Incra V27 Basic Miter Gauge
Review by knotscott posted 257 days ago 752 views 0 times favorited 7 comments Add to Favorites Watch
Incra V27 Basic Miter Gauge No-picture-s No-picture-s Click the pictures to enlarge them
The V27 is Incra’s entry level basic gauge retailing at about $60 and is constructed primarily of sturdy steel with some well placed nylon trim pieces. The bottom of the steel protractor head glides on a nylon pad that rides along the table surface. The Incra has a “GlideLOCK” miter bar that consists of 4 expandable nylon adjustment spacers in the bar to be perfectly taylor fitted to the standard 3/4”x3/8” miter slot on your saw. There is a removable t-clip on the end of the bar for added holding stability in slots that have a t-groove. The V27 features 27 indexed angle settings with laser cut notches every 5 degrees plus a couple extra for the most popular angles. It’s held firmly in place with Incra’s “AngleLock” – a positive locking steel pointer that fits perfectly into the v-shaped notches . It also has one degree hash marks on the protractor compass for more minute adjustments. The push handle is a robust hard plastic round knob mounted just behind the face. Overall it’s well built but is a little lighter duty than my stock cast iron gauge. It is however considerably more precise.
My gauge was not dead-on as received out of the package. Adjusting the miter head square to the bar is a bit tedious and requires loosening 4 hex screws in the face using the supplied hex wrench, and manually aligning it to a reference like the miter bar or miter slot. Once dialed in, it’s very accurate and stays put. Another task that’s a bit tedious involves the Glidelock bar width adjustments. Three of the adjustment spacers are easily accessible and require only a turn of the hex screw to adjust, but the fourth adjustment washer resides underneath the head assembly which needs to be removed in order to access. Again, once adjusted and dialed in, the performance is amazing. There is no lateral slop in the miter slot, and with my hand resting on the table surface using only thumb power, a flick of my thumb launches the gauge to the back of the saw! (“Don’t try this at home folks…”) The nylon pad under the head is a really effective feature. No other gauge I’ve ever used slides anywhere near as well as the Incra. Great design feature. The instructions for making these adjustments are clear with good picture examples.
The V27 is extremely easy to use and is very accurate at the prenotched angles. Loosen the AngleLock pointer and the handle, rotate the gauge to the desired notch, and place the pointer firmly back into the form fitting V slot. It’s simple and goof proof as long as you use the 5 degree notch settings provided. The AngleLock pointer sits firmly in the indented V notch for the indexed settings, but for finer increments, the pointer gets backed out of the notch and is consistently skewed from this position and doesn’t lend itself well to precision with the one degree increments. The Incra 1000 and higher models address this issue with an additional plastic vernier pointer which slides back and forth above the indexed notches and points directly at the printed markings on the compass. I added my own version of this pointer using a small piece of mylar that I aligned with the zero reading, and can be pointed more accurately at any 1 degree marking on the gauge much like the more expensive models. (One of these days I’ll replace the transparency film with something more elegant and permanent, but this works…see the pics below) At $60 the V27 is tremendous value in my opinion.
homemade pointer
pointer
View knotscott's profile (online now)
knotscott
529 posts in 270 days
7 comments so far
View CessnaPilotBarry's profile
CessnaPilotBarry
1273 posts in 597 days
posted 256 days ago
I think these are fantastic, I have several. Adjust it once, and depend on the marks for quick, repeatable setups.
The lack of a fence is actually a reasonably good thing, as I add sacrificial fences to all of my miter gages. Two screws and an appropriately sized MDF scrap, and you’re good! An additional benefit to a sacrificial fence is that the operator will always know exactly where the kerf will land. Flip stops are great, but it’s just as simple to clamp a scrap block to the sacrificial fence.
I’ve also built mini-sleds that attach for speciific router table and band saw operations.
All of my 90 degree table saw cuts are done with sleds, the gages get used for everything else.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View Doug S.'s profile
Doug S.
306 posts in 603 days
posted 256 days ago
5 Stars from me too. If you have a bandsaw, throuw away that POS gauge that came with your BS and buy this.
-- Use the fence Luke
View RedShirt013's profile
RedShirt013
117 posts in 557 days
posted 256 days ago
I got one V27 and it is awesome for the price, and the 5 degree is suitable for most of what I do. It take take a bit of work like you said to calibrate it initially, but takes less than 30 minutes in my case. If you like V27’s simplicity but not 5 degree increments, it’s not much more $ for the V120.
-- Ed
CessnaPilotBarry
posted 256 days ago
Ed,
I have two V27’s and an Incra 1000, and don’t understand what you mean by 5 degree increment. The V27 is easily set to any angle, say 21.5 degrees, and the handle is tightened to lock it, just like the 1000.
Both lock plenty tight, even without the V120’s teeth.
RedShirt013
posted 255 days ago
CessnaPilotBarry,
It’s true what you said, the V27 can be adjusted to any angle and locked. However if I stick with the 5 degrees (or 22.5) then I can use the V shaped notch & teeth to dial it in, and I know I will be dead on. It’s entirely usable at any other angles but just require some more careful eyeballing and test cuts.
-- Ed
View marcb's profile
marcb
700 posts in 568 days
posted 254 days ago
For the price this can’t be beat. Even the more expensive ones have a hard time beating it. Typically only winning at the 1degree ease of use.
I also want to add this thing is HEAVY. I kinda shy’d away from it until someone mentioned that to me. It looks light and maybe a little flimsy. No, they use heavy duty tool steel for this.
I bought one that I managed to find at the old price around x-mas. Best purchase I made for myself at that time(well the Xbox 360 was pretty good too).
View Kevin's profile
Kevin
294 posts in 853 days
posted 254 days ago
I love mine as well. So much better than the stock miter gauges with the bandsaw and tablesaw.
-- Kevin, Wichita, Kansas
