Harbor Freight 13" DP (Model 38142)
Review by knotscott posted 260 days ago 1463 views 0 times favorited 3 comments Add to Favorites Watch
Harbor Freight 13" DP (Model 38142) No-picture-s No-picture-s Click the pictures to enlarge them
This 13” DP is a far cry from my most prestigious tool, and Harbor Freight’s “Central Machinery” brand doesn’t typically conjure up tons of confidence and the obligatory “Tim the tool man Taylor” grunts that the big names will, but this particular purchase has been too good to not give it the credit it’s due. The 38142 is a 13”, 16 speed, 3/4 hp benchtop drill press. It weighs in at a respectable 125#, and stands over 40” tall. It has a quill stroke of 3-1/8” and spins from 240 to 2600 RPMs.
The Central Machinery hollow mortiser is the only other motorized Harbor Freight tool I’ve tried so far. Like many of you, I’m justifiably cautious about putting my trust and hard earned money into their products, especially those that plug into the wall! Many items are “hit and miss” at best, but there are some functional tools often at outrageously attractive prices. Since there are two stores near me, and they have a fairly generous return policy, I decided to drop my guard and make this purchase for $144 (on sale, plus a coupon). I had scoped out most of the competitors in this class and price range…Craftsman 12”, Hitachi, Delta, Ryobi, Grizzly, etc. The HF not only looked pretty stout, it offered the most DP for the money IMO. It’s very similar to the Grizzly G7943.
The motor is surprisingly stout…considerably more powerful than my little 8” 1/2 HP Grizzly that this replaced, and actually seems to be rated fairly accurately. Vibration is very low, and runout is nearly non-existent. The swing of 13” is fairly generous for a benchtop, and the stroke is a reasonable 3-1/8”. The 38142 lacks many of the creature comforts of some of the others…no lasers, no variable speed dials, no fancy hold downs, but it is a solidly built basic drill press with good basic function for my needs. Changing belts is a bit of a nuisance, but no worse than most. I’ve pondered upgrading the belts to link belts, but there’s so little vibration I fear I’ll be wasting money.
I honestly don’t know what more I could asak from this tool, and think that I would have needed to spend in the range of 3 times the amount to get significantly more tool. It won’t have much resale value should I decide to move it, and it might not hang around for 35 years (maybe it will), but I’ve been surprisingly impressed with this particular HF purchase in it’s first year of excellent service.
From the supplier:
Machined steel column features rack and pinion table movement. Cast iron table is accurately gauged, tilts to 45° left or right. Precision chuck holds bit from the smallest wire gauge to the largest size with 5/8’’ shank. Morse taper spindle for versatility. Adjustable depth stop and gauge included. Table and base are slotted for easy vise installation.
  • Chuck capacity: 7/64’’ to 5/8’‘
  • Six-speed spindle, from 240 to 3600 RPM
  • Spindle stroke: 3-1/8’‘
  • Spindle Taper: MT2
Motor HP: 3/4; Column diameter: 2-57/64’’; Table size: 11-1/2’’ diameter; Swing: 13-7/8’’; Base size: 17-5/8’’ x 10’’; Height: 41-3/4’‘
Tool weight: 125 lbs.
ITEM 38142-9VGA
View knotscott's profile (online now)
knotscott
539 posts in 275 days
3 comments so far
View USCJeff's profile
USCJeff
901 posts in 968 days
posted 260 days ago
Always nice to get a good one from HF. There’s not a whole lot to a Drill Press, so decent gamble. I’ve been happy with their Dust Collector. Only use it between two tools adjacent to it. Same thing as you said, I oculd spend triple for a centralized machine, but it met my needs for the most part.
-- Jeff, South Carolina
View mrsawdust's profile
mrsawdust
47 posts in 466 days
posted 259 days ago
Knot,
nicely written review. continued sucess with the drill press….
mike
-- mrsawdust, pittsburgh,pa.
View Emeralds's profile
Emeralds
155 posts in 462 days
posted 259 days ago
Reliable functionality and value, two of the big three. Not being a “tool snob” myself, I don’t own any of the truly highend names. I started buying tools in my 20’s. Now in my mid 50’s I still own and use many of the tools I purchased years ago daily. None are names that would impress but I paid a fair price and am still using them 30 years later.
Happy to hear you’ve found a good one.
-- JMP
