Abrasive sanding ball
Review by htl posted 01-01-2016 09:53 PM 3624 views 0 times favorited 1 comment Add to Favorites Watch
Abrasive sanding ball Abrasive sanding ball No-picture-s Click the pictures to enlarge them
A couple a months ago I needed a flap sander and went to Harbor Freight to pick one up, they had tons of sanding thingys but flap sanders no.
The closest thing was this Abrasive ball they have 3 different grits and I got the 80 grit to test out.
What it turns out to be is pads like you would use to clean a greasy pot in your sink bolted together to make this ball but with a little bit of sand or other grit glued to the out side.
I got the 80 grit thinking it would make fast work out of some leaves I was shaping [wanted to round off the sharp edges] but the out side sand didn’t last any time BUT and it’s a big BUT the ball turns out to be great at buffing out small parts like the leaves and now on my toy excavator parts.
It will get the fuzz off and put a shine on wood with out rounding off the edges.
Plus it doesn’t catch on the small parts and rip them out of your hand.
It also works great on larger flat parts as well.
So it falses as a shaper or rounder of parts but it’s a 5 when it come to the buffing of small parts I’m working with right now.
You won’t find it on the web sight but I bought a new one in Huntsville today so their in the store.
Turns out it is on the web site under 80 Grit Abrasive Ball
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
View htl's profile
htl
4317 posts in 1394 days
1 comment so far
View Bill1974's profile
Bill1974
127 posts in 3220 days
#1 posted 01-04-2016 06:27 PM
I have used these to buff and shine up copper pipes. Makes a nice uniform finish and is much quicker than trying to do the same with sandpaper. It has it’s uses and it’s inexpensive.
