| Review by knotscott | posted 249 days ago | 1036 views | 0 times favorited | 3 comments | ![]() |
- Scheppach Tiger 2000 Wet Sharpening System
- Brand: Scheppach | Category: Sharpening Accessories
Once I acquired some functional chisels, and a fleet of hand planes, I needed an easy and effective method to keep a good edge on all of them. I initially bought a little jig that held the blades at a set angle and allowed me to work the blade back and forth across an abrasive surface…it worked ok but took a fair amount of time. I also bought a small Delta Utility Sharpener that didn’t work quite as well, but was a little faster. When the Scheppach Tiger 2000 went on sale for near $100 with free shipping, I couldn’t resist.
The Tiger 2000 is a wet/dry slow speed blue aluminum oxide grinding wheel type system that has an 8” x 2” wheel and a leather honing wheel. The system includes a tool rest, a blade holder, angle gauge, water tray, and a polishing compound for the leather wheel. It’s eerily similar to the Harbor Freight unit, but has a metal housing and a more palatable color scheme! ;-) This type of system is a smaller version of the Tormek and Jet 10” systems. One benefit of the grinding wheel systems is that they leave a hollow grind on the bevel which is desirable to many users.
The system is simple and intuitive to use. You flatten the back edge, mount up a plane blade or chisel in the holde, and adjust to the appropriate angle and create a bevel. Within a few minutes you’ll have a decent edge that’s actually fairly sharp, but it’s the honing wheel that turns it into a shiny razor! I’ve used it both dry and wet. The process does create some dust when dry, or messy water when using the quenching tray. A diamond dressing tool keeps the wheel true and fresh.
I’m not sure how this compares to the Tormek, Jet, Grizzly 10” systems, and have never used the Worksharp system, but it’s effective, simple, and reasonably priced.
(currently on sale at Woodcraft for $119.99 as of 3/21/09)
3 comments so far
Mark Shymanski
home | projects | blog
1555 posts in 609 days
posted 249 days ago
Thanks for the review. I’m still sharpening by hand, but I have a hard time with some of the chisels I have to keep the angle constant.
mrsawdust
47 posts in 463 days
posted 249 days ago
knot,
good review. i’m still debating on which brand to purchase and i’m reasonably sure it won’t be a $400 model. i think i’m getting a little jealous. seems your getting a new tool everyday. i like the way you do business….
mike
-- mrsawdust, pittsburgh,pa.
knotscott
529 posts in 272 days
posted 249 days ago
Hi Mike – Nah, very few new tools….just new reviews on this site!
