Shop Fox W1677 3HP Cabinet Saw
Review by knotscott posted 03-12-2009 12:42 AM 8419 views 1 time favorited 8 comments Add to Favorites Watch
Shop Fox W1677 3HP Cabinet Saw No-picture-s No-picture-s Click the pictures to enlarge them
The W1677 is a 3hp, 10”, left tilt, triple belt drive industrial cabinet saw with a Shop Fox Classic t-square style fence that offers 26” rip capacity. Shop Fox is part of the Woodstock International group, which is also associated with Grizzly. Both companies are owned by businessman, luthier, and woodworker, Shiraz Balolia. For all intents and purposes, the Shop Fox W1677 and Grizzly G1023SL are identical except for color, retail circumstances, and warranty. The 1677 has two 10” solid cast iron extension wings for a total width of 40”. It’s also available in a few other configurations that include an alternate fence (the SF “Original”), longer rails options (EXT1, EXT2, etc), and there’s also a 5hp option (W1711). The W1677 comes with heavy duty 8” chrome handwheels, a 4” dust port, steel motor cover, a blade guard/splitter assembly, magnetic switch, standard and dado inserts, and a very heavy duty cast iron miter gauge. The Shop Fox Classic fence is a good copy of the venerable Biesemeyer Commercial fence. The most notable difference is that the fence faces are made from UHMW plastic vs the plastic laminated birch ply faces of the Biesemeyer. One downfall of the Shop Fox Classic fence is that in it’s stock configuration the fence rails only offer 26” rip capacity to the right of the blade and 8” to the left. Because this is a left tilting saw, I didn’t envision ever needing the capacity to rip on the left side of the blade, so during the initial setup I slid the front fence rail over to the right an additional 10” for a respectable rip capacity of 36” to the right of the blade and none to the left. This minor modification still allowed me to use the stock bolt holes and required no extra drilling…there’s simply one less bolt holding the rail tube. Since the measuring tape had never been installed on the rail, I was still able to place it appropriately starting at zero. The tape readout only extends to 26” so I’ll have to either measure by hand for rips beyond 26”, or add an extension tape to 36”.
The 1677 was in alignment as received out of the box, so I haven’t needed to make any trunnion adjustments. The fence has required some tweaking to dial in, but it’s a simple process of adjusting one of two allen screws using fractions of a rotation. The miter gauge also required some adjustment but was extremely simple. The stock miter gauge is made of heavy duty cast iron and offers width adjusters for the miter bar to eliminate any slop. As rugged as this gauge is, it lacks the precision and finess of my Incra, Osborne, and Woodhaven gauges. There was one small defect that required a call to Shop Fox’s customer service department. One screw head on the right fence face was snapped off at the factory, and unfortunately it was the first screw which left the front end of the fence loose. The options were to send the entire fence back or fix it myself. I opted to tackle the fix and went out and bought an “EZ-Out” screw extractor. Shop Fox tech service offered one of their 30T saw blades to compensate the expense of the EZ-Out. Fit and finish of the 1677 are excellent, and the Shop Fox color scheme (ivory and black) looks great in my opinion. The powder coat paint and chrome handwheels are flawless. The cast iron surfaces were nicely polished and smooth. I was surprised and disappointed to note that the wings did not include a beveled front edge. I was also a disappointed that the fence rail tubes and guide tube don’t include any type of caps in their ends. These are minor complaints to be sure, but things that I’ve come to expect from my better tools, and are both luxuries that my Craftsman 22124 hybrid saw provided. The 22124 also had 12” wings vs the Shop Fox’s 10” wings, and I do miss the additional 4” of CI surface area. The Shop Fox Classic fence is a very similar design as my former Biesemeyer Commercial fence. I do think I’m going to miss the Biese. While the fit and finish the 1677 itself is excellent, the SF Classic lacks that same level of polish, and it’s most notable on the fence handle which is the one part of the fence that I deal with the most often.
About a month after purchasing the 1677, I bought a “Bolt On Ripping Knife” (BORK) from Bob Ross of Walnutacre Woodworking. The BORK is essentially an aftermarket riving knife that travels up, down, and tilts with the blade. It’s a very nice upgrade to the clumsy stock splitter on the SF. I’ll likely post a brief separate review of the BORK later on.
All in all, the 1677 is a beautiful machine that I’m very happy with.
View knotscott's profile
knotscott
8121 posts in 3494 days
8 comments so far
View dalec's profile
dalec
612 posts in 4007 days
#1 posted 03-12-2009 04:22 PM
Deals where you get a discount along with a rebate and free shipping, seeing the deal and lining up finances is really a case of having all the stars in alignment. Thanks for the review.
Congratulations on the purchase – have fun.
Dalec
View PurpLev's profile
PurpLev
8540 posts in 3767 days
#2 posted 03-12-2009 04:31 PM
nice review, well put together – thanks!
View WoodWorkerDoc's profile
WoodWorkerDoc
7 posts in 2451 days
#3 posted 01-10-2012 02:45 AM
I am also in the market for a tablesaw, but am stuck between the Grizzly, the Shop Fox, and the Jet. Are you still glad you picked the Shop Fox? It looks beautiful in the pics, and sounds great from your review.
Thanks for the input.
Doc
knotscott
#4 posted 01-10-2012 03:23 AM
Yep, still happy….haven’t had a lick of trouble. Plenty of power, its not fussy about blades, precise enough for anything I’ll ever do. The SF and Griz should be nearly idential, so go with whichever is cheapest, but if price is close, SF offers a longer warranty. The Jet should be similar in features and overall quality…a good chunk of the premium you’d pay is for dealer support and longer warranty….all good things, but the key point is that you’re not necessarily buying a nicer saw with that extra money. Good luck!
WoodWorkerDoc
#5 posted 01-12-2012 09:19 PM
Of course, I had to go and look at the PM2000. Really nice saw, one I’d keep for a lifetime! The differences in fit & finish seem miniscule, and don’t seem like they would have any impact on reality for most woodworkers. Still, it is the PM2000…
Aside from the PM, and assuming finances weren’t a primary issue, is there any distinguishing feature about the SF, other than warranty and shipping, that swayed you towards one particular saw vs the others? It’s kinda trivial, but I do like the drawer feature in the Jet Deluxe. I need all the help I can get staying organized! Just currious what you thought having recently purchased your SF.
Thanks again.
Doc
knotscott
#6 posted 01-14-2012 12:24 PM
I grabbed mine for $903 shipped, so price/value was a major motivator in the purchase. I wasn’t really TS shopping at the time, but was familiar with the saw, and seized that price opportunity. The PM2000 has a deeper table than the other two. It’s not likely that you’ll ever be able to tell the cuts apart, but if those other “little features” are calling your name and you have the funds, I wouldn’t hesitate to spend more and get what you really like….after all, it is a hobby for many of us, and loving the tools every time we use them is part of the fun.
WoodWorkerDoc
#7 posted 01-16-2012 09:21 PM
That is an insane price! If I find a similar deal, I’ll take it. Thanks for the input. I’ll let you know what I end up with, if you’re interested. I agree with ”...loving the tools…” being part of the fun; not so sure my wife gets it though!
Regards,
Doc
knotscott
#8 posted 01-17-2012 05:30 AM
Definitely…please keep me posted.
