect for Loctite products.
That said, I’d be very interesting in hearing what Loctite says if you called and shared your poor experience with them.
Thanks for the detailed, straight shooting review.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
getneds
146 posts in 249 days
posted 236 days ago
I use Loc-tite heavy duty construction adhesive. its equivelent to Liquid nails H D. This tuff is very strong and has tremendous holding power. It comes in 19 oz. tubes. To put tile i’d use that and a trick is:
1. put the beads of glue where needed.
2. Press together
3. pull apart and let set 2 – 3 mins.
4 press back together and viola!
Works like contact adhesive this way. but use enough and don’t be skimpy.
-- Woodshop supplies at bulk discounts. www.getneds.com
Don Niermann
155 posts in 865 days
posted 236 days ago
I have had problems with epoxy from them and will not buy anything with that name.
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
dusty2
111 posts in 322 days
posted 235 days ago
I have no experience with this product but -
If it stuck to the tiles as indicated in the beginning of this thread but did not stick to the plywood maybe, just maybe preparation is part of this problem and NOT the product itself.
It may even be that it is not intended to stick to wood. Loctite is a product line that has been around for a long time and I thought had a pretty good reputation. I suspect we have a premature, knee jerk reaction here.
-- Making Sawdust Safely
dennis mitchell
3789 posts in 1207 days
posted 235 days ago
I’ve seen Dans work. I really Really doubt that it was preparation. Using construction adhesive is not rocket science.
Many times a “pretty good reputation” comes from advertising.
Is it really that hard to believe that they might be a little misleading in their claims?
I know of many adhesives that would hold the tile just fine.
Don "Dances with Wood" Butler
275 posts in 288 days
posted 235 days ago
I LOVE Powergrab!!!!
I have an installation in a public building, a set of large, heavy columns fabricated in MDF, affixed to the existing substrates with no surface prep.
They have been there for a couple of years now with no separation issues.
I also use it in my shop for various quick-stick needs.
But I haven’t stuck a hammer on the ceiling.
Yet.
Best regards,
d
-- If a man says something in the forest and there's no woman to hear it, is he still wrong?
TopamaxSurvivor
posted 235 days ago
There must be some consistency issues with this product. I tried it to hold some small electrical parts on concrete columns. The failure was 100%.
DAN
posted 235 days ago
The adhesive easily scrapped and peeled off the tiles easily with a chisel. Wonderd myself it was just a bad batch.
After 24 hours of dry time I expected it to setup like a solid rock.
It might have been a little cool in my basement, probably in the 60’s. Also I failed to mention it was on bending plywood … not that it should make a difference. I’m gluing them in with my old tried and true gorilla glue tonight and will post a photo here when completed
Brad_Nailor
1213 posts in 850 days
posted 235 days ago
Wow…interesting…exact opposite results with the same product.
DAN
posted 233 days ago
something else I remember is the bead of adhesive when squeezed out of the tube didn’t stick real well . When I touched it with my finger it didn’t feel stickey. Kind of dry or chalky. Thinking back I should have stopped right there.
I finished gluing the tiles with gorilla glue last night and hung display up today. Will snap a photo and post
Tango
15 posts in 446 days
posted 222 days ago
Well….they might change the product name to….”Piece of Grab”....
posted 221 days ago
Its worth noting that PowerGrab isn’t just one thing. There are a number of different formulations for specific applications. I have a couple of different ones on my shelf. Just grabbing a tube of PowerGrab without noticing what its intended to do can result in adhesive failure.
I don’t mean to fuel an argument, just offer some information. I know the stuff has been, for me, everything I wanted it to be.
don
CessnaPilotBarry
posted 221 days ago
Good point, Donbee…
I’ve seen similar confusion with all threadlocker’s referred to as “Locktite”, Kilz products, “Bullseye”, “Goop”, etc…
DAN
posted 221 days ago
I thought something was fishy … should never had used it. I recall toughing the stuff, ... right out of the tube and it wasn’t—sticky, ...but,,, had a more chalky surface. Must have been a bad batch, maybe it had been frozen.
cicerojoe
2 posts in 338 days
posted 196 days ago
I have had identical bad experiences with this adhesive. It did not work at all. I now stick to the polyurethane PL.
16683 posts in 470 days
posted 196 days ago
bad stuff
Don K.
1095 posts in 219 days
posted 196 days ago
Wow, I am surprised… I have had nothing but good luck with it. Even used it to put up a tile back splash on one of my rent house’s a few yeas ago….All still there.
-- Don S.E. OK
