The Super General is King!
Review by knotscott posted 03-20-2009 07:40 PM 6155 views 0 times favorited 6 comments Add to Favorites Watch
The Super General is King! No-picture-s No-picture-s Click the pictures to enlarge them
One glance of the 010-044 Super General gives the immediate impression that this is a state-of-the-art blade, and is made to world class standards. The materials used are the finest examples available, and the manufacturing techniques used are nearly flawless. The teeth are among the largest I’ve seen on any blade, and the gullets are noticeably deep.
Two distinctive design characteristics of the Super General’s tooth geometry are what sets it apart from most other premium general purpose (GP) blades like the Forrest WWII, Tenryu Gold Medal, or Ridge Carbide TS2000. It features a Hi-ATB grind that offers a steep 30° alternating bevel across the top of the teeth, and a double side grind. Most GP blades use a shallower standard ATB grind. The new Freud Fusion F410 is the only other blade I know of with a similar design. These two blades are really in a separate class from the other premium 40T or 50T blades. The “Hi-ATB” grind has the lowest tearout of any grind available due to the sheering action that it creates across the fibers. This grind is typically seen in dedicated higher tooth count crosscut blades used specifically for ultra fine cuts in veneers, fine plywood, and melamine. The result of the Hi-ATB in this 40T general purpose configuration is extremely low tear-out on crosscuts in hardwood, plywood, and sheetgoods, and very clean rip cuts. The double side grind enhances the polishing characteristics of an already low side clearance, resulting in a very smooth glassy surface that’s also typically only seen in the higher tooth count specialty blades. I’m actually able to recognize cuts made by the Super General by inspecting the edge of the board, which is really pretty amazing, because it’s typically very hard to distinguish cuts made by most other premium general purpose blades. The downside….the Hi-ATB grinds are a bit less efficient at ripping thick stock than some standard ATB or ATB/R 40 tooth blades, but it’s still more than adequate to rip up to ~ 2” without much struggle, depending on the saw and the material. Also, the features that provide the highly polished edge can increase the chance of burning if the saw bogs or the feed rate slows too much in thick material…raising the blade height and increasing the feedrate will usually help if that’s the case. I’d also expect the tips of the steep bevel to abrade a bit more rapidly than those on standard ATB grinds, but hobbyists should still get very good edge life.
The Super General is a super choice for general purpose work that requires clean rip cuts with polished edges, excellent cuts in ply or laminates, or fine crosscuts….all with the benefit of not needing to change blades. Really a remarkably smooth cutting blade. You’ll have to buy two separate dedicated task blades of comparable quality to do better….one for ripping, one for crosscutting, but neither will do well outside of their dedicated range, so will need to be changed out for each task.
Note – The Super General is now available in both a 3/32” thin kerf, and 1/8” full kerf widths.
View knotscott's profile
knotscott
8120 posts in 3490 days
6 comments so far
View Emeralds's profile
Emeralds
143 posts in 3677 days
#1 posted 03-20-2009 07:57 PM
A very nice review. I’ve enjoyed your series of TS blade reviews and have found them quite useful.
Thanks for the insite.
Keep em coming.
Joe
-- JMP
View Chris 's profile
Chris
1879 posts in 4106 days
#2 posted 03-20-2009 09:12 PM
FYI…. Forrest offers a HiATB version as well.
What does the Infinity go for $?
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
knotscott
#3 posted 03-20-2009 10:08 PM
Hi Chris – I know Forrest offers a Hi-ATB in their Duraline melamine/laminate/plywood blades and their WWI crosscut blade, but thought their WWII is a more standard ATB. The WWII’s I’ve used are not Hi-ATB….checking their website, it says the WWII has a 15° ATB. Is their Hi-ATB general purpose blade something new, and do you know if it has a dual side grind as well?
From the Forrest website, WWII description:
The Super General is ~ $100.
Chris
#4 posted 03-21-2009 07:12 PM
So it’s price is comparable to the General… Definitely food for thought.
View JohnnyDust's profile
JohnnyDust
73 posts in 2601 days
#5 posted 08-16-2011 06:32 PM
Purchased this blade a couple of weeks ago. At the same time I did a motor upgrade on my saw and put the both of them to the test over the weekend. I found this…
1) In sheet goods, particularly hardwood plys, the General is fantastic. No tearout and a baby smooth finish. Shocked me how good it was even though I read several reviews.
2) It’s better at ripping than many cheap rip blades….
3) It’s sharp enough to scare you stiff. Crosscutts looked like they had been cut with a lazer. Dang!
-- I'm not crying... That's dust in my eyes!
knotscott
#6 posted 06-27-2012 12:23 PM
To further address “Chris’” comment about a Hi-ATB from Forrest – Since this review was written, Forrest has introduced a new 48T WWII with a 25° top bevel cut.
I’ve had my Super General for ~ 3 years now and it’s still sharp. Keeping things in perspective, I’m a hobby with low volumes of work in my shop, and I have enough blades that I tend to save this one for more critical applications so it doesn’t see constant use, but it’s hanging tough and still has outstanding cut quality.
