I love this stuff!
Review by Drew posted 11-16-2015 11:25 PM 7776 views 12 times favorited 13 comments Add to Favorites Watch
I love this stuff! No-picture-s No-picture-s Click the pictures to enlarge them
I’m sure I have sprayed 20+ different waterborne topcoats the last 6-7 years. Several of which I’ve sprayed well over 50 gallons of! Most of which was on corporate or commercial projects.
As with most things, there are things I like and dislike about all of them. About a year ago I decided to try emtech. Jeff (owner, target coatings) suggested I use 8000cv. I had yet to shoot a waterborne conversion varnish that I liked so I went with 9300 instead. After a short learning curve I became fond it, although it can picky about how its used.
One of my big clients ask me to make them some walnut tables finished with EnduroVar, so I did. EV has a beautiful color to it, but I found it’s not a high enough quality product for commercial tabletops. With that I decided to try EM8000cv.
I spray using a Fuji Mini-Mite 4 with their T70 gun (great system btw). With this setup I was instantly happy shooting 8000cv. It took very little playing to get it to work good. This stuff shoots nice, lays down great and feels very good to the touch. You do need to strain it, and I run water through my gun after every coat (gun held upside down under faucet till stream runs clear). And on that note, this stuff has to be the easiest stuff I have ever cleaned out of a gun. Bonus!
Did I mention durability yet! Oh yes, it’s durable! I had some epoxy leach out of some knots on an ash table. I was able to soak those spots enough with denatured alcohol that I could scrub and pick all the bad epoxy out WITHOUT effecting the finish! I was blown away! I have a walnut table in my office that has only 2 coats of 8000cv on it that I have abused as a test piece for a good 6 months, and it looks like the week after I shot it!
I highly recommend this product (as well as Target Coatings in general) for anyone that sprays on their topcoats as it is the best product I have used!
Ash top with 3 coats of 8000cv
Oak tops with walnut inlay. Left is untouched, right has one coat 8000cv
Before picture of some reclaimed barn wood tops, skip planed (bottom side up)
Now the top sides with 3 coats of 8000cv
-- TruCraftFurniture.com
View Drew's profile
Drew
350 posts in 3339 days
13 comments so far
View seriousturtle's profile
seriousturtle
101 posts in 3570 days
#1 posted 11-17-2015 01:43 AM
Thanks for the post. The only water-based product I’ve sprayed is Sherwin Williams Kem-Aqua. That stuff is nice, but doesn’t lay as smooth as I’d like. Maybe I’ll give this a shot. Did the EM8000cv give those tables the yellow oil color?
-- ~the turtle
View Drew's profile
Drew
#2 posted 11-17-2015 01:58 AM
Yes. These are just 8000, no color added.
The only thing I’ve found that is easier to shoot is GF Enduro poly, but it doesn’t have great durability.
View AandCstyle's profile
AandCstyle
3185 posts in 2496 days
#3 posted 11-17-2015 11:29 PM
Drew, I am just a hobby woodworker, but I have been using Target’s products for over 6 years, primarily EM6000. I agree with all you said and will add that I have never had a problem with blushing and sanding between coats is minimal to non-existent.
-- Art
View Ken90712's profile
Ken90712
17616 posts in 3428 days
#4 posted 11-18-2015 10:01 AM
Great advice and info Thx, I’ll be trying it
View Drew's profile
Drew
#5 posted 11-18-2015 05:00 PM
6000 is good stuff too.
I use it when I need true water white, like over painted furniture and between paint colors.
And with a coupon code you can’t beat the price!
Drew, I am just a hobby woodworker, but I have been using Target s products for over 6 years, primarily EM6000. I agree with all you said and will add that I have never had a problem with blushing and sanding between coats is minimal to non-existent.
- AandCstyle
View Drew's profile
Drew
#6 posted 11-18-2015 05:01 PM
I should add the only real downside with EmTech products is that they are not available locally. S&H prices do add up
View OSU55's profile
OSU55
2033 posts in 2229 days
#7 posted 11-18-2015 06:00 PM
I am a hobbyist and dont use a lot of topcoat products but I started using WB about 5 yrs ago. Based on research I chose Target Coatings. I have used a few other WBs from the bbs and There is no comparison to Targets products. While I dont have personal experience with other higher end WB topcoats I see more of these comparisons where Target comes out on top.
Ive used em6000, 2000, and 9000. Based on Targets data and my experience, and low volume use, I chose to continue using the 6000 and 9000. Both provide water clear clarity and can be tinted to get amber/yellow look of oil finishes. Targets WR4000 is an excellent stain base that can be tinted with Transtint.
View Hawaiilad's profile
Hawaiilad
3312 posts in 3260 days
#8 posted 11-19-2015 02:20 AM
Can you guys tell me is this can be used as a wipe on? I use allot of wipe on poly and am always looking for something better of course
-- Larry in Hawaii,
View Drew's profile
Drew
#9 posted 11-19-2015 04:57 PM
- Hawaiilad
Nope. ^95% of waterborne topcoats dry to fast to wipe on. I’ve heard of a few through the years but haven’t tried any of them.
^83.6% of all statistics are made up on the spot
OSU55
#10 posted 11-19-2015 06:16 PM
Yes they can using the available retarder on smaller projects. They are best applied with a foam brush vs wiping. It’s really best to spray them. Unless you are looking for a non-yellowing finish, stay with oil based poly for wiping.
View CharlesA's profile
CharlesA
3359 posts in 2037 days
#11 posted 11-19-2015 10:20 PM
I’m no expert, but with GF waterborne poly, I can brush or use a pad on smaller surfaces or vertical surfaces, but it you have a larger flat table top or the like, you have to spray to get it really nice.
View tblake1984's profile
tblake1984
29 posts in 1410 days
#12 posted 11-24-2015 02:57 PM
Drew,
You mention that you shoot this stuff over paint? I am looking to do something similar to a vanity I am finsihing up right now. I would like to shoot it with white paint and then use 6000 over it to protect it. What kind of paint would you recommend I use?
I am new to spray finishing so any tips you could provide would be appreciated.
View ClammyBallz's profile
ClammyBallz
449 posts in 1376 days
#13 posted 12-08-2015 06:07 PM
Instead of painting it white, consider using the white lacquer. I have used the black and it’s awesome stuff. It doesn’t get gummy like paint and dries in an hour.
http://targetcoatings.com/products/pigmented-top-coats-interior/em6500-seriespigmented-spray-lacquer/
