Butterfly Inlays Made Easy
Review by knotscott posted 03-21-2009 01:25 AM 3706 views 1 time favorited 7 comments Add to Favorites Watch
Butterfly Inlays Made Easy No-picture-s No-picture-s Click the pictures to enlarge them
Even for a first timer, this inlay kit worked flawlessly as advertised. Using just basic router skills, it couldn’t be much simpler. Put the bit and the guide bushing in the router, trace the template to cut the receiving hole, add the spacer to trace out the inlay with the same template, cut the inlay piece free from the stock, and place it in the complimenting cutout hole. Some sanding may be required to make everything flush, and a practice run is always a good idea. The tip of the bit is fairly small, so light cuts are recommended.
I used a Woodcraft template much like the one shown below, and the Freud bit and bushing set in my Freud FT1700 router. This is a high quality brass set that worked like a charm for me on my first try.
Here’s my first results:
View knotscott's profile
knotscott
8151 posts in 3580 days
7 comments so far
View interpim's profile
interpim
1170 posts in 3663 days
#1 posted 03-21-2009 03:41 AM
Great review!
-- San Diego, CA
View tenontim's profile
tenontim
2131 posts in 3949 days
#2 posted 03-21-2009 04:57 AM
I have one of these too, and really like it. If you have access to someone with a laser cutting rig, you can design your own templates on AutoCad and have them cut out in some Lexan. If you don’t have AutoCad, most shops will do it for a fee, if you provide the pattern. Just keep in mind the difference in size between the guide and the bushing.
View Todd Thomas 's profile
Todd Thomas
4969 posts in 3653 days
#3 posted 03-21-2009 12:25 PM
thanks for the information….I’m looking at getting this as well….keep the reviews coming…good job
-- Todd, Oak Ridge, TN, Hello my name is Todd and I'm a Toolholic, I bought my last tool 10 days, no 4 days, oh heck I bought a tool on the way here! †
27250 posts in 4027 days
#4 posted 03-21-2009 02:21 PM
Thanks for the review. I have been meaning to try this and this review has been helpful.
View Peteybadboy's profile (online now)
Peteybadboy
528 posts in 2154 days
#5 posted 01-26-2015 04:56 PM
I just got one. Made a custom template out of 1/4” hardboard. Question….how deep should you make the hole? The bit can go very deep unless you get a different length bit. What depth works well for you?
-- Petey
knotscott
#6 posted 01-26-2015 05:51 PM
- Peteybadboy
Good question that I don’t have a definitive answer for. I’ve generally gone in the range of 3/16” to 1/4”, then sanded them flush, but it just seemed intuitively ok at that thickness, be it right or wrong. If the main material is thick enough, I see no reason you couldn’t go deeper. You will find that those tiny 1/8” diameter cutters break pretty easily….go slow or take multiple lighter passes, or both.
Peteybadboy
#7 posted 02-13-2015 07:15 PM
When I cut out the insert it does not fit. It requires a bit of sanding. With fragile inserts its difficult. Anyone else experience this?
-- Petey
